[QGIS Commit] r12349 - in trunk/qgis: python/core src/app src/core src/plugins/north_arrow
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Dec 7 09:22:37 EST 2009
Author: wonder
Date: 2009-12-07 09:22:37 -0500 (Mon, 07 Dec 2009)
New Revision: 12349
   trunk/qgis/python/core/qgsproject.sip
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/core/qgsexception.h
   trunk/qgis/src/core/qgsproject.cpp
   trunk/qgis/src/core/qgsproject.h
   trunk/qgis/src/plugins/north_arrow/plugin.cpp
Removed QgsIOException. From now if QgsProject's read() and write() functions return false, it's possible to find out the error message using error() function.
Modified: trunk/qgis/python/core/qgsproject.sip
--- trunk/qgis/python/core/qgsproject.sip	2009-12-07 10:43:06 UTC (rev 12348)
+++ trunk/qgis/python/core/qgsproject.sip	2009-12-07 14:22:37 UTC (rev 12349)
@@ -231,6 +231,20 @@
       @note added in 1.3 */
     QString readPath( QString filename ) const;
+    /** Return error message from previous read/write
+      @note added in 1.4 */
+    QString error() const;
+  protected:
+    /** Set error message from read/write operation
+    void setError( QString errorMessage );
+    /** Clear error message
+    void clearError();
   signals:
     //! emitted when project is being read
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2009-12-07 10:43:06 UTC (rev 12348)
+++ trunk/qgis/src/app/qgisapp.cpp	2009-12-07 14:22:37 UTC (rev 12349)
@@ -3370,6 +3370,9 @@
       if ( ! QgsProject::instance()->read() )
+        QMessageBox::critical( this,
+                               tr( "QGIS Project Read Error" ),
+                               QgsProject::instance()->error() );
         mMapCanvas->freeze( false );
         mMapCanvas->refresh();
         return;
@@ -3389,16 +3392,6 @@
       // Tell the legend to update the ordering
       mMapLegend->readProject( e.document() );
-    catch ( std::exception & e )
-      QMessageBox::critical( this,
-                             tr( "QGIS Project Read Error" ),
-                             QString::fromLocal8Bit( e.what() ) );
-      QgsDebugMsg( "BAD QgsMapLayer::LayerType FOUND" );
-      mMapCanvas->freeze( false );
-      mMapCanvas->refresh();
-      return;
     setTitleBarText_( *this );
     emit projectRead();     // let plug-ins know that we've read in a new
@@ -3436,6 +3429,12 @@
     if ( ! QgsProject::instance()->read( projectFile ) )
+                             tr( "Unable to open project" ),
+      QApplication::restoreOverrideCursor();
       return false;
@@ -3468,21 +3467,7 @@
     // Continue after last catch statement
-                           tr( "Unable to open project" ),
-    QApplication::restoreOverrideCursor();
-    return false;
   // Continue, now with layers found (hopefully)
@@ -3569,33 +3554,23 @@
     QgsProject::instance()->setFileName( fullPath.filePath() );
-  try
+  if ( QgsProject::instance()->write() )
-    if ( QgsProject::instance()->write() )
-      setTitleBarText_( *this ); // update title bar
-      statusBar()->showMessage( tr( "Saved project to: %1" ).arg( QgsProject::instance()->fileName() ) );
+    setTitleBarText_( *this ); // update title bar
+    statusBar()->showMessage( tr( "Saved project to: %1" ).arg( QgsProject::instance()->fileName() ) );
-      if ( isNewProject )
-        // add this to the list of recently used project files
-        QSettings settings;
-        saveRecentProjectPath( fullPath.filePath(), settings );
-    else
+    if ( isNewProject )
-                             tr( "Unable to save project" ),
-                             tr( "Unable to save project to %1" ).arg( QgsProject::instance()->fileName() ) );
-      return false;
+      // add this to the list of recently used project files
+      QSettings settings;
+      saveRecentProjectPath( fullPath.filePath(), settings );
+  else
                            tr( "Unable to save project %1" ).arg( QgsProject::instance()->fileName() ),
     return false;
   return true;
@@ -3628,29 +3603,20 @@
     saveFilePath = myFI.filePath() + ".qgs";
-  try
-    QgsProject::instance()->setFileName( saveFilePath );
+  QgsProject::instance()->setFileName( saveFilePath );
-      saveRecentProjectPath( saveFilePath, settings );
-    else
+    saveRecentProjectPath( saveFilePath, settings );
+  else
-    QMessageBox::critical( 0x0,
-                           QString::fromLocal8Bit( e.what() ),
+                           QgsProject::instance()->error(),
                            QMessageBox::Ok,
                            Qt::NoButton );
@@ -3693,20 +3659,8 @@
   // possibly save any pending work before opening a different project
   if ( saveDirty() )
-    try
-      if ( ! addProject( fileName ) )
-        QgsDebugMsg( "unable to load project " + fileName );
-    catch ( QgsIOException & io_exception )
-      Q_UNUSED( io_exception );
-                             tr( "QGIS: Unable to load project" ),
-                             tr( "Unable to load project %1" ).arg( fileName ) );
+    // error handling and reporting is in addProject() function
+    addProject( fileName );
   return ;
Modified: trunk/qgis/src/core/qgsexception.h
--- trunk/qgis/src/core/qgsexception.h	2009-12-07 10:43:06 UTC (rev 12348)
+++ trunk/qgis/src/core/qgsexception.h	2009-12-07 14:22:37 UTC (rev 12349)
@@ -56,27 +56,7 @@
 }; // class QgsException
-/** for Qgis I/O related exceptions
-  @note usually thrown for opening file's that don't exist, and the like.
