[QGIS Commit] r11526 - trunk/qgis/ms-windows
svn_qgis at osgeo.org
Sun Aug 30 10:23:21 EDT 2009
Author: timlinux
Date: 2009-08-30 10:23:21 -0400 (Sun, 30 Aug 2009)
New Revision: 11526
trunk/qgis/ms-windows/QGIS-Installer.nsi
Added grass and nograss clauses
Modified: trunk/qgis/ms-windows/QGIS-Installer.nsi
--- trunk/qgis/ms-windows/QGIS-Installer.nsi 2009-08-30 13:59:53 UTC (rev 11525)
+++ trunk/qgis/ms-windows/QGIS-Installer.nsi 2009-08-30 14:23:21 UTC (rev 11526)
@@ -9,7 +9,7 @@
;Select if you are building a "Development Version" or a "Release Version" of the Quantum GIS Installer
;Change the INSTALLER_TYPE variable to Release or Development
-!define INSTALLER_TYPE "Release"
+!define INSTALLER_TYPE "Release-NoGrass"
@@ -39,7 +39,7 @@
;define the QGIS Base Name
-!define RELEASE_QGIS_BASE "Quantum GIS"
+!define RELEASE_QGIS_BASE "Quantum GIS Daphnis"
!define DEV_QGIS_BASE "Quantum GIS Unstable Dev"
;Set the installer variables, depending on the selected version to build
@@ -56,6 +56,18 @@
!define CHECK_INSTALL_NAME "${RELEASE_QGIS_BASE}"
!define INSTALLER_DISPLAYED_NAME "${COMPLETE_NAME}"
!define PACKAGE_FOLDER ".\QGIS-Release-Package"
+!else if ${INSTALLER_TYPE} == "Release-NoGrass"
+ !define VERSION_NUMBER "${RELEASE_VERSION_NUMBER}"
+ !define VERSION_NAME "${RELEASE_VERSION_NAME}"
+ !define COMPLETE_NAME "${RELEASE_QGIS_BASE} ${RELEASE_VERSION_NUMBER} ${RELEASE_VERSION_NAME}"
+ !define SVN_REVISION "${RELEASE_SVN_REVISION}"
+ !define BINARY_REVISION "${RELEASE_BINARY_REVISION}"
+ !define QGIS_BASE "${RELEASE_QGIS_BASE}"
+ !define INSTALLER_NAME "QGIS-${VERSION_NUMBER}-${BINARY_REVISION}-Setup.exe"
+ !define DISPLAYED_NAME "${RELEASE_QGIS_BASE} ${VERSION_NUMBER}-${BINARY_REVISION}"
+ !define CHECK_INSTALL_NAME "${RELEASE_QGIS_BASE}"
+ !define INSTALLER_DISPLAYED_NAME "${COMPLETE_NAME}"
+ !define PACKAGE_FOLDER ".\QGIS-Release-Package-No-Grass"
!else if ${INSTALLER_TYPE} == "Development"
!define VERSION_NUMBER "${DEV_VERSION_NUMBER}"
!define VERSION_NAME "${DEV_VERSION_NAME}"
@@ -525,6 +537,9 @@
Delete "$INSTDIR\icons\QGIS.ico"
Delete "$INSTDIR\icons\QGIS_Web.ico"
+ Delete "$INSTDIR\MRSID_README.txt"
+ Delete "$INSTDIR\run.bat"
;remove folders
RMDir /r "$INSTDIR\bin"
@@ -541,6 +556,8 @@
RMDir /r "$INSTDIR\resources"
RMDir /r "$INSTDIR\svg"
RMDir /r "$INSTDIR\themes"
+ RMDir /r "$INSTDIR\proj"
+ RMDir /r "$INSTDIR\epsg_csv"
;if empty, remove the install folder
RMDir "$INSTDIR"
