[QGIS Commit] r12418 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org
Sat Dec 12 08:18:39 EST 2009
Author: jef
Date: 2009-12-12 08:18:38 -0500 (Sat, 12 Dec 2009)
New Revision: 12418
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.h
better fix for #2137
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-12-12 11:32:11 UTC (rev 12417)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2009-12-12 13:18:38 UTC (rev 12418)
@@ -24,8 +24,6 @@
#include <netinet/in.h>
#endif
-#include <cassert>
#include <qgis.h>
#include <qgsapplication.h>
#include <qgsfeature.h>
@@ -191,12 +189,12 @@
calculateExtents();
getFeatureCount();
+ // set the primary key
+ getPrimaryKey();
// load the field list
loadFields();
- // set the primary key
- getPrimaryKey();
// Set the postgresql message level so that we don't get the
// 'there is no transaction in progress' warning.
#ifndef QGISDEBUG
@@ -870,6 +868,9 @@
for ( int i = 0; i < PQnfields( result ); i++ )
QString fieldName = QString::fromUtf8( PQfname( result, i ) );
+ if ( fieldName == geometryColumn )
+ continue;
int fldtyp = PQftype( result, i );
QString typOid = QString().setNum( fldtyp );
int fieldModifier = PQfmod( result, i );
@@ -899,79 +900,76 @@
if ( PQntuples( tresult ) > 0 )
fieldComment = QString::fromUtf8( PQgetvalue( tresult, 0, 0 ) );
- if ( fieldName != geometryColumn )
+ QVariant::Type fieldType;
+ if ( fieldTType == "b" )
- QVariant::Type fieldType;
+ bool isArray = fieldTypeName.startsWith( "_" );
- if ( fieldTType == "b" )
+ if ( isArray )
+ fieldTypeName = fieldTypeName.mid( 1 );
+ if ( fieldTypeName == "int8" )
- bool isArray = fieldTypeName.startsWith( "_" );
- if ( isArray )
- fieldTypeName = fieldTypeName.mid( 1 );
- if ( fieldTypeName == "int8" )
- fieldType = QVariant::LongLong;
- fieldSize = -1;
- else if ( fieldTypeName.startsWith( "int" ) ||
- fieldTypeName == "serial" )
- fieldType = QVariant::Int;
- fieldSize = -1;
- else if ( fieldTypeName == "real" ||
- fieldTypeName == "double precision" ||
- fieldTypeName.startsWith( "float" ) ||
- fieldTypeName == "numeric" )
- fieldType = QVariant::Double;
- fieldSize = -1;
- else if ( fieldTypeName == "text" ||
- fieldTypeName == "bpchar" ||
- fieldTypeName == "varchar" ||
- fieldTypeName == "bool" ||
- fieldTypeName == "geometry" ||
- fieldTypeName == "money" ||
- fieldTypeName.startsWith( "time" ) ||
- fieldTypeName.startsWith( "date" ) )
- fieldType = QVariant::String;
- fieldSize = -1;
- else if ( fieldTypeName == "char" )
- else
- QgsDebugMsg( "Field " + fieldName + " ignored, because of unsupported type " + fieldTypeName );
- continue;
- if ( isArray )
- fieldTypeName = "_" + fieldTypeName;
- fieldSize = -1;
+ fieldType = QVariant::LongLong;
+ fieldSize = -1;
- else if ( fieldTType == "e" )
+ else if ( fieldTypeName.startsWith( "int" ) ||
+ fieldTypeName == "serial" )
- // enum
+ fieldType = QVariant::Int;
+ fieldSize = -1;
+ else if ( fieldTypeName == "real" ||
+ fieldTypeName == "double precision" ||
+ fieldTypeName.startsWith( "float" ) ||
+ fieldTypeName == "numeric" )
+ fieldType = QVariant::Double;
+ fieldSize = -1;
+ else if ( fieldTypeName == "text" ||
+ fieldTypeName == "bpchar" ||
+ fieldTypeName == "varchar" ||
+ fieldTypeName == "bool" ||
+ fieldTypeName == "geometry" ||
+ fieldTypeName == "money" ||
+ fieldTypeName.startsWith( "time" ) ||
+ fieldTypeName.startsWith( "date" ) )
fieldSize = -1;
