[QGIS Commit] r12347 - trunk/qgis/python/core
svn_qgis at osgeo.org
Sun Dec 6 19:36:58 EST 2009
Author: jef
Date: 2009-12-06 19:36:57 -0500 (Sun, 06 Dec 2009)
New Revision: 12347
trunk/qgis/python/core/qgsvectorlayer.sip
trunk/qgis/python/core/symbology-ng-core.sip
missed the python part
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip 2009-12-06 23:26:22 UTC (rev 12346)
+++ trunk/qgis/python/core/qgsvectorlayer.sip 2009-12-07 00:36:57 UTC (rev 12347)
@@ -498,6 +498,11 @@
virtual void updateExtents();
+ /** Returns the index of a field name or -1 if the field does not exist
+ @note this method was added in version 1.4
+ int fieldNameIndex( const QString& fieldName ) const;
signals:
/** This signal is emited when selection was changed */
Modified: trunk/qgis/python/core/symbology-ng-core.sip
--- trunk/qgis/python/core/symbology-ng-core.sip 2009-12-06 23:26:22 UTC (rev 12346)
+++ trunk/qgis/python/core/symbology-ng-core.sip 2009-12-07 00:36:57 UTC (rev 12347)
@@ -41,18 +41,18 @@
QString type() const;
- virtual QgsSymbolV2* symbolForFeature(QgsFeature& feature)=0;
- virtual void startRender(QgsRenderContext& context, const QMap<int, QgsField>& fields)=0;
- virtual void stopRender(QgsRenderContext& context)=0;
+ virtual QgsSymbolV2* symbolForFeature(QgsFeature& feature)=0;
+ virtual void startRender(QgsRenderContext& context, const QgsVectorLayer * )=0;
+ virtual void stopRender(QgsRenderContext& context)=0;
virtual QList<QString> usedAttributes()=0;
- virtual ~QgsFeatureRendererV2();
- virtual QString dump();
+ virtual ~QgsFeatureRendererV2();
+ virtual QString dump();
virtual QgsFeatureRendererV2* clone()=0 /Factory/;
virtual QgsSymbolV2List symbols()=0;
@@ -85,17 +85,17 @@
%End
public:
- QgsSingleSymbolRendererV2(QgsSymbolV2* symbol /Transfer/);
- virtual ~QgsSingleSymbolRendererV2();
- virtual QgsSymbolV2* symbolForFeature(QgsFeature& feature);
- virtual void startRender(QgsRenderContext& context, const QMap<int, QgsField>& fields);
- virtual void stopRender(QgsRenderContext& context);
+ QgsSingleSymbolRendererV2(QgsSymbolV2* symbol /Transfer/);
+ virtual ~QgsSingleSymbolRendererV2();
+ virtual QgsSymbolV2* symbolForFeature(QgsFeature& feature);
+ virtual void startRender(QgsRenderContext& context, const QgsVectorLayer * );
+ virtual void stopRender(QgsRenderContext& context);
virtual QList<QString> usedAttributes();
QgsSymbolV2* symbol() const;
@@ -125,21 +125,21 @@
%End
public:
//! takes ownership of symbol
QgsRendererCategoryV2(QVariant value, QgsSymbolV2* symbol /Transfer/, QString label);
QgsRendererCategoryV2(const QgsRendererCategoryV2& cat);
~QgsRendererCategoryV2();
QVariant value() const;
QgsSymbolV2* symbol();
QString label() const;
void setSymbol(QgsSymbolV2* s /Transfer/);
void setLabel(QString label);
QString dump();
@@ -152,34 +152,34 @@
%End
public:
QgsCategorizedSymbolRendererV2(QString attrName = QString(), QgsCategoryList categories = QgsCategoryList());
- virtual ~QgsCategorizedSymbolRendererV2();
+ virtual ~QgsCategorizedSymbolRendererV2();
virtual QgsFeatureRendererV2* clone() /Factory/;
const QgsCategoryList& categories();
//! return index of category with specified value (-1 if not found)
int categoryIndexForValue(QVariant val);
bool updateCategorySymbol(int catIndex, QgsSymbolV2* symbol /Transfer/);
bool updateCategoryLabel(int catIndex, QString label);
bool deleteCategory(int catIndex);
void deleteAllCategories();
//! create a renderer from XML element
static QgsFeatureRendererV2* load(QDomElement& symbologyElem) /Factory/;
@@ -199,7 +199,7 @@
void setSourceColorRamp(QgsVectorColorRampV2* ramp /Transfer/);
protected:
QgsSymbolV2* symbolForValue(QVariant value);
@@ -244,7 +244,7 @@
@@ -319,30 +319,30 @@
public:
- virtual void setColor(const QColor& color);
- virtual QColor color() const;
- virtual ~QgsSymbolLayerV2();
- virtual QString layerType() const = 0;
- virtual void startRender(QgsRenderContext& context) = 0;
- virtual void stopRender(QgsRenderContext& context) = 0;
- virtual QgsSymbolLayerV2* clone() const = 0 /Factory/;
- virtual QgsStringMap properties() const = 0;
- virtual void drawPreviewIcon(QPainter* painter, QSize size) = 0;
- virtual QgsSymbolV2* subSymbol();
- virtual bool setSubSymbol(QgsSymbolV2* symbol /Transfer/);
+ virtual void setColor(const QColor& color);
+ virtual QColor color() const;
+ virtual ~QgsSymbolLayerV2();
+ virtual QString layerType() const = 0;
+ virtual void startRender(QgsRenderContext& context) = 0;
+ virtual void stopRender(QgsRenderContext& context) = 0;
+ virtual QgsSymbolLayerV2* clone() const = 0 /Factory/;
+ virtual QgsStringMap properties() const = 0;
+ virtual void drawPreviewIcon(QPainter* painter, QSize size) = 0;
+ virtual QgsSymbolV2* subSymbol();
+ virtual bool setSubSymbol(QgsSymbolV2* symbol /Transfer/);
QgsSymbolV2::SymbolType type() const;
void setLocked(bool locked);
- bool isLocked() const;
+ bool isLocked() const;
// used only with rending with symbol levels is turned on (0 = first pass, 1 = second, ...)
