[QGIS Commit] r12444 - trunk/qgis/resources/context_help
svn_qgis at osgeo.org
Sun Dec 13 18:13:53 EST 2009
Author: jef
Date: 2009-12-13 18:13:52 -0500 (Sun, 13 Dec 2009)
New Revision: 12444
Added:
trunk/qgis/resources/context_help/QgsNewOgrConnection-de_DE
trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-de_DE
trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US
trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR
trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-ru_RU
trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-sk_SK
Removed:
trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-de_DE
trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-en_US
trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-fr_FR
trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-ru_RU
trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-sk_SK
rename context helps for QgsCreateNewVectorLayer to QgsNewVectorLayerDialog
Deleted: trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-de_DE
--- trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-de_DE 2009-12-13 22:57:18 UTC (rev 12443)
+++ trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-de_DE 2009-12-13 23:13:52 UTC (rev 12444)
@@ -1,2 +0,0 @@
-<h3>Einen neuen Vektorlayer erzeugen</h3>
Deleted: trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-en_US
--- trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-en_US 2009-12-13 22:57:18 UTC (rev 12443)
+++ trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-en_US 2009-12-13 23:13:52 UTC (rev 12444)
@@ -1,2 +0,0 @@
-<h3>Create New Vector Layer</h3>
Deleted: trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-fr_FR
--- trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-fr_FR 2009-12-13 22:57:18 UTC (rev 12443)
+++ trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-fr_FR 2009-12-13 23:13:52 UTC (rev 12444)
@@ -1,84 +0,0 @@
-<h3>Créer une nouvelle couche vectorielle</h3>
-QGIS offre la possibilité de créer une couche de données vectorielles
-possédant des attributs définis et configurés par l'utilisateur.<br>
-Pour l'instant, cette couche vectorielle ne peut être créée qu'au
-format ESRI shapefile (.shp), mais il possible d'utiliser séparément
-des outils comme OGR pour convertir cette couche dans un autre format.
-<p>Pour accéder à la boîte de dialogue de création de couche
-vectorielle, il existe trois possibilités:
-</p>
-<ul>
-<li>Sur la barre d'outils contrôle des couches de QGIS, appuyer sur
-le bouton <label>Nouvelle couche vectorielle</label>;
-</li>
-<li>ou dans le menu <label>Couche</label>, sélectionner la fonction <label>Nouvelle
-couche vectorielle...</label>;
-</li>
-<li>ou taper directement le raccourci clavier (<label>Shift+Ctrl+N</label>
-sous Mac OSX).
-</li>
-</ul>
-<h4>Configuration de la couche vectorielle</h4>
-<h5><u>Étape 1 : Choix du type</u></h5>
-Dans la boîte de dialogue <label>Nouvelle couche vecteur</label>, sélectionner
-le type de couche à créer en cochant le bouton souhaité:
-<ul>
-<li><label>Point</label> pour créer une couche contenant des objets de type
-ponctuels;
-</li>
-<li><label>Ligne</label> pour créer une couche contenant des objets de type
-linéaires;
-</li>
-<li><label>Polygone</label> pour créer une couche contenant des objets de
-type surfaciques.
-</li>
-</ul>
-<h5><u>Étape 2 : Création et configuration des Attributs de couche</u></h5>
-Quel que soit le type de couche choisi, la configuration des attributs
-de la couche se fait toujours de la même manière:
-<ol>
-<li>Entrer un nom pour l'attribut dans la case <label>Nom</label>;
-</li>
-<li>Choisir le type d'attribut à l'aide du menu déroulant <label>Type</label>
-: <br>
-<ul>
-<li><tab>Ligne (string) pour un attribut de type chaîne de
-caractère</tab></li>
-<li><tab>Entier (integer) pour un attribut de type nombres entiers</tab></li>
-<li><tab>Réel (real) pour un attribut de type nombres réels</tab></li>
-</ul>
-</li>
-<li>Spécifier la largeur de l'attribut (nombre de caractères maximum)
-en entrant une valeur dans la case <label>Largeur</label> (facultatif);
-</li>
-<li>Pour les attributs de type réel uniquement, entrer la précision
-(nombre de chiffres après la virgule) dans la case <label>Précision</label>;
-</li>
-<li>Créer l'attribut de couche en appuyant sur le bouton <label>Ajouter
-l'attribut</label>.