+ else if ( fieldTypeName == "char" )
+ fieldType = QVariant::String;
else
- QgsDebugMsg( "Field " + fieldName + " ignored, because of unsupported type type " + fieldTType );
+ QgsDebugMsg( "Field " + fieldName + " ignored, because of unsupported type " + fieldTypeName );
continue;
- attributeFields.insert( i, QgsField( fieldName, fieldType, fieldTypeName, fieldSize, fieldModifier, fieldComment ) );
+ if ( isArray )
+ fieldTypeName = "_" + fieldTypeName;
+ fieldSize = -1;
+ else if ( fieldTType == "e" )
+ // enum
+ fieldSize = -1;
+ else
+ QgsDebugMsg( "Field " + fieldName + " ignored, because of unsupported type type " + fieldTType );
+ continue;
+ attributeFields.insert( i, QgsField( fieldName, fieldType, fieldTypeName, fieldSize, fieldModifier, fieldComment ) );
@@ -1064,6 +1062,17 @@
"primary key), has a PostgreSQL oid column or has a ctid\n"
"column with a 16bit block number.\n" ) );
+ else
+ primaryKeyDefault = defaultValue( primaryKey ).toString();
+ if ( primaryKeyDefault.isNull() )
+ primaryKeyDefault = QString( "max(%1)+1 from %2.%3" )
+ .arg( quotedIdentifier( primaryKey ) )
+ .arg( quotedIdentifier( mSchemaName ) )
+ .arg( quotedIdentifier( mTableName ) );
else if ( type == "v" ) // the relation is a view
@@ -1091,18 +1100,33 @@
+ // Have a poke around the view to see if any of the columns
+ // could be used as the primary key.
+ tableCols cols;
+ // Given a schema.view, populate the cols variable with the
+ // schema.table.column's that underly the view columns.
+ findColumns( cols );
if ( primaryKey.isEmpty() )
- // Have a poke around the view to see if any of the columns
- // could be used as the primary key.
- tableCols cols;
- // Given a schema.view, populate the cols variable with the
- // schema.table.column's that underly the view columns.
- findColumns( cols );
// From the view columns, choose one for which the underlying
// column is suitable for use as a key into the view.
primaryKey = chooseViewColumn( cols );
+ tableCols::const_iterator it = cols.find( primaryKey );
+ if ( it != cols.end() )
+ primaryKeyDefault = defaultValue( it->second.column, it->second.relation, it->second.schema ).toString();
+ .arg( quotedIdentifier( it->second.column ) )
+ .arg( quotedIdentifier( it->second.schema ) )
+ .arg( quotedIdentifier( it->second.relation ) );
else
QgsDebugMsg( "Unexpected relation type of '" + type + "'." );
@@ -1201,9 +1225,20 @@
valid = false;
showMessageBox( tr( "Unable to find a key column" ), log );
+ else
- if ( primaryKey.length() > 0 )
+ if ( !primaryKey.isNull() )
QgsDebugMsg( "Qgis row key is " + primaryKey );
@@ -1893,28 +1928,18 @@
-int QgsPostgresProvider::maxPrimaryKeyValue()
- QString sql;
- sql = QString( "select max(%1) from %2" )
- .arg( quotedIdentifier( primaryKey ) )
- .arg( mSchemaTableName );
- Result rmax = connectionRO->PQexec( sql );
- QString maxValue = QString::fromUtf8( PQgetvalue( rmax, 0, 0 ) );
- return maxValue.toInt();
bool QgsPostgresProvider::isValid()
return valid;
-QVariant QgsPostgresProvider::defaultValue( QString fieldName )
+QVariant QgsPostgresProvider::defaultValue( QString fieldName, QString tableName, QString schemaName )
+ if ( schemaName.isNull() )
+ schemaName = mSchemaName;
+ if ( tableName.isNull() )
+ tableName = mTableName;
// Get the default column value from the Postgres information
// schema. If there is no default we return an empty string.
