[QGIS Commit] r12482 - in trunk/qgis: i18n resources/context_help
svn_qgis at osgeo.org
Tue Dec 15 16:41:32 EST 2009
Author: jef
Date: 2009-12-15 16:41:32 -0500 (Tue, 15 Dec 2009)
New Revision: 12482
trunk/qgis/i18n/qgis_de.ts
trunk/qgis/resources/context_help/QgsProjectProperties-de_DE
trunk/qgis/resources/context_help/QgsProjectProperties-en_US
update german translation
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2009-12-15 21:40:37 UTC (rev 12481)
+++ trunk/qgis/i18n/qgis_de.ts 2009-12-15 21:41:32 UTC (rev 12482)
@@ -7977,7 +7977,7 @@
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="195"/>
<source>Snapping</source>
- <translation>Snapping</translation>
+ <translation>Objektfang</translation>
</message>
<message>
<location filename="../src/ui/qgscompositionwidgetbase.ui" line="201"/>
@@ -10355,7 +10355,7 @@
<message>
<location filename="../src/plugins/grass/qgsgrasseditbase.ui" line="162"/>
<source>Snapping in screen pixels</source>
- <translation>Snappingtoleranz in Bildschirmpixel</translation>
+ <translation>Fangtoleranz in Bildschirmpixel</translation>
</message>
<message>
<location filename="../src/plugins/grass/qgsgrasseditbase.ui" line="213"/>
@@ -14132,7 +14132,7 @@
<message>
<location filename="../src/app/qgsmaptoolvertexedit.cpp" line="51"/>
<source>Snap tolerance</source>
- <translation>Snappingtoleranz</translation>
+ <translation>Fangtoleranz</translation>
</message>
<message>
<location filename="../src/app/qgsmaptoolvertexedit.cpp" line="52"/>
@@ -14147,7 +14147,7 @@
<message>
<location filename="../src/app/qgsmaptoolvertexedit.cpp" line="58"/>
<source>Have you set the tolerance in Settings > Project Properties > General?</source>
- <translation>Haben Sie die Snappingtoleranz in Einstellungen > Projekteinstellungen > Allgemein eingestellt?</translation>
+ <translation>Haben Sie die Fangtoleranz in Einstellungen > Projekteinstellungen > Allgemein eingestellt?</translation>
</message>
</context>
<context>
@@ -15772,7 +15772,7 @@
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="703"/>
</message>
<message>
<location filename="../src/ui/qgsoptionsbase.ui" line="302"/>
@@ -18255,7 +18255,7 @@
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="307"/>
<source>Snapping options...</source>
- <translation>Snapping-Optionen...</translation>
+ <translation>Fangoptionen...</translation>
</message>
<message>
<location filename="../src/ui/qgsprojectpropertiesbase.ui" line="42"/>
@@ -20608,7 +20608,7 @@
<location filename="../src/app/qgssnappingdialog.cpp" line="65"/>
<location filename="../src/app/qgssnappingdialog.cpp" line="95"/>
<source>to vertex and segment</source>
- <translation>zum Stützpunkt und Segment</translation>
+ <translation>zum Stützpunkt oder Segment</translation>
</message>
<message>
<location filename="../src/app/qgssnappingdialog.cpp" line="76"/>
@@ -20629,7 +20629,7 @@
<message>
<location filename="../src/ui/qgssnappingdialogbase.ui" line="13"/>
<source>Snapping options</source>
- <translation>Einrastoptionen</translation>
+ <translation>Fangoptionen</translation>
</message>
<message>
<location filename="../src/ui/qgssnappingdialogbase.ui" line="38"/>
Modified: trunk/qgis/resources/context_help/QgsProjectProperties-de_DE
--- trunk/qgis/resources/context_help/QgsProjectProperties-de_DE 2009-12-15 21:40:37 UTC (rev 12481)
+++ trunk/qgis/resources/context_help/QgsProjectProperties-de_DE 2009-12-15 21:41:32 UTC (rev 12482)
@@ -15,7 +15,10 @@
<tr><td><label>Pfade speichern</label></td><td>Möglichkeit Pfade absolut oder relativ zu speichern.</td><tr>
<tr><td><label>Layereinheiten</label></td><td>Wählen Sie die Einheiten der Layer des Projekts</td></tr>
<tr><td><label>Genauigkeit</label></td><td>Benutzen Sie die manuelle Einstellungen der Anzeigegenauigkeit in der Statuszeile. Während die Maus über die Karte bewegt wird, werden die Koordinaten ständig mit der gewählten Genauigkeit in der Statuszeile angezeigt. Automatisch (die Voreinstellung) führt zu einer von den Karteneinheiten abhängigen Voreinstellung.</td></tr>
-<tr><td><label>Digitalisierung</label></td><td>Dies erlaubt Ihnen eine Fangtoleranz in Pixeln, die Linienstärke und -farbe während des Digitalisieren festzulegen</td></tr>
+<tr><td><label>Digitalisierung</label></td><td>Die Option <label>Ermöglichte topologisches Editieren</label> gestattet bearbeiten und weiterführen von Polygonmosaiken. Das Verschieben des Stützpunkts einer gemeinsamer Grenze führt zur Änderung beider Grenzen.<p>
+Um die Digitalisierung aller gemeinsamen Punkte einer Grenze zu vermeiden dient die Option <label>Überschneidung von neuen Polygonen vermeiden...</label>. Im Dialogfenster sind die gewünschten Layer zu wählen an die das neue Polygon angepaßt werden soll. Die Flächen der Polygone, die das neue Polygon überdeckt,
+werden automatisch entfernt.<p>
+<label>Fangoptionen<label> erlaubt Ihnen eine Fangtoleranz in Pixeln oder Karteneinheiten und den Fangmodus einzustellen: <label>zum Stützpunkt</label>, <label>zu Segment</label> oder <label>zum Stützpunkt oder Segment</label> für jeden einzelnen Layer.</td></tr>
</table>
<a name="crs">
<h4>Reiter Koordinatenbezugssystem (KBS)</h4>
Modified: trunk/qgis/resources/context_help/QgsProjectProperties-en_US
--- trunk/qgis/resources/context_help/QgsProjectProperties-en_US 2009-12-15 21:40:37 UTC (rev 12481)
+++ trunk/qgis/resources/context_help/QgsProjectProperties-en_US 2009-12-15 21:41:32 UTC (rev 12482)
@@ -17,7 +17,7 @@
<tr><td><label>Layer units</label></td><td>Choose the units appropriate for the layers in the project.</td></tr>
<tr><td><label>Precision</label></td><td>Use the manual setting to set the precision of the display in the status bar. As the mouse is moved over the map canvas, the coordinates are updated and displayed in the status bar using the precision you choose. Automatic (the default) results in a default precision based on the map units.</td></tr>
<tr><td><label>Digitizing</label></td><td>The option <label> Enable topological editing</label> enables editing and maintaining common boundaries in polygon mosaics. Editing a vertex in shared boundary will result in updating both boundaries.<p>
-To avoid digitizing all vertices of the common boundary select <label>Avoid intersections of new polygons</label>. In the dialog window tick appropriate layers to which the new polygon will be adjusted. Draw the new poligon in the way it overlap the existng one, it will be cut automatically. <p>
+To avoid digitizing all vertices of the common boundary select <label>Avoid intersections of new polygons</label>. In the dialog window tick appropriate layers to which the new polygon will be adjusted. Draw the new polygon in the way it overlap the existing one, it will be cut automatically. <p>
<label>Snapping options</label> allows you to set the snapping tolerance in pixels or map units and the snapping mode: <label>to vertex</label>, <label>to segment</label>, <label>to vertex and segment</label> for every layer separately.</td></tr>
</table>
