[QGIS Commit] r11511 -
trunk/qgis/src/plugins/raster_terrain_analysis
svn_qgis at osgeo.org
Wed Aug 26 08:28:52 EDT 2009
Author: mhugent
Date: 2009-08-26 08:28:52 -0400 (Wed, 26 Aug 2009)
New Revision: 11511
Removed:
trunk/qgis/src/plugins/raster_terrain_analysis/Makefile
Remove Makefile from svn
Deleted: trunk/qgis/src/plugins/raster_terrain_analysis/Makefile
--- trunk/qgis/src/plugins/raster_terrain_analysis/Makefile 2009-08-26 12:28:15 UTC (rev 11510)
+++ trunk/qgis/src/plugins/raster_terrain_analysis/Makefile 2009-08-26 12:28:52 UTC (rev 11511)
@@ -1,291 +0,0 @@
-# Makefile for building: libraster_terrain_analysis.so.1.0.0
-# Generated by qmake (2.01a) (Qt 4.5.0) on: Fr. Aug 21 16:16:23 2009
-# Project: raster_terrain_analysis.pro
-# Template: lib
-# Command: /usr/bin/qmake-qt4 -unix -o Makefile raster_terrain_analysis.pro
-####### Compiler, tools and options
-CC = gcc
-CXX = g++
-DEFINES = -DGUI_EXPORT= -DCORE_EXPORT= -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED
-CFLAGS = -pipe -g -D_REENTRANT -Wall -W -fPIC $(DEFINES)
-CXXFLAGS = -pipe -g -D_REENTRANT -Wall -W -fPIC $(DEFINES)
-INCPATH = -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4 -I../../../include/qgis -I../../../../gdal-1.6.0/include -I. -I.
-LINK = g++
-LFLAGS = -shared -Wl,-soname,libraster_terrain_analysis.so.1
-LIBS = $(SUBLIBS) -L/usr/lib -L/home/marco/src/qgis/lib -L/home/marco/src/gdal-1.6.0/lib -lqgis_core -lqgis_gui -lgdal -lQtGui -lQtCore -lpthread
-AR = ar cqs
-RANLIB =
-QMAKE = /usr/bin/qmake-qt4
-TAR = tar -cf
-COMPRESS = gzip -9f
-COPY = cp -f
-SED = sed
-COPY_FILE = $(COPY)
-COPY_DIR = $(COPY) -r
-INSTALL_FILE = install -m 644 -p
-INSTALL_DIR = $(COPY_DIR)
-INSTALL_PROGRAM = install -m 755 -p
-DEL_FILE = rm -f
-SYMLINK = ln -sf
-DEL_DIR = rmdir
-MOVE = mv -f
-CHK_DIR_EXISTS= test -d
-MKDIR = mkdir -p
-####### Output directory
-OBJECTS_DIR = ./
-####### Files
-SOURCES = qgsrasterterrainanalysisplugin.cpp \
- qgsninecellfilter.cpp \
- qgsruggednessfilter.cpp \
- qgsderivativefilter.cpp \
- qgsslopefilter.cpp \
- qgsaspectfilter.cpp \
- qgstotalcurvaturefilter.cpp \
- qgsrasterterrainanalysisdialog.cpp moc_qgsrasterterrainanalysisplugin.cpp \
- moc_qgsrasterterrainanalysisdialog.cpp \
- qrc_resources.cpp
-OBJECTS = qgsrasterterrainanalysisplugin.o \
- qgsninecellfilter.o \
- qgsruggednessfilter.o \
- qgsderivativefilter.o \
- qgsslopefilter.o \
- qgsaspectfilter.o \
- qgstotalcurvaturefilter.o \
- qgsrasterterrainanalysisdialog.o \
- moc_qgsrasterterrainanalysisplugin.o \
- moc_qgsrasterterrainanalysisdialog.o \
- qrc_resources.o
-DIST = /usr/share/qt4/mkspecs/common/g++.conf \
- /usr/share/qt4/mkspecs/common/unix.conf \
- /usr/share/qt4/mkspecs/common/linux.conf \
- /usr/share/qt4/mkspecs/qconfig.pri \
