[QGIS Commit] r12548 - trunk/qgis/i18n
svn_qgis at osgeo.org
Sun Dec 20 14:12:18 EST 2009
Author: pcav
Date: 2009-12-20 14:12:17 -0500 (Sun, 20 Dec 2009)
New Revision: 12548
trunk/qgis/i18n/qgis_it.ts
Minor edits to the IT translation
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts 2009-12-20 18:42:01 UTC (rev 12547)
+++ trunk/qgis/i18n/qgis_it.ts 2009-12-20 19:12:17 UTC (rev 12548)
@@ -5108,7 +5108,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="579"/>
<source>&Save Project</source>
- <translation>&Salva Progetto</translation>
+ <translation>&Salva progetto</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="580"/>
@@ -5757,7 +5757,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="1505"/>
<source>Help</source>
- <translation type="unfinished">Guida</translation>
+ <translation>Guida</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1431"/>
@@ -6663,7 +6663,7 @@
<message>
<location filename="../src/app/qgisapp.cpp" line="1203"/>
<source>Print Composers</source>
- <translation>Stampa</translation>
+ <translation>Stampe</translation>
</message>
<message>
<location filename="../src/app/qgisapp.cpp" line="1210"/>
@@ -20339,7 +20339,7 @@
<message>
<location filename="../src/app/qgsmaptoolvertexedit.cpp" line="58"/>
<source>Have you set the tolerance in Settings > Project Properties > General?</source>
- <translation>Hai impostato la tolleranza in Impostazioni > Proprietà Progetto > Generale > Opzioni di Snap?</translation>
+ <translation>Hai impostato la tolleranza in Impostazioni > Proprietà progetto > Generale > Opzioni di snap?</translation>
</message>
</context>
<context>
@@ -20898,7 +20898,7 @@
<message>
<location filename="../src/app/qgsmeasuretool.cpp" line="78"/>
<source><p>This map is defined with a geographic coordinate system (latitude/longitude) but the map extents suggests that it is actually a projected coordinate system (e.g., Mercator). If so, the results from line or area measurements will be incorrect.</p><p>To fix this, explicitly set an appropriate map coordinate system using the <tt>Settings:Project Properties</tt> menu.</source>
- <translation><p>Questa mappa è definita con un sistema di coordinate geografico (latitudine/longitudine) ma l'estensione della mappa suggerisce che attualmente si sta facendo uso di un altro sistema di proiezione (e.s. Mercatore) per tale motivo i risultati delle misurazione di linee o aree risulta sbagliato.</p><p>Per risolvere il problema occorre assegnare il sistema di coordinate corretto utilizzando la voce di menu <tt>Impostazioni: Proprietà Progetto</tt>.</translation>
+ <translation><p>Questa mappa è definita con un sistema di coordinate geografico (latitudine/longitudine) ma l'estensione della mappa suggerisce che attualmente si sta facendo uso di un altro sistema di proiezione (e.s. Mercatore) per tale motivo i risultati delle misurazione di linee o aree risulta sbagliato.</p><p>Per risolvere il problema occorre assegnare il sistema di coordinate corretto utilizzando la voce di menu <tt>Impostazioni: Proprietà progetto</tt>.</translation>
</message>
</context>
<context>
