[QGIS Commit] r11524 - in trunk/qgis/src: app gui
svn_qgis at osgeo.org
Sat Aug 29 15:14:28 EDT 2009
Author: homann
Date: 2009-08-29 15:14:28 -0400 (Sat, 29 Aug 2009)
New Revision: 11524
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/gui/qgsencodingfiledialog.cpp
trunk/qgis/src/gui/qgsencodingfiledialog.h
Add a "cancel all" button when searching for missing files after opening a project. Fixes #1317
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2009-08-28 20:32:23 UTC (rev 11523)
+++ trunk/qgis/src/app/qgisapp.cpp 2009-08-29 19:14:28 UTC (rev 11524)
@@ -2338,10 +2338,13 @@
-static void openFilesRememberingFilter_( QString const &filterName,
- QString const &filters, QStringList & selectedFiles, QString& enc, QString &title )
+static bool openFilesRememberingFilter_( QString const &filterName,
+ QString const &filters, QStringList & selectedFiles, QString& enc, QString &title,
+ bool cancelAll = false )
+ bool retVal = false;
bool haveLastUsedFilter = false; // by default, there is no last
// used filter
@@ -2367,6 +2370,12 @@
openFileDialog->selectFilter( lastUsedFilter );
+ // Check if we should add a cancel all button
+ if ( cancelAll )
+ openFileDialog->addCancelAll();
if ( openFileDialog->exec() == QDialog::Accepted )
selectedFiles = openFileDialog->selectedFiles();
@@ -2383,8 +2392,14 @@
settings.setValue( "/UI/" + filterName, openFileDialog->selectedFilter() );
settings.setValue( "/UI/" + filterName + "Dir", myPath );
+ else
+ // Cancel or cancel all
+ retVal = openFileDialog->cancelAll();
delete openFileDialog;
+ return retVal;
} // openFilesRememberingFilter_
@@ -2938,7 +2953,7 @@
static
-void
+bool
findMissingFile_( QString const & fileFilters, QDomNode & layerNode )
// Prepend that file name to the valid file format filter list since it
@@ -2966,7 +2981,7 @@
default:
QgsDebugMsg( "unable to determine data type" );
- return;
+ return false;
// Prepend the original data source base name to make it easier to pick it
@@ -2982,15 +2997,16 @@
.arg( originalDataSource.fileName() )
.arg( originalDataSource.absoluteFilePath() );
- openFilesRememberingFilter_( memoryQualifier,
- myFileFilters,
- selectedFiles,
- enc,
- title );
+ bool retVal = openFilesRememberingFilter_( memoryQualifier,
+ myFileFilters,
+ selectedFiles,
+ enc,
+ title,
+ true );
if ( selectedFiles.isEmpty() )
- return;
+ return retVal;
else
@@ -3000,7 +3016,7 @@
QgsDebugMsg( "unable to re-read layer" );
+ return retVal;
} // findMissingFile_
@@ -3019,17 +3035,19 @@
static
-void
+bool
findLayer_( QString const & fileFilters, QDomNode const & constLayerNode )
// XXX actually we could possibly get away with a copy of the node
QDomNode & layerNode = const_cast<QDomNode&>( constLayerNode );
switch ( providerType_( layerNode ) )
case IS_FILE:
QgsDebugMsg( "layer is file based" );
- findMissingFile_( fileFilters, layerNode );
+ retVal = findMissingFile_( fileFilters, layerNode );
break;
case IS_DATABASE:
@@ -3044,7 +3062,7 @@
QgsDebugMsg( "layer has an unkown type" );
break;
+ return retVal;
} // findLayer_
@@ -3064,7 +3082,11 @@
i != layerNodes.end();
++i )
- findLayer_( fileFilters, *i );
+ if ( findLayer_( fileFilters, *i ) )
+ // If findLayer returns true, the user hit Cancel All button
+ break;
} // findLayers_
Modified: trunk/qgis/src/gui/qgsencodingfiledialog.cpp
--- trunk/qgis/src/gui/qgsencodingfiledialog.cpp 2009-08-28 20:32:23 UTC (rev 11523)
+++ trunk/qgis/src/gui/qgsencodingfiledialog.cpp 2009-08-29 19:14:28 UTC (rev 11524)
@@ -18,6 +18,7 @@
#include "qgslogger.h"
#include <QSettings>
#include <QComboBox>
+#include <QPushButton>
#include <QLabel>
#include <QLayout>
#include <QTextCodec>
@@ -28,6 +29,8 @@
const QString & filter, const QString & encoding )
: QFileDialog( parent, caption, directory, filter )
+ mCancelAll = false;
+ mCancelAllButton = 0;
mEncodingComboBox = new QComboBox( this );
QLabel* l = new QLabel( tr( "Encoding:" ), this );
layout()->addWidget( l );
@@ -121,3 +124,25 @@
settings.setValue( "/UI/encoding", encoding() );
QgsDebugMsg( QString( "Set encoding " + encoding() + " as default." ) );
+void QgsEncodingFileDialog::addCancelAll()
+ if ( ! mCancelAllButton )
+ mCancelAllButton = new QPushButton( "Cancel &All", NULL );
+ layout()->addWidget( mCancelAllButton ); // Ownership transfered, no need to delete later on
+ connect( mCancelAllButton, SIGNAL( clicked() ), this, SLOT( pbnCancelAll_clicked() ) );
+bool QgsEncodingFileDialog::cancelAll()
+ return mCancelAll;
+void QgsEncodingFileDialog::pbnCancelAll_clicked()
+ mCancelAll = true;
+ // Now, continue as the user clicked the cancel button
+ reject();
Modified: trunk/qgis/src/gui/qgsencodingfiledialog.h
--- trunk/qgis/src/gui/qgsencodingfiledialog.h 2009-08-28 20:32:23 UTC (rev 11523)
+++ trunk/qgis/src/gui/qgsencodingfiledialog.h 2009-08-29 19:14:28 UTC (rev 11524)
@@ -18,6 +18,7 @@
#include <QFileDialog>
class QComboBox;
+class QPushButton;
/** \ingroup gui
* A file dialog which lets the user select the prefered encoding type for a data provider.
@@ -32,12 +33,25 @@
~QgsEncodingFileDialog();
/**Returns a string describing the choosen encoding*/
QString encoding() const;
+ /* Adds a 'Cancel All' button for the user to click */
+ void addCancelAll();
+ /* Returns true if the user clicked 'Cancel All' */
+ bool cancelAll();
public slots:
void saveUsedEncoding();
+ void pbnCancelAll_clicked();
private:
/**Box to choose the encoding type*/
QComboBox* mEncodingComboBox;
+ /* The button to click */
+ QPushButton *mCancelAllButton;
+ /* Set if user clicked 'Cancel All' */
+ bool mCancelAll;
#endif