@@ -1924,8 +1949,8 @@
QString sql( "SELECT column_default FROM"
" information_schema.columns WHERE"
" column_default IS NOT NULL"
- " AND table_schema = " + quotedValue( mSchemaName ) +
- " AND table_name = " + quotedValue( mTableName ) +
+ " AND table_schema = " + quotedValue( schemaName ) +
+ " AND table_name = " + quotedValue( tableName ) +
" AND column_name = " + quotedValue( fieldName ) );
QVariant defaultValue( QString::null );
@@ -1935,8 +1960,6 @@
if ( PQntuples( result ) == 1 && !PQgetisnull( result, 0, 0 ) )
defaultValue = QString::fromUtf8( PQgetvalue( result, 0, 0 ) );
- // QgsDebugMsg( QString("defaultValue for %1 is NULL: %2").arg(fieldId).arg( defaultValue.isNull() ) );
return defaultValue;
@@ -2084,7 +2107,6 @@
QStringList defaultValues;
QList<int> fieldId;
- int primaryKeyId = -1;
// look for unique attribute values to place in statement instead of passing as parameter
// e.g. for defaults
@@ -2098,15 +2120,9 @@
QgsDebugMsg( "Checking field against: " + fieldname );
- if ( fieldname.isEmpty() || fieldname == geometryColumn )
+ if ( fieldname.isEmpty() || fieldname == geometryColumn || fieldname == primaryKey )
continue;
- if ( fieldname == primaryKey )
- primaryKeyId = it.key();
- continue;
int i;
for ( i = 1; i < flist.size(); i++ )
@@ -2170,10 +2186,6 @@
throw PGException( stmt );
PQclear( stmt );
- QString keyDefault = defaultValue( primaryKey ).toString();
- int primaryKeyHighWater = -1;
- if ( keyDefault.isNull() )
- primaryKeyHighWater = maxPrimaryKeyValue();
QList<int> newIds;
for ( QgsFeatureList::iterator features = flist.begin(); features != flist.end(); features++ )
@@ -2188,19 +2200,9 @@
if ( primaryKeyType != "tid" )
- QByteArray key = paramValue( primaryKeyId >= 0 ? attributevec[ primaryKeyId ].toString() : QString::null, keyDefault );
- if ( key.isNull() )
- ++primaryKeyHighWater;
- params << QString::number( primaryKeyHighWater );
- newIds << primaryKeyHighWater;
- else
- params << key;
- newIds << key.toInt();
+ int id = paramValue( primaryKeyDefault, primaryKeyDefault ).toInt();
+ params << QString::number( id );
+ newIds << id;
for ( int i = 0; i < fieldId.size(); i++ )
@@ -3111,8 +3113,7 @@
message->showMessage();
-void QgsPostgresProvider::showMessageBox( const QString& title,
- const QStringList& text )
+void QgsPostgresProvider::showMessageBox( const QString& title, const QStringList& text )
showMessageBox( title, text.join( "\n" ) );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.h
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2009-12-12 11:32:11 UTC (rev 12417)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.h 2009-12-12 13:18:38 UTC (rev 12418)
@@ -205,7 +205,7 @@
QgsAttributeList attributeIndexes();
/**Returns the default value for field specified by @c fieldName */
- QVariant defaultValue( QString fieldName );
+ QVariant defaultValue( QString fieldName, QString tableName = QString::null, QString schemaName = QString::null );
/**Returns the default value for field specified by @c fieldId */
QVariant defaultValue( int fieldId );
@@ -409,6 +409,10 @@
QString primaryKey;
+ * Default value for primary key
+ QString primaryKeyDefault;
* Data type for the primary key
QString primaryKeyType;
@@ -560,13 +564,6 @@
int enabledCapabilities;
- /**Returns the maximum value of the primary key attribute
- @note You should run this inside of a PostgreSQL transaction
- so that you can safely increment the value returned for
- use in newly added features.
- int maxPrimaryKeyValue();
//! Get the feature count based on the where clause
long getFeatureCount();
