[QGIS Commit] r12382 - trunk/qgis/src/plugins/gps_importer
svn_qgis at osgeo.org
Wed Dec 9 05:26:55 EST 2009
Author: borysiasty
Date: 2009-12-09 05:26:52 -0500 (Wed, 09 Dec 2009)
New Revision: 12382
trunk/qgis/src/plugins/gps_importer/qgsgpsdevicedialogbase.ui
revert a string accidentally changed in r12374
Modified: trunk/qgis/src/plugins/gps_importer/qgsgpsdevicedialogbase.ui
--- trunk/qgis/src/plugins/gps_importer/qgsgpsdevicedialogbase.ui 2009-12-09 10:26:04 UTC (rev 12381)
+++ trunk/qgis/src/plugins/gps_importer/qgsgpsdevicedialogbase.ui 2009-12-09 10:26:52 UTC (rev 12382)
@@ -269,11 +269,11 @@
<bool>true</bool>
</property>
<property name="html">
- <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
-<html><head><meta name="qrichtext" content="1" /><style type="text/css">
+ <string><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
+<html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
-</style></head><body style=" font-family:'DejaVu Sans'; font-size:8pt; font-weight:400; font-style:normal;">
-<p style=" margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-family:'Sans Serif'; font-size:9pt;">In the download and upload commands there can be special words that will be replaced by QGIS when the commands are used. These words are:</span><span style=" font-family:'Sans Serif'; font-size:9pt; font-style:italic;">%babel</span><span style=" font-family:'Sans Serif'; font-size:9pt;"> - the path to GPSBabel<br /></span><span style=" font-family:'Sans Serif'; font-size:9pt; font-style:italic;">%in</span><span style=" font-family:'Sans Serif'; font-size:9pt;"> - the GPX filename when uploading or the port when downloading<br /></span><span style=" font-family:'Sans Serif'; font-size:9pt; font-style:italic;">%out</span><span style=" font-family:'Sans Serif'; font-size:9pt;"> - the port when uploading or the GPX filename when downloading</span></p></body></html></string>
+</style></head><body style=" font-family:'MS Shell Dlg 2'; font-size:8.25pt; font-weight:400; font-style:normal;">
+<p style=" margin-top:12px; margin-bottom:12px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"><span style=" font-family:'Sans Serif'; font-size:9pt;">In the download and upload commands there can be special words that will be replaced by QGIS when the commands are used. These words are:</span><span style=" font-family:'Sans Serif'; font-size:9pt; font-style:italic;">%babel</span><span style=" font-family:'Sans Serif'; font-size:9pt;"> - the path to GPSBabel<br /></span><span style=" font-family:'Sans Serif'; font-size:9pt; font-style:italic;">%in</span><span style=" font-family:'Sans Serif'; font-size:9pt;"> - the GPX filename when uploading or the port when downloading<br /></span><span style=" font-family:'Sans Serif'; font-size:9pt; font-style:italic;">%out</span><span style=" font-family:'Sans Serif'; font-size:9pt;"> - the port when uploading or the GPX filename when downloading</span></p></body></html></string>
</property>
<property name="textInteractionFlags">
<set>Qt::NoTextInteraction</set>
