[QGIS Commit] r12388 - docs/branches/1.3.0/french/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Dec 9 14:26:42 EST 2009
Author: jrm
Date: 2009-12-09 14:26:41 -0500 (Wed, 09 Dec 2009)
New Revision: 12388
   docs/branches/1.3.0/french/user_guide/plugins_coordinate_capture.tex
proofreaded by Jean Roc
Modified: docs/branches/1.3.0/french/user_guide/plugins_coordinate_capture.tex
--- docs/branches/1.3.0/french/user_guide/plugins_coordinate_capture.tex	2009-12-09 18:08:00 UTC (rev 12387)
+++ docs/branches/1.3.0/french/user_guide/plugins_coordinate_capture.tex	2009-12-09 19:26:41 UTC (rev 12388)
@@ -1,43 +1,78 @@
 % vim: set textwidth=78 autoindent:
-\subsection{Coordinate Capture Plugin}
+%\subsection{Coordinate Capture Plugin}
+\subsection{Extension Saisie de Coordonnées}
 % when the revision of a section has been finalized,
 % comment out the following line:
 % \updatedisclaimer
-The coordinate capture plugin is easy to use and provides the
-ability to display coordinates on the map canvas for two
-selected Coordinate Reference Systems (CRS).
+%The coordinate capture plugin is easy to use and provides the
+%ability to display coordinates on the map canvas for two
+%selected Coordinate Reference Systems (CRS).
+L'extension Saisie de Coordonnées est simple d'utilisation et offre la
+possibilité d'afficher des coordonnées sur la carte en sélectionnant deux
+Systèmes de Coordonnées de Référence (SCR) différents.
+%\begin{figure}[ht]
+%   \begin{center}
+%   \caption{Coordinate Cature Plugin \nixcaption}\label{fig:coordinate_capture_dialog}\smallskip
+%   \includegraphics[clip=true, width=9cm]{coordinate_capture_dialog}
+%\end{center}
+%\end{figure}
 \begin{figure}[ht]
    \begin{center}
-   \caption{Coordinate Cature Plugin \nixcaption}\label{fig:coordinate_capture_dialog}\smallskip
+   \caption{L'extension Saisie de Coordonnées \nixcaption}\label{fig:coordinate_capture_dialog}\smallskip
 \end{center}
 \end{figure}
+%\begin{enumerate}
+%  \item Start QGIS, select \dropmenuopttwo{mActionOptions}{Project Properties} from
+%  the \mainmenuopt{Settings} (KDE, Windows) or \mainmenuopt{File} (Gnome, OSX) menu
+%  and click on the \tab{Projection} tab. As an alternative you
+%  you can also click on the \toolbtntwo{mIconProjectionEnabled}{projector} icon in the lower
+%  right-hand corner of the statusbar.
+%  \item Click on the \checkbox{Enable on the fly projection} checkbox and select a projected
+%  coordinate system of your choice (see also Section \ref{label_projections}).
+%  \item Load the coordinate capture plugin in the Plugin Manager (see Section
+%  \ref{sec:load_core_plugin}) and ensure that the dialog is visible by going to \mainmenuopt{View}
+%   > \dropmenuopt{Panels} and ensuring that \checkbox{Coordinate Capture} is enabled.
+%   The cordinate capture dialog appears as shown in Figure \ref{fig:coordinate_capture_dialog}.
+%  \item Click on the \toolbtntwo{geographic}{Click to the select the CRS to use for coordinate display}
+%  icon and select a different CRS from the one you selected above.
+%  \item To start capturing coordinates, click on \button{Start capture}. You can now click anywhere
+%  on the map canvas and the plugin will show the coordinates for both of your selected CRS.
+%  \item To enable mouse coordinate tracking click the \toolbtntwo{tracking}{mouse tracking} icon.
+%  \item You can also copy selected coordinates to the clipboard.
+%\end{enumerate}
 \begin{enumerate}
-  \item Start QGIS, select \dropmenuopttwo{mActionOptions}{Project Properties} from
-  the \mainmenuopt{Settings} (KDE, Windows) or \mainmenuopt{File} (Gnome, OSX) menu
-  and click on the \tab{Projection} tab. As an alternative you
-  you can also click on the \toolbtntwo{mIconProjectionEnabled}{projector} icon in the lower
-  right-hand corner of the statusbar.
-  \item Click on the \checkbox{Enable on the fly projection} checkbox and select a projected
-  coordinate system of your choice (see also Section \ref{label_projections}).
-  \item Load the coordinate capture plugin in the Plugin Manager (see Section
-  \ref{sec:load_core_plugin}) and ensure that the dialog is visible by going to \mainmenuopt{View}
-   > \dropmenuopt{Panels} and ensuring that \checkbox{Coordinate Capture} is enabled.
-   The cordinate capture dialog appears as shown in Figure \ref{fig:coordinate_capture_dialog}.
-  \item Click on the \toolbtntwo{geographic}{Click to the select the CRS to use for coordinate display}
-  icon and select a different CRS from the one you selected above.
-  \item To start capturing coordinates, click on \button{Start capture}. You can now click anywhere
-  on the map canvas and the plugin will show the coordinates for both of your selected CRS.
-  \item To enable mouse coordinate tracking click the \toolbtntwo{tracking}{mouse tracking} icon.
-  \item You can also copy selected coordinates to the clipboard.
+  \item Démarrez QGIS, sélectionnez \dropmenuopttwo{mActionOptions}{Propriétés du  Projet} dans le menu
+  \mainmenuopt{Préférences} (KDE, Windows) ou \mainmenuopt{Fichier} (Gnome, OSX)
+  et appuyez sur l'onglet \tab{Système de coordonnées de référence (SCR)}.
+  Vous pouvez également appuyer sur l'icône \toolbtntwo{mIconProjectionEnabled}{Statut de la projection}
+  située dans l'angle inférieur droit de la barre de statut.
+  \item Cochez l'option \checkbox{Autoriser la projection 'à la volée'} et
+  sélectionnez le système de coordonnées de votre choix (voir également
+  la Section \ref{label_projections}).
+  \item Chargez l'extension Saisie de Coordonnées depuis le Gestionnaire
+  d'Extension (voir la Section \ref{sec:load_core_plugin}) puis assurez-vous
+  que l'extension est activée en allant dans \mainmenuopt{Vue} > \dropmenuopt{Panneaux}
+  pour vérifier que la fonction \checkbox{Saisie de Coordonnées} est cochée.
+   La fenêtre Saisie de Coordonnées apparaît alors comme indiqué dans
+  la Figure \ref{fig:coordinate_capture_dialog}.
+  \item Appuyez sur l'icône \toolbtntwo{geographic}{Cliquez pour sélectionner le SCR à utiliser pour l'affichage des coordonnées}
+  et sélectionnez un SCR différent de celui que vous avez choisi plus haut.
+  \item Pour lancer la capture de coordonnées, appuyez sur \button{Débuter la capture}.
+  Vous pouvez maintenant cliquer n'importe où sur la carte et l'extension
+  affichera les coordonnées dans chacun des deux SCR sélectionnés.
+  \item Pour activer le suivi des coordonnées par le curseur appuyez sur
+  l'icône \toolbtntwo{tracking}{Suivi du curseur}.
+  \item Vous pouvez également copier les coordonnés dans le presse-papiers.
 \end{enumerate}
 \newpage
More information about the QGIS-commit mailing list
