[QGIS Commit] r12508 - in trunk/qgis/src: core core/pal
plugins/labeling
svn_qgis at osgeo.org
Fri Dec 18 14:14:58 EST 2009
Author: wonder
Date: 2009-12-18 14:14:57 -0500 (Fri, 18 Dec 2009)
New Revision: 12508
trunk/qgis/src/core/pal/pal.cpp
trunk/qgis/src/core/qgsgeometry.cpp
trunk/qgis/src/plugins/labeling/pallabeling.cpp
Less verbosity to stdout from labeling plugin
Modified: trunk/qgis/src/core/pal/pal.cpp
--- trunk/qgis/src/core/pal/pal.cpp 2009-12-18 16:04:00 UTC (rev 12507)
+++ trunk/qgis/src/core/pal/pal.cpp 2009-12-18 19:14:57 UTC (rev 12508)
@@ -493,7 +493,9 @@
Feats *feat;
- std::cout << "FIRSST NBFT : " << prob->nbft << std::endl;
+#ifdef _VERBOSE_
+ std::cout << "FIRST NBFT : " << prob->nbft << std::endl;
+#endif
// Filtering label positions against obstacles
amin[0] = amin[1] = -DBL_MAX;
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp 2009-12-18 16:04:00 UTC (rev 12507)
+++ trunk/qgis/src/core/qgsgeometry.cpp 2009-12-18 19:14:57 UTC (rev 12508)
@@ -4117,7 +4117,7 @@
hasZValue = true;
case QGis::WKBLineString:
- QgsDebugMsg( "Linestring found" );
+ QgsDebugMsgLevel( "Linestring found", 3 );
QgsPolyline sequence;
@@ -4181,7 +4181,7 @@
hasZValue = true;
case QGis::WKBPolygon:
- QgsDebugMsg( "Polygon found" );
+ QgsDebugMsgLevel( "Polygon found", 3 );
// get number of rings in the polygon
numRings = ( int * )( mGeometry + 1 + sizeof( int ) );
@@ -4223,7 +4223,7 @@
hasZValue = true;
case QGis::WKBMultiPolygon:
- QgsDebugMsg( "Multipolygon found" );
+ QgsDebugMsgLevel( "Multipolygon found", 3 );
QVector<GEOSGeometry*> polygons;
Modified: trunk/qgis/src/plugins/labeling/pallabeling.cpp
--- trunk/qgis/src/plugins/labeling/pallabeling.cpp 2009-12-18 16:04:00 UTC (rev 12507)
+++ trunk/qgis/src/plugins/labeling/pallabeling.cpp 2009-12-18 19:14:57 UTC (rev 12508)
@@ -21,6 +21,7 @@
#include <QTime>
#include <QPainter>
+#include <qgslogger.h>
#include <qgsvectorlayer.h>
#include <qgsmaplayerregistry.h>
#include <qgsvectordataprovider.h>
@@ -240,7 +241,7 @@
catch ( std::exception* e )
- std::cerr << "Ignoring feature " << f.id() << " due PAL exception: " << e->what() << std::endl;
+ QgsDebugMsg( QString( "Ignoring feature %1 due PAL exception: " ).arg( f.id() ) + QString::fromLatin1( e->what() ) );
return;
@@ -431,7 +432,7 @@
catch ( std::exception& e )
- std::cerr << "PAL EXCEPTION :-( " << e.what() << std::endl;
+ QgsDebugMsg( "PAL EXCEPTION :-( " + QString::fromLatin1( e.what() ) );
mActiveLayers.clear(); // clean up
return;
@@ -460,7 +461,7 @@
// find the solution
labels = mPal->solveProblem( problem, mShowingAllLabels );
- std::cout << "LABELING work: " << t.elapsed() << "ms ... labels# " << labels->size() << std::endl;
+ QgsDebugMsg( QString( "LABELING work: %1 ms ... labels# %2" ).arg( t.elapsed() ).arg( labels->size() ) );
t.restart();
painter->setRenderHint( QPainter::Antialiasing );
@@ -477,7 +478,7 @@
drawLabel( *it, painter, xform );
- std::cout << "LABELING draw: " << t.elapsed() << "ms" << std::endl;
+ QgsDebugMsg( QString( "LABELING draw: %1 ms" ).arg( t.elapsed() ) );
delete problem;
delete labels;
