[QGIS Commit] r12540 - in trunk/qgis: python/core src/core
src/plugins/labeling
svn_qgis at osgeo.org
Sun Dec 20 11:35:46 EST 2009
Author: wonder
Date: 2009-12-20 11:35:45 -0500 (Sun, 20 Dec 2009)
New Revision: 12540
trunk/qgis/python/core/qgsmaprenderer.sip
trunk/qgis/src/core/qgsmaprenderer.cpp
trunk/qgis/src/core/qgsmaprenderer.h
trunk/qgis/src/plugins/labeling/pallabeling.cpp
trunk/qgis/src/plugins/labeling/pallabeling.h
Fix new labeling to work with render caching.
Modified: trunk/qgis/python/core/qgsmaprenderer.sip
--- trunk/qgis/python/core/qgsmaprenderer.sip 2009-12-20 16:12:02 UTC (rev 12539)
+++ trunk/qgis/python/core/qgsmaprenderer.sip 2009-12-20 16:35:45 UTC (rev 12540)
@@ -14,6 +14,8 @@
//! called when we're going to start with rendering
virtual void init() = 0;
+ //! called to find out whether the layer is used for labeling
+ virtual bool willUseLayer( QgsVectorLayer* layer ) = 0;
//! called when starting rendering of a layer
virtual int prepareLayer(QgsVectorLayer* layer, int& attrIndex) = 0;
//! called for every feature
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp 2009-12-20 16:12:02 UTC (rev 12539)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp 2009-12-20 16:35:45 UTC (rev 12540)
@@ -180,9 +180,9 @@
dymax = mExtent.yMaximum() + whitespace;
- QgsDebugMsg( QString("Map units per pixel (x,y) : %1, %2\n" ).arg( mapUnitsPerPixelX ).arg( mapUnitsPerPixelY ) );
- QgsDebugMsg( QString("Pixmap dimensions (x,y) : %1, %2\n" ).arg( myWidth ).arg( myHeight ) );
- QgsDebugMsg( QString("Extent dimensions (x,y) : %1, %2\n" ).arg( mExtent.width() ).arg( mExtent.height() ) );
+ QgsDebugMsg( QString( "Map units per pixel (x,y) : %1, %2\n" ).arg( mapUnitsPerPixelX ).arg( mapUnitsPerPixelY ) );
+ QgsDebugMsg( QString( "Pixmap dimensions (x,y) : %1, %2\n" ).arg( myWidth ).arg( myHeight ) );
+ QgsDebugMsg( QString( "Extent dimensions (x,y) : %1, %2\n" ).arg( mExtent.width() ).arg( mExtent.height() ) );
QgsDebugMsg( mExtent.toString() );
// update extent
@@ -194,7 +194,7 @@
// update the scale
updateScale();
- QgsDebugMsg( QString("Scale (assuming meters as map units) = 1:%1").arg( mScale ) );
+ QgsDebugMsg( QString( "Scale (assuming meters as map units) = 1:%1" ).arg( mScale ) );
newCoordXForm.setParameters( mMapUnitsPerPixel, dxmin, dymin, myHeight );
mRenderContext.setMapToPixel( newCoordXForm );
@@ -406,10 +406,12 @@
// Force render of layers that are being edited
+ // or if there's a labeling engine that needs the layer to register features
if ( ml->type() == QgsMapLayer::VectorLayer )
QgsVectorLayer* vl = qobject_cast<QgsVectorLayer *>( ml );
- if ( vl->isEditable() )
+ if ( vl->isEditable() ||
+ ( mRenderContext.labelingEngine() && mRenderContext.labelingEngine()->willUseLayer( vl ) ) )
ml->setCacheImage( 0 );
@@ -576,7 +578,7 @@
// set correct extent
mRenderContext.setExtent( mExtent );
- mRenderContext.setCoordinateTransform(NULL);
+ mRenderContext.setCoordinateTransform( NULL );
mLabelingEngine->drawLabeling( mRenderContext );
mLabelingEngine->exit();
@@ -813,7 +815,7 @@
QgsMapLayer * lyr = registry->mapLayer( *it );
if ( lyr == NULL )
- QgsDebugMsg( QString("WARNING: layer '%1' not found in map layer registry!").arg( *it ) );
+ QgsDebugMsg( QString( "WARNING: layer '%1' not found in map layer registry!" ).arg( *it ) );
else
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h 2009-12-20 16:12:02 UTC (rev 12539)
+++ trunk/qgis/src/core/qgsmaprenderer.h 2009-12-20 16:35:45 UTC (rev 12540)
@@ -47,6 +47,8 @@
virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex ) = 0;
Modified: trunk/qgis/src/plugins/labeling/pallabeling.cpp
--- trunk/qgis/src/plugins/labeling/pallabeling.cpp 2009-12-20 16:12:02 UTC (rev 12539)
+++ trunk/qgis/src/plugins/labeling/pallabeling.cpp 2009-12-20 16:35:45 UTC (rev 12540)
@@ -288,6 +288,14 @@
+bool PalLabeling::willUseLayer( QgsVectorLayer* layer )
+ LayerSettings lyrTmp;
+ lyrTmp.readFromLayer( layer );
+ return lyrTmp.enabled;
int PalLabeling::prepareLayer( QgsVectorLayer* layer, int& attrIndex )
// start with a temporary settings class, find out labeling info
@@ -298,7 +306,7 @@
return 0;
// find out which field will be needed
- int fldIndex = layer->dataProvider()->fieldNameIndex( lyrTmp.fieldName );
+ int fldIndex = layer->fieldNameIndex( lyrTmp.fieldName );
if ( fldIndex == -1 )
return 0;
attrIndex = fldIndex;
Modified: trunk/qgis/src/plugins/labeling/pallabeling.h
--- trunk/qgis/src/plugins/labeling/pallabeling.h 2009-12-20 16:12:02 UTC (rev 12539)
+++ trunk/qgis/src/plugins/labeling/pallabeling.h 2009-12-20 16:35:45 UTC (rev 12540)
@@ -123,6 +123,8 @@
virtual void init();
+ virtual bool willUseLayer( QgsVectorLayer* layer );
//! hook called when drawing layer before issuing select()
virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex );
//! hook called when drawing for every feature in a layer