-</li>
-</ol>
-L'attribut créé apparaît alors dans la liste de la boîte de dialogue.<br>
-Pour créer les attributs suivants, recommencer les opérations
-ci-dessus.
-<h5><u>Étape 3 optionnelle : Effacer un attribut de couche</u></h5>
-En cas d'erreur, il est possible d'effacer un attribut créé. Pour cela,
-sélectionner l'attribut dans la liste et appuyer sur le bouton <label>Effacer
-l'attribut sélectionné</label>.
-<h5><u>Étape 4: Valider et créer la couche vectorielle</u></h5>
-Une fois les étapes 1 et 2 réalisées, valider la création de la couche
-en appuyant sur le bouton <label>OK</label> pour créer la couche ou sur le
-bouton <label>Annuler</label> pour fermer la boîte de dialogue sans créer la
-couche.
-<p>QGIS propose alors de choisir le nom et l'emplacement physique de
-stockage des fichiers shape dans l'arborescence de l'ordinateur :
-choisir un nom et un emplacement pour la couche puis appuyer sur <label>OK</label>
-pour valider le choix, ou sur <label>Annuler</label> pour quitter sans
-enregistrer.</p>
-<p>Une fois cette action réalisée, la couche est chargée dans le projet
-QGIS en cours.</p>
-<p><u>Important : </u> une nouvelle couche créée est forcément vide,
-il est donc normal qu'une couche nouvellement créée apparaisse dans la
-barre d'outils <label>Couches</label>, mais qu'aucune donnée n'apparaisse sur
-la carte du projet. Pour entrer des données dans la couche il est
-nécessaire de passer par la fonction <label>Basculer en mode édition</label>.</p>
Deleted: trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-ru_RU
--- trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-ru_RU 2009-12-13 22:57:18 UTC (rev 12443)
+++ trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-ru_RU 2009-12-13 23:13:52 UTC (rev 12444)
@@ -1,2 +0,0 @@
-<h3>Создать новый векторный слой</h3>
Deleted: trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-sk_SK
--- trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-sk_SK 2009-12-13 22:57:18 UTC (rev 12443)
+++ trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-sk_SK 2009-12-13 23:13:52 UTC (rev 12444)
@@ -1,2 +0,0 @@
-<h3>Tvorba novej vektorovej vrstvy</h3>
Added: trunk/qgis/resources/context_help/QgsNewOgrConnection-de_DE
--- trunk/qgis/resources/context_help/QgsNewOgrConnection-de_DE (rev 0)
+++ trunk/qgis/resources/context_help/QgsNewOgrConnection-de_DE 2009-12-13 23:13:52 UTC (rev 12444)
@@ -0,0 +1 @@
+<h3>Neue OGR-Datenbankverbindung</h3>
Copied: trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-de_DE (from rev 12439, trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-de_DE)
--- trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-de_DE (rev 0)
+++ trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-de_DE 2009-12-13 23:13:52 UTC (rev 12444)
@@ -0,0 +1,2 @@
+<h3>Einen neuen Vektorlayer erzeugen</h3>
Copied: trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US (from rev 12439, trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-en_US)
--- trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US (rev 0)
+++ trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-en_US 2009-12-13 23:13:52 UTC (rev 12444)
@@ -0,0 +1,2 @@
+<h3>Create New Vector Layer</h3>
Copied: trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR (from rev 12439, trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-fr_FR)
--- trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR (rev 0)
+++ trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-fr_FR 2009-12-13 23:13:52 UTC (rev 12444)
@@ -0,0 +1,84 @@
+<h3>Créer une nouvelle couche vectorielle</h3>
+QGIS offre la possibilité de créer une couche de données vectorielles
+possédant des attributs définis et configurés par l'utilisateur.<br>
+Pour l'instant, cette couche vectorielle ne peut être créée qu'au
+format ESRI shapefile (.shp), mais il possible d'utiliser séparément
+des outils comme OGR pour convertir cette couche dans un autre format.
+<p>Pour accéder à la boîte de dialogue de création de couche
+vectorielle, il existe trois possibilités:
+</p>
+<ul>
+<li>Sur la barre d'outils contrôle des couches de QGIS, appuyer sur
+le bouton <label>Nouvelle couche vectorielle</label>;
+</li>
+<li>ou dans le menu <label>Couche</label>, sélectionner la fonction <label>Nouvelle
+couche vectorielle...</label>;
+</li>
+<li>ou taper directement le raccourci clavier (<label>Shift+Ctrl+N</label>
+sous Mac OSX).