- /usr/share/qt4/mkspecs/features/qt_functions.prf \
- /usr/share/qt4/mkspecs/features/qt_config.prf \
- /usr/share/qt4/mkspecs/features/exclusive_builds.prf \
- /usr/share/qt4/mkspecs/features/default_pre.prf \
- /usr/share/qt4/mkspecs/features/debug.prf \
- /usr/share/qt4/mkspecs/features/default_post.prf \
- /usr/share/qt4/mkspecs/features/qt.prf \
- /usr/share/qt4/mkspecs/features/unix/thread.prf \
- /usr/share/qt4/mkspecs/features/moc.prf \
- /usr/share/qt4/mkspecs/features/warn_on.prf \
- /usr/share/qt4/mkspecs/features/resources.prf \
- /usr/share/qt4/mkspecs/features/uic.prf \
- /usr/share/qt4/mkspecs/features/yacc.prf \
- /usr/share/qt4/mkspecs/features/lex.prf \
- raster_terrain_analysis.pro
-QMAKE_TARGET = raster_terrain_analysis
-DESTDIR =
-TARGET = libraster_terrain_analysis.so.1.0.0
-TARGETA = libraster_terrain_analysis.a
-TARGETD = libraster_terrain_analysis.so.1.0.0
-TARGET0 = libraster_terrain_analysis.so
-TARGET1 = libraster_terrain_analysis.so.1
-TARGET2 = libraster_terrain_analysis.so.1.0
-first: all
-####### Implicit rules
-.SUFFIXES: .o .c .cpp .cc .cxx .C
-.cpp.o:
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o "$@" "$<"
-.cc.o:
-.cxx.o:
-.C.o:
-.c.o:
- $(CC) -c $(CFLAGS) $(INCPATH) -o "$@" "$<"
-####### Build rules
-all: Makefile $(TARGET)
-$(TARGET): ui_qgsrasterterrainanalysisdialogbase.h $(OBJECTS) $(SUBLIBS) $(OBJCOMP)
- -$(DEL_FILE) $(TARGET) $(TARGET0) $(TARGET1) $(TARGET2)
- $(LINK) $(LFLAGS) -o $(TARGET) $(OBJECTS) $(LIBS) $(OBJCOMP)
- -ln -s $(TARGET) $(TARGET0)
- -ln -s $(TARGET) $(TARGET1)
- -ln -s $(TARGET) $(TARGET2)
-staticlib: $(TARGETA)
-$(TARGETA): ui_qgsrasterterrainanalysisdialogbase.h $(OBJECTS) $(OBJCOMP)
- -$(DEL_FILE) $(TARGETA)
- $(AR) $(TARGETA) $(OBJECTS)
-Makefile: raster_terrain_analysis.pro /usr/share/qt4/mkspecs/linux-g++/qmake.conf /usr/share/qt4/mkspecs/common/g++.conf \
- /usr/lib/libQtGui.prl \
- /usr/lib/libQtCore.prl
- $(QMAKE) -unix -o Makefile raster_terrain_analysis.pro
-/usr/share/qt4/mkspecs/common/g++.conf:
-/usr/share/qt4/mkspecs/common/unix.conf:
-/usr/share/qt4/mkspecs/common/linux.conf:
-/usr/share/qt4/mkspecs/qconfig.pri:
-/usr/share/qt4/mkspecs/features/qt_functions.prf:
-/usr/share/qt4/mkspecs/features/qt_config.prf:
-/usr/share/qt4/mkspecs/features/exclusive_builds.prf:
-/usr/share/qt4/mkspecs/features/default_pre.prf:
-/usr/share/qt4/mkspecs/features/debug.prf:
-/usr/share/qt4/mkspecs/features/default_post.prf:
-/usr/share/qt4/mkspecs/features/qt.prf:
-/usr/share/qt4/mkspecs/features/unix/thread.prf:
-/usr/share/qt4/mkspecs/features/moc.prf:
-/usr/share/qt4/mkspecs/features/warn_on.prf:
-/usr/share/qt4/mkspecs/features/resources.prf:
-/usr/share/qt4/mkspecs/features/uic.prf:
-/usr/share/qt4/mkspecs/features/yacc.prf:
-/usr/share/qt4/mkspecs/features/lex.prf:
-/usr/lib/libQtGui.prl:
-/usr/lib/libQtCore.prl:
-qmake: FORCE
- @$(QMAKE) -unix -o Makefile raster_terrain_analysis.pro
-dist:
- @$(CHK_DIR_EXISTS) .tmp/raster_terrain_analysis1.0.0 || $(MKDIR) .tmp/raster_terrain_analysis1.0.0
- $(COPY_FILE) --parents $(SOURCES) $(DIST) .tmp/raster_terrain_analysis1.0.0/ && $(COPY_FILE) --parents qgsrasterterrainanalysisplugin.h qgsninecellfilter.h qgsruggednessfilter.h qgsderivativefilter.h qgsslopefilter.h qgsaspectfilter.h qgsrasterterrainanalysisdialog.h .tmp/raster_terrain_analysis1.0.0/ && $(COPY_FILE) --parents resources.qrc .tmp/raster_terrain_analysis1.0.0/ && $(COPY_FILE) --parents qgsrasterterrainanalysisplugin.cpp qgsninecellfilter.cpp qgsruggednessfilter.cpp qgsderivativefilter.cpp qgsslopefilter.cpp qgsaspectfilter.cpp qgstotalcurvaturefilter.cpp qgsrasterterrainanalysisdialog.cpp .tmp/raster_terrain_analysis1.0.0/ && $(COPY_FILE) --parents qgsrasterterrainanalysisdialogbase.ui .tmp/raster_terrain_analysis1.0.0/ && (cd `dirname .tmp/raster_terrain_analysis1.0.0` && $(TAR) raster_terrain_analysis1.0.0.tar raster_terrain_analysis1.0.0 && $(COMPRESS) raster_terrain_analysis1.0.0.tar) && $(MOVE) `dirname .tmp/raster_terrain_analysis1.0.0`/raster_terrain_analysis1.0.0.tar.gz . && $(DEL_FILE) -r .tmp/raster_terrain_analysis1.0.0
-clean:compiler_clean
- -$(DEL_FILE) $(OBJECTS)
- -$(DEL_FILE) *~ core *.core
-####### Sub-libraries
-distclean: clean
- -$(DEL_FILE) $(TARGET0) $(TARGET1) $(TARGET2) $(TARGETA)
- -$(DEL_FILE) Makefile
-mocclean: compiler_moc_header_clean compiler_moc_source_clean
-mocables: compiler_moc_header_make_all compiler_moc_source_make_all
-compiler_moc_header_make_all: moc_qgsrasterterrainanalysisplugin.cpp moc_qgsrasterterrainanalysisdialog.cpp
-compiler_moc_header_clean:
- -$(DEL_FILE) moc_qgsrasterterrainanalysisplugin.cpp moc_qgsrasterterrainanalysisdialog.cpp
-moc_qgsrasterterrainanalysisplugin.cpp: qgsrasterterrainanalysisplugin.h
- /usr/bin/moc-qt4 $(DEFINES) $(INCPATH) qgsrasterterrainanalysisplugin.h -o moc_qgsrasterterrainanalysisplugin.cpp
-moc_qgsrasterterrainanalysisdialog.cpp: ui_qgsrasterterrainanalysisdialogbase.h \
- qgsrasterterrainanalysisdialog.h
- /usr/bin/moc-qt4 $(DEFINES) $(INCPATH) qgsrasterterrainanalysisdialog.h -o moc_qgsrasterterrainanalysisdialog.cpp
-compiler_rcc_make_all: qrc_resources.cpp
-compiler_rcc_clean:
- -$(DEL_FILE) qrc_resources.cpp
-qrc_resources.cpp: resources.qrc \
- /usr/bin/rcc -name resources resources.qrc -o qrc_resources.cpp
-compiler_image_collection_make_all: qmake_image_collection.cpp
-compiler_image_collection_clean:
- -$(DEL_FILE) qmake_image_collection.cpp
-compiler_moc_source_make_all:
-compiler_moc_source_clean:
-compiler_uic_make_all: ui_qgsrasterterrainanalysisdialogbase.h