-class QgsIOException : public QgsException
-  public:
-    QgsIOException( std::string const & what )
-        : QgsException( what )
-    QgsIOException( QString const & what )
-}; // class QgsIOException
 /** for files missing from layers while reading project files
Modified: trunk/qgis/src/core/qgsproject.cpp
--- trunk/qgis/src/core/qgsproject.cpp	2009-12-07 10:43:06 UTC (rev 12348)
+++ trunk/qgis/src/core/qgsproject.cpp	2009-12-07 14:22:37 UTC (rev 12349)
@@ -747,6 +747,8 @@
 bool QgsProject::read()
+  clearError();
   std::auto_ptr< QDomDocument > doc =
     std::auto_ptr < QDomDocument > ( new QDomDocument( "qgis" ) );
@@ -755,7 +757,8 @@
     imp_->file.close();     // even though we got an error, let's make
     // sure it's closed anyway
-    throw QgsIOException( tr( "Unable to open %1" ).arg( imp_->file.fileName() ) );
+    setError( tr( "Unable to open %1" ).arg( imp_->file.fileName() ) );
+    return false;
   // location of problem associated with errorMsg
@@ -776,7 +779,8 @@
     imp_->file.close();
-    throw QgsException( tr( "%1 for file %2" ).arg( errorString ).arg( imp_->file.fileName() ) );
+    setError( tr( "%1 for file %2" ).arg( errorString ).arg( imp_->file.fileName() ) );
+    return false;
   imp_->file.close();
@@ -922,6 +926,8 @@
 bool QgsProject::write()
+  clearError();
   // if we have problems creating or otherwise writing to the project file,
   // let's find out up front before we go through all the hand-waving
   // necessary to create all the Dom objects
@@ -930,7 +936,8 @@
-    throw QgsIOException( tr( "Unable to save to file %1" ).arg( imp_->file.fileName() ) );
+    setError( tr( "Unable to save to file %1" ).arg( imp_->file.fileName() ) );
+    return false;
   QFileInfo myFileInfo( imp_->file );
   if ( !myFileInfo.isWritable() )
@@ -938,8 +945,9 @@
     imp_->file.close();
-    throw QgsIOException( tr( "%1 is not writeable. Please adjust permissions (if possible) and try again." )
-                          .arg( imp_->file.fileName() ) );
+    setError( tr( "%1 is not writeable. Please adjust permissions (if possible) and try again." )
+              .arg( imp_->file.fileName() ) );
+    return false;
   QDomImplementation DomImplementation;
@@ -1023,10 +1031,11 @@
   if ( projectFileStream.pos() == -1  || imp_->file.error() != QFile::NoError )
-    throw QgsIOException( tr( "Unable to save to file %1. Your project "
-                              "may be corrupted on disk. Try clearing some space on the volume and "
-                              "check file permissions before pressing save again." )
+    setError( tr( "Unable to save to file %1. Your project "
+                  "may be corrupted on disk. Try clearing some space on the volume and "
+                  "check file permissions before pressing save again." )
+    return false;
   dirty( false );               // reset to pristine state
@@ -1456,3 +1465,18 @@
   return srcElems.join( "/" );
+void QgsProject::setError( QString errorMessage )
+  mErrorMessage = errorMessage;
+QString QgsProject::error() const
+  return mErrorMessage;
+void QgsProject::clearError()
+  setError( QString() );
Modified: trunk/qgis/src/core/qgsproject.h
--- trunk/qgis/src/core/qgsproject.h	2009-12-07 10:43:06 UTC (rev 12348)
+++ trunk/qgis/src/core/qgsproject.h	2009-12-07 14:22:37 UTC (rev 12349)
@@ -264,6 +264,20 @@
+  protected:
   signals:
@@ -295,6 +309,8 @@
     std::pair< bool, std::list<QDomNode> > _getMapLayers( QDomDocument const &doc );
+    QString mErrorMessage;
 }; // QgsProject
 #endif
Modified: trunk/qgis/src/plugins/north_arrow/plugin.cpp
--- trunk/qgis/src/plugins/north_arrow/plugin.cpp	2009-12-07 10:43:06 UTC (rev 12348)
+++ trunk/qgis/src/plugins/north_arrow/plugin.cpp	2009-12-07 14:22:37 UTC (rev 12349)
@@ -325,7 +325,7 @@
         p1 = transform.transform( p1 );
         p2 = transform.transform( p2 );
-      catch ( QgsException &e )
+      catch ( QgsCsException &e )
         Q_UNUSED( e );
         // just give up
More information about the QGIS-commit mailing list