+</li>
+</ul>
+<h4>Configuration de la couche vectorielle</h4>
+<h5><u>Étape 1 : Choix du type</u></h5>
+Dans la boîte de dialogue <label>Nouvelle couche vecteur</label>, sélectionner
+le type de couche à créer en cochant le bouton souhaité:
+<ul>
+<li><label>Point</label> pour créer une couche contenant des objets de type
+ponctuels;
+</li>
+<li><label>Ligne</label> pour créer une couche contenant des objets de type
+linéaires;
+</li>
+<li><label>Polygone</label> pour créer une couche contenant des objets de
+type surfaciques.
+</li>
+</ul>
+<h5><u>Étape 2 : Création et configuration des Attributs de couche</u></h5>
+Quel que soit le type de couche choisi, la configuration des attributs
+de la couche se fait toujours de la même manière:
+<ol>
+<li>Entrer un nom pour l'attribut dans la case <label>Nom</label>;
+</li>
+<li>Choisir le type d'attribut à l'aide du menu déroulant <label>Type</label>
+: <br>
+<ul>
+<li><tab>Ligne (string) pour un attribut de type chaîne de
+caractère</tab></li>
+<li><tab>Entier (integer) pour un attribut de type nombres entiers</tab></li>
+<li><tab>Réel (real) pour un attribut de type nombres réels</tab></li>
+</ul>
+</li>
+<li>Spécifier la largeur de l'attribut (nombre de caractères maximum)
+en entrant une valeur dans la case <label>Largeur</label> (facultatif);
+</li>
+<li>Pour les attributs de type réel uniquement, entrer la précision
+(nombre de chiffres après la virgule) dans la case <label>Précision</label>;
+</li>
+<li>Créer l'attribut de couche en appuyant sur le bouton <label>Ajouter
+l'attribut</label>.
+</li>
+</ol>
+L'attribut créé apparaît alors dans la liste de la boîte de dialogue.<br>
+Pour créer les attributs suivants, recommencer les opérations
+ci-dessus.
+<h5><u>Étape 3 optionnelle : Effacer un attribut de couche</u></h5>
+En cas d'erreur, il est possible d'effacer un attribut créé. Pour cela,
+sélectionner l'attribut dans la liste et appuyer sur le bouton <label>Effacer
+l'attribut sélectionné</label>.
+<h5><u>Étape 4: Valider et créer la couche vectorielle</u></h5>
+Une fois les étapes 1 et 2 réalisées, valider la création de la couche
+en appuyant sur le bouton <label>OK</label> pour créer la couche ou sur le
+bouton <label>Annuler</label> pour fermer la boîte de dialogue sans créer la
+couche.
+<p>QGIS propose alors de choisir le nom et l'emplacement physique de
+stockage des fichiers shape dans l'arborescence de l'ordinateur :
+choisir un nom et un emplacement pour la couche puis appuyer sur <label>OK</label>
+pour valider le choix, ou sur <label>Annuler</label> pour quitter sans
+enregistrer.</p>
+<p>Une fois cette action réalisée, la couche est chargée dans le projet
+QGIS en cours.</p>
+<p><u>Important : </u> une nouvelle couche créée est forcément vide,
+il est donc normal qu'une couche nouvellement créée apparaisse dans la
+barre d'outils <label>Couches</label>, mais qu'aucune donnée n'apparaisse sur
+la carte du projet. Pour entrer des données dans la couche il est
+nécessaire de passer par la fonction <label>Basculer en mode édition</label>.</p>
Copied: trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-ru_RU (from rev 12439, trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-ru_RU)
--- trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-ru_RU (rev 0)
+++ trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-ru_RU 2009-12-13 23:13:52 UTC (rev 12444)
@@ -0,0 +1,2 @@
+<h3>Создать новый векторный слой</h3>
Copied: trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-sk_SK (from rev 12439, trunk/qgis/resources/context_help/QgsCreateNewVectorLayer-sk_SK)
--- trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-sk_SK (rev 0)
+++ trunk/qgis/resources/context_help/QgsNewVectorLayerDialog-sk_SK 2009-12-13 23:13:52 UTC (rev 12444)
@@ -0,0 +1,2 @@
+<h3>Tvorba novej vektorovej vrstvy</h3>