-compiler_uic_clean:
- -$(DEL_FILE) ui_qgsrasterterrainanalysisdialogbase.h
-ui_qgsrasterterrainanalysisdialogbase.h: qgsrasterterrainanalysisdialogbase.ui
- /usr/bin/uic-qt4 qgsrasterterrainanalysisdialogbase.ui -o ui_qgsrasterterrainanalysisdialogbase.h
-compiler_yacc_decl_make_all:
-compiler_yacc_decl_clean:
-compiler_yacc_impl_make_all:
-compiler_yacc_impl_clean:
-compiler_lex_make_all:
-compiler_lex_clean:
-compiler_clean: compiler_moc_header_clean compiler_rcc_clean compiler_uic_clean
-####### Compile
-qgsrasterterrainanalysisplugin.o: qgsrasterterrainanalysisplugin.cpp qgsrasterterrainanalysisplugin.h \
- qgsaspectfilter.h \
- qgsderivativefilter.h \
- qgsninecellfilter.h \
- qgsslopefilter.h \
- qgsruggednessfilter.h \
- qgsrasterterrainanalysisdialog.h \
- ui_qgsrasterterrainanalysisdialogbase.h
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgsrasterterrainanalysisplugin.o qgsrasterterrainanalysisplugin.cpp
-qgsninecellfilter.o: qgsninecellfilter.cpp qgsninecellfilter.h
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgsninecellfilter.o qgsninecellfilter.cpp
-qgsruggednessfilter.o: qgsruggednessfilter.cpp qgsruggednessfilter.h \
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgsruggednessfilter.o qgsruggednessfilter.cpp
-qgsderivativefilter.o: qgsderivativefilter.cpp qgsderivativefilter.h \
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgsderivativefilter.o qgsderivativefilter.cpp
-qgsslopefilter.o: qgsslopefilter.cpp qgsslopefilter.h \
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgsslopefilter.o qgsslopefilter.cpp
-qgsaspectfilter.o: qgsaspectfilter.cpp qgsaspectfilter.h \
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgsaspectfilter.o qgsaspectfilter.cpp
-qgstotalcurvaturefilter.o: qgstotalcurvaturefilter.cpp qgstotalcurvaturefilter.h
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgstotalcurvaturefilter.o qgstotalcurvaturefilter.cpp
-qgsrasterterrainanalysisdialog.o: qgsrasterterrainanalysisdialog.cpp qgsrasterterrainanalysisdialog.h \
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qgsrasterterrainanalysisdialog.o qgsrasterterrainanalysisdialog.cpp
-moc_qgsrasterterrainanalysisplugin.o: moc_qgsrasterterrainanalysisplugin.cpp
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o moc_qgsrasterterrainanalysisplugin.o moc_qgsrasterterrainanalysisplugin.cpp
-moc_qgsrasterterrainanalysisdialog.o: moc_qgsrasterterrainanalysisdialog.cpp
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o moc_qgsrasterterrainanalysisdialog.o moc_qgsrasterterrainanalysisdialog.cpp
-qrc_resources.o: qrc_resources.cpp
- $(CXX) -c $(CXXFLAGS) $(INCPATH) -o qrc_resources.o qrc_resources.cpp
-####### Install
-install: FORCE
-uninstall: FORCE
-FORCE:
