[QGIS Commit] r12415 - in trunk/qgis/src: app/composer ui
svn_qgis at osgeo.org
Fri Dec 11 17:40:16 EST 2009
Author: jef
Date: 2009-12-11 17:40:15 -0500 (Fri, 11 Dec 2009)
New Revision: 12415
trunk/qgis/src/app/composer/qgscomposer.h
trunk/qgis/src/ui/qgscomposerbase.ui
fix #2240
Modified: trunk/qgis/src/app/composer/qgscomposer.h
--- trunk/qgis/src/app/composer/qgscomposer.h 2009-12-11 22:17:54 UTC (rev 12414)
+++ trunk/qgis/src/app/composer/qgscomposer.h 2009-12-11 22:40:15 UTC (rev 12415)
@@ -238,7 +238,7 @@
//! Raise, unminimize and activate this window
void activate();
- void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
+ void on_mButtonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
private:
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui 2009-12-11 22:17:54 UTC (rev 12414)
+++ trunk/qgis/src/ui/qgscomposerbase.ui 2009-12-11 22:40:15 UTC (rev 12415)
@@ -136,7 +136,7 @@
<item row="1" column="0">
<widget class="QDialogButtonBox" name="mButtonBox">
<property name="standardButtons">
- <set>QDialogButtonBox::Close</set>
+ <set>QDialogButtonBox::Close|QDialogButtonBox::Help</set>
</property>
</widget>
</item>