void setRenderingPass(int renderingPass);
@@ -350,7 +350,7 @@
protected:
QgsSymbolLayerV2(QgsSymbolV2::SymbolType type, bool locked = false);
@@ -363,18 +363,18 @@
public:
virtual void renderPoint(const QPointF& point, QgsRenderContext& context) = 0;
- void drawPreviewIcon(QPainter* painter, QSize size);
+ void drawPreviewIcon(QPainter* painter, QSize size);
void setAngle(double angle);
double angle() const;
void setSize(double size);
double size() const;
protected:
QgsMarkerSymbolLayerV2(bool locked = false);
class QgsLineSymbolLayerV2 : QgsSymbolLayerV2
@@ -385,12 +385,12 @@
public:
virtual void renderPolyline(const QPolygonF& points, QgsRenderContext& context) = 0;
void setWidth(double width);
double width() const;
protected:
QgsLineSymbolLayerV2(bool locked = false);
@@ -404,9 +404,9 @@
public:
virtual void renderPolygon(const QPolygonF& points, QList<QPolygonF>* rings, QgsRenderContext& context) = 0;
protected:
QgsFillSymbolLayerV2(bool locked = false);
@@ -434,60 +434,60 @@
%End
public:
- enum SymbolType
- Marker,
- Line,
- Fill
+ enum SymbolType
+ Marker,
+ Line,
+ Fill
virtual ~QgsSymbolV2();
//! return new default symbol for specified geometry type
static QgsSymbolV2* defaultSymbol(QGis::GeometryType geomType) /Factory/;
// symbol layers handling
QgsSymbolLayerV2* symbolLayer(int layer);
int symbolLayerCount();
//! insert symbol layer to specified index
bool insertSymbolLayer(int index, QgsSymbolLayerV2* layer /Transfer/);
//! append symbol layer at the end of the list
bool appendSymbolLayer(QgsSymbolLayerV2* layer /Transfer/);
//! delete symbol layer at specified index
bool deleteSymbolLayer(int index);
//! remove symbol layer from the list and return pointer to it
QgsSymbolLayerV2* takeSymbolLayer(int index) /TransferBack/;
//! delete layer at specified index and set a new one
bool changeSymbolLayer(int index, QgsSymbolLayerV2* layer /Transfer/);
- void startRender(QgsRenderContext& context);
- void stopRender(QgsRenderContext& context);
- void setColor(const QColor& color);
- QColor color();
+ void startRender(QgsRenderContext& context);
+ void stopRender(QgsRenderContext& context);
+ void setColor(const QColor& color);
+ QColor color();
QImage bigSymbolPreviewImage();
- QString dump();
+ QString dump();
virtual QgsSymbolV2* clone() const = 0 /Factory/;
protected:
QgsSymbolV2(SymbolType type, QgsSymbolLayerV2List layers /Transfer/); // can't be instantiated
@@ -500,14 +500,14 @@
%End
public:
- QgsMarkerSymbolV2(QgsSymbolLayerV2List layers /Transfer/ = QgsSymbolLayerV2List());
- void setAngle(double angle);
- double angle();
- void setSize(double size);
- double size();
+ QgsMarkerSymbolV2(QgsSymbolLayerV2List layers /Transfer/ = QgsSymbolLayerV2List());
+ void setAngle(double angle);
+ double angle();
+ void setSize(double size);
+ double size();
void renderPoint(const QPointF& point, QgsRenderContext& context, int layer = -1);
virtual QgsSymbolV2* clone() const /Factory/;
@@ -522,13 +522,13 @@
%End
public:
- QgsLineSymbolV2(QgsSymbolLayerV2List layers /Transfer/ = QgsSymbolLayerV2List());
+ QgsLineSymbolV2(QgsSymbolLayerV2List layers /Transfer/ = QgsSymbolLayerV2List());
double width();
void renderPolyline(const QPolygonF& points, QgsRenderContext& context, int layer = -1);
@@ -541,8 +541,8 @@
%End
public:
- QgsFillSymbolV2(QgsSymbolLayerV2List layers /Transfer/ = QgsSymbolLayerV2List());
+ QgsFillSymbolV2(QgsSymbolLayerV2List layers /Transfer/ = QgsSymbolLayerV2List());
void renderPolygon(const QPolygonF& points, QList<QPolygonF>* rings, QgsRenderContext& context, int layer = -1);
@@ -561,20 +561,20 @@
%End
public:
- /** construct invalid metadata */
- QgsSymbolLayerV2Metadata();
- /** construct metadata */
- // TODO
