[QGIS Commit] r11521 - trunk/qgis/src/gui
svn_qgis at osgeo.org
Fri Aug 28 03:52:59 EDT 2009
Author: homann
Date: 2009-08-28 03:52:58 -0400 (Fri, 28 Aug 2009)
New Revision: 11521
trunk/qgis/src/gui/qgsprojectionselector.cpp
Use EPGS and Proj4 strings as persistent list of popular CRS:es
Modified: trunk/qgis/src/gui/qgsprojectionselector.cpp
--- trunk/qgis/src/gui/qgsprojectionselector.cpp 2009-08-27 01:00:55 UTC (rev 11520)
+++ trunk/qgis/src/gui/qgsprojectionselector.cpp 2009-08-28 07:52:58 UTC (rev 11521)
@@ -34,6 +34,7 @@
const int NAME_COLUMN = 0;
const int EPSG_COLUMN = 1;
const int QGIS_CRS_ID_COLUMN = 2;
+const int POPULAR_CRSES = 4;
QgsProjectionSelector::QgsProjectionSelector( QWidget* parent,
const char * name,
@@ -59,7 +60,33 @@
// Read settings from persistent storage
QSettings settings;
mRecentProjections = settings.value( "/UI/recentProjections" ).toStringList();
+ /*** The reading (above) of internal id from persistent storage should be removed sometims in the future */
+ /*** This is kept now for backwards compatibility */
+ QStringList projectionsEpsg = settings.value( "/UI/recentProjectionsEpsg" ).toStringList();
+ QStringList projectionsProj4 = settings.value( "/UI/recentProjectionsProj4" ).toStringList();
+ if ( projectionsEpsg.size() >= mRecentProjections.size() )
+ // We had saved state with EPSG and Proj4. Use that instead
+ // to find out the csr id
+ QgsDebugMsg( "Use popular projection list from EPSG/Proj4 saved state" );
+ mRecentProjections.clear();
+ for ( int i = 0; i < projectionsEpsg.size(); i++ )
+ // Create a crs from the EPSG
+ QgsCoordinateReferenceSystem crs( projectionsEpsg.at( i ).toLong(), QgsCoordinateReferenceSystem::EpsgCrsId );
+ if ( ! crs.isValid() )
+ // Couldn't create from EPSG, try the Proj4 string instead
+ if ( ! crs.createFromProj4( projectionsProj4.at( i ) ) )
+ // No? Skip this entry
+ continue;
+ mRecentProjections << QString::number( crs.srsid() );
@@ -75,13 +102,32 @@
mRecentProjections.removeAll( QString::number( crsId ) );
mRecentProjections.prepend( QString::number( crsId ) );
- // Prunse size of list
+ // Prune size of list
while ( mRecentProjections.size() > 4 )
mRecentProjections.removeLast();
- // Save to file
+ // Save to file *** Should be removed sometims in the future ***
settings.setValue( "/UI/recentProjections", mRecentProjections );
+ // Convert to EPGS and proj4, and save those values also
+ QStringList projectionsEpsg;
+ QStringList projectionsProj4;
+ for ( int i = 0; i < mRecentProjections.size(); i++ )
+ // Create a crs from the crsId
+ QgsCoordinateReferenceSystem crs( mRecentProjections.at( i ).toLong(), QgsCoordinateReferenceSystem::InternalCrsId );
+ continue;
+ projectionsEpsg << QString::number( crs.epsg() );
+ projectionsProj4 << crs.toProj4();
+ settings.setValue( "/UI/recentProjectionsEpsg", projectionsEpsg );
+ settings.setValue( "/UI/recentProjectionsProj4", projectionsProj4 );
@@ -205,8 +251,8 @@
//this line is neccesary to make change projection work
//with geoserver because for some reason geoserver returns
//EPSG:WGS84(DD) as the first srs and is invalid because the
- //epsg database expect an integer string
- if(rx.indexIn(parts.at( 1 )) == -1)
+ //epsg database expect an integer string
+ if ( rx.indexIn( parts.at( 1 ) ) == -1 )
epsgParts.push_back( parts.at( 1 ) );
