[QGIS Commit] r12487 - in trunk/qgis/python: .
plugins/plugin_installer
svn_qgis at osgeo.org
Tue Dec 15 19:37:02 EST 2009
Author: borysiasty
Date: 2009-12-15 19:37:01 -0500 (Tue, 15 Dec 2009)
New Revision: 12487
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_gui.py
trunk/qgis/python/utils.py
Plugin installer update - rest of the r12476
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-12-15 23:55:01 UTC (rev 12486)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2009-12-16 00:37:01 UTC (rev 12487)
@@ -15,7 +15,7 @@
return "Plugin Installer"
def version():
- return "Version 1.0.6"
+ return "Version 1.0.7"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-12-15 23:55:01 UTC (rev 12486)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2009-12-16 00:37:01 UTC (rev 12487)
@@ -599,11 +599,17 @@
plugin = plugins.all()[key]
if not plugin["error"]:
if previousStatus in ["not installed", "new"]:
- if QGIS_14: infoString = (self.tr("Plugin installed successfully"), self.tr("Plugin installed successfully"))
+ if QGIS_14:
+ infoString = (self.tr("Plugin installed successfully"), self.tr("Plugin installed successfully"))
+ settings = QSettings()
+ settings.setValue("/PythonPlugins/"+plugin["localdir"], QVariant(True))
else: infoString = (self.tr("Plugin installed successfully"), self.tr("Python plugin installed.\nNow you need to enable it in Plugin Manager."))
else:
infoString = (self.tr("Plugin reinstalled successfully"), self.tr("Python plugin reinstalled.\nYou need to restart Quantum GIS in order to reload it."))
- startPlugin(plugin["localdir"])
+ try:
+ startPlugin(plugin["localdir"])
+ except:
+ pass
else:
if plugin["error"] == "incompatible":
message = self.tr("The plugin is designed for a newer version of Quantum GIS. The minimum required version is:")
Modified: trunk/qgis/python/utils.py
--- trunk/qgis/python/utils.py 2009-12-15 23:55:01 UTC (rev 12486)
+++ trunk/qgis/python/utils.py 2009-12-16 00:37:01 UTC (rev 12487)
@@ -153,6 +153,8 @@
def unloadPlugin(packageName):
""" unload and delete plugin! """
global plugins
+ if not plugins.has_key(packageName): return False
try:
plugins[packageName].unload()
