[QGIS Commit] r12339 - in trunk/qgis/src/ui: . symbollayer
svn_qgis at osgeo.org
Sat Dec 5 12:04:44 EST 2009
Author: jef
Date: 2009-12-05 12:04:44 -0500 (Sat, 05 Dec 2009)
New Revision: 12339
trunk/qgis/src/ui/qgscomposerbase.ui
trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
trunk/qgis/src/ui/qgscompositionbase.ui
trunk/qgis/src/ui/qgsfieldcalculatorbase.ui
trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
trunk/qgis/src/ui/symbollayer/widget_simpleline.ui
fix ui warnings
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui 2009-12-05 17:03:44 UTC (rev 12338)
+++ trunk/qgis/src/ui/qgscomposerbase.ui 2009-12-05 17:04:44 UTC (rev 12339)
@@ -20,7 +20,7 @@
<property name="mouseTracking">
<bool>true</bool>
</property>
- <layout class="QGridLayout" name="gridLayout">
+ <layout class="QGridLayout" name="gridLayout_1">
<item row="0" column="0">
<widget class="QSplitter" name="mSplitter">
Modified: trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui 2009-12-05 17:03:44 UTC (rev 12338)
+++ trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui 2009-12-05 17:04:44 UTC (rev 12339)
@@ -150,7 +150,7 @@
<property name="title">
<string>Options</string>
</property>
<widget class="QLabel" name="label">
<property name="text">
Modified: trunk/qgis/src/ui/qgscompositionbase.ui
--- trunk/qgis/src/ui/qgscompositionbase.ui 2009-12-05 17:03:44 UTC (rev 12338)
+++ trunk/qgis/src/ui/qgscompositionbase.ui 2009-12-05 17:04:44 UTC (rev 12339)
@@ -31,7 +31,7 @@
<string>Paper</string>
</property>
<property name="margin">
<number>0</number>
</property>
Modified: trunk/qgis/src/ui/qgsfieldcalculatorbase.ui
--- trunk/qgis/src/ui/qgsfieldcalculatorbase.ui 2009-12-05 17:03:44 UTC (rev 12338)
+++ trunk/qgis/src/ui/qgsfieldcalculatorbase.ui 2009-12-05 17:04:44 UTC (rev 12339)
@@ -135,7 +135,7 @@
<string>Operators</string>
</property>
<widget class="QPushButton" name="mPlusPushButton">
Modified: trunk/qgis/src/ui/qgsprojectpropertiesbase.ui
--- trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-12-05 17:03:44 UTC (rev 12338)
+++ trunk/qgis/src/ui/qgsprojectpropertiesbase.ui 2009-12-05 17:04:44 UTC (rev 12339)
@@ -286,7 +286,7 @@
<string>Digitizing</string>
</property>
<widget class="QCheckBox" name="mEnableTopologicalEditingCheckBox">
Modified: trunk/qgis/src/ui/symbollayer/widget_simpleline.ui
--- trunk/qgis/src/ui/symbollayer/widget_simpleline.ui 2009-12-05 17:03:44 UTC (rev 12338)
+++ trunk/qgis/src/ui/symbollayer/widget_simpleline.ui 2009-12-05 17:04:44 UTC (rev 12339)
@@ -124,7 +124,7 @@
</spacer>
</item>
<item>
<widget class="QLabel" name="label_5">