- //QgsSymbolLayerV2Metadata(QString name, QgsSymbolV2::SymbolType type,
+ /** construct invalid metadata */
+ QgsSymbolLayerV2Metadata();
+ /** construct metadata */
+ // TODO
+ //QgsSymbolLayerV2Metadata(QString name, QgsSymbolV2::SymbolType type,
// QgsSymbolLayerV2CreateFunc pfCreate,
// QgsSymbolLayerV2WidgetFunc pfWidget);
- QString name() const;
- QgsSymbolV2::SymbolType type();
- // TODO QgsSymbolLayerV2CreateFunc createFunction() const { return mCreateFunc; }
- // TODO QgsSymbolLayerV2WidgetFunc widgetFunction() const { return mWidgetFunc; }
+ QString name() const;
+ QgsSymbolV2::SymbolType type();
+ // TODO QgsSymbolLayerV2CreateFunc createFunction() const { return mCreateFunc; }
+ // TODO QgsSymbolLayerV2WidgetFunc widgetFunction() const { return mWidgetFunc; }
@@ -586,28 +586,28 @@
%End
public:
//! return the single instance of this class (instantiate it if not exists)
- static QgsSymbolLayerV2Registry* instance();
+ static QgsSymbolLayerV2Registry* instance();
//! return metadata for specified symbol layer
- QgsSymbolLayerV2Metadata symbolLayerMetadata(QString name) const;
+ QgsSymbolLayerV2Metadata symbolLayerMetadata(QString name) const;
//! register a new symbol layer type
- void addSymbolLayerType(const QgsSymbolLayerV2Metadata& metadata);
+ void addSymbolLayerType(const QgsSymbolLayerV2Metadata& metadata);
//! create a new instance of symbol layer given symbol layer name and properties
- QgsSymbolLayerV2* createSymbolLayer(QString name, const QgsStringMap& properties) const /Factory/;
+ QgsSymbolLayerV2* createSymbolLayer(QString name, const QgsStringMap& properties) const /Factory/;
//! return a list of available symbol layers for a specified symbol type
QStringList symbolLayersForType(QgsSymbolV2::SymbolType type);
//! create a new instance of symbol layer for specified symbol type with default settings
- static QgsSymbolLayerV2* defaultSymbolLayer(QgsSymbolV2::SymbolType type) /Factory/;
+ static QgsSymbolLayerV2* defaultSymbolLayer(QgsSymbolV2::SymbolType type) /Factory/;
protected:
- QgsSymbolLayerV2Registry();
+ QgsSymbolLayerV2Registry();
@@ -619,60 +619,60 @@
%End
public:
QgsStyleV2();
~QgsStyleV2();
//! return default application-wide style
static QgsStyleV2* defaultStyle();
//! remove all contents of the style
void clear();
//! add symbol to style. takes symbol's ownership
bool addSymbol(QString name, QgsSymbolV2* symbol);
//! remove symbol from style (and delete it)
bool removeSymbol(QString name);
//! return a NEW copy of symbol
QgsSymbolV2* symbol(QString name);
//! return a const pointer to a symbol (doesn't create new instance)
const QgsSymbolV2* symbolRef(QString name) const;
//! return count of symbols in style
int symbolCount();
//! return a list of names of symbols
QStringList symbolNames();
//! add color ramp to style. takes ramp's ownership
bool addColorRamp(QString name, QgsVectorColorRampV2* colorRamp);
//! remove color ramp from style (and delete it)
bool removeColorRamp(QString name);
//! return a NEW copy of color ramp
QgsVectorColorRampV2* colorRamp(QString name);
const QgsVectorColorRampV2* colorRampRef(QString name) const;
//! return count of color ramps
int colorRampCount();
//! return a list of names of color ramps
QStringList colorRampNames();
//! load a file into the style
bool load(QString filename);
//! save style into a file (will use current filename if empty string is passed)
bool save(QString filename = QString());
//! return last error from load/save operation
QString errorString();
@@ -691,13 +691,13 @@
public:
virtual ~QgsVectorColorRampV2();
virtual QColor color(double value) const = 0;
virtual QString type() const = 0;
virtual QgsVectorColorRampV2* clone() const = 0;
