[QGIS Commit] r12405 - in trunk/qgis/src: app core
svn_qgis at osgeo.org
Fri Dec 11 05:27:14 EST 2009
Author: jef
Date: 2009-12-11 05:27:14 -0500 (Fri, 11 Dec 2009)
New Revision: 12405
trunk/qgis/src/app/qgsidentifyresults.cpp
trunk/qgis/src/core/qgsmaplayer.cpp
trunk/qgis/src/core/qgsmaplayer.h
fix #2255
Modified: trunk/qgis/src/app/qgsidentifyresults.cpp
--- trunk/qgis/src/app/qgsidentifyresults.cpp 2009-12-11 10:25:43 UTC (rev 12404)
+++ trunk/qgis/src/app/qgsidentifyresults.cpp 2009-12-11 10:27:14 UTC (rev 12405)
@@ -159,6 +159,7 @@
if ( vlayer )
connect( vlayer, SIGNAL( layerDeleted() ), this, SLOT( layerDestroyed() ) );
+ connect( vlayer, SIGNAL( layerCrsChanged() ), this, SLOT( layerDestroyed() ) );
connect( vlayer, SIGNAL( featureDeleted( int ) ), this, SLOT( featureDeleted( int ) ) );
connect( vlayer, SIGNAL( editingStarted() ), this, SLOT( editingToggled() ) );
connect( vlayer, SIGNAL( editingStopped() ), this, SLOT( editingToggled() ) );
@@ -166,6 +167,7 @@
else
connect( layer, SIGNAL( destroyed() ), this, SLOT( layerDestroyed() ) );
+ connect( layer, SIGNAL( layerCrsChanged() ), this, SLOT( layerDestroyed() ) );
Modified: trunk/qgis/src/core/qgsmaplayer.cpp
--- trunk/qgis/src/core/qgsmaplayer.cpp 2009-12-11 10:25:43 UTC (rev 12404)
+++ trunk/qgis/src/core/qgsmaplayer.cpp 2009-12-11 10:27:14 UTC (rev 12405)
@@ -440,9 +440,11 @@
return *mCRS;
-void QgsMapLayer::setCrs( const QgsCoordinateReferenceSystem& srs )
+void QgsMapLayer::setCrs( const QgsCoordinateReferenceSystem& srs, bool emitSignal )
*mCRS = srs;
+ if ( emitSignal )
+ emit layerCrsChanged();
unsigned int QgsMapLayer::getTransparency()
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h 2009-12-11 10:25:43 UTC (rev 12404)
+++ trunk/qgis/src/core/qgsmaplayer.h 2009-12-11 10:27:14 UTC (rev 12405)
@@ -211,8 +211,9 @@
const QgsCoordinateReferenceSystem& srs();
- /** Sets layer's spatial reference system */
- void setCrs( const QgsCoordinateReferenceSystem& srs );
+ /** Sets layer's spatial reference system
+ @note emitSignal added in 1.4 */
+ void setCrs( const QgsCoordinateReferenceSystem& srs, bool emitSignal = true );
/** A convenience function to capitalise the layer name */
@@ -320,9 +321,14 @@
/** Emit a signal with status (e.g. to be caught by QgisApp and display a msg on status bar) */
void statusChanged( QString theStatus );
- /** Emit a signal that layer name has been changed */
+ /** Emit a signal that the layer name has been changed */
void layerNameChanged();
+ /** Emit a signal that layer's CRS has been reset
+ added in 1.4
+ void layerCrsChanged();
/** This signal should be connected with the slot QgsMapCanvas::refresh()
* @TODO: to be removed - GUI dependency
