[QGIS Commit] r12572 - trunk/qgis/i18n
svn_qgis at osgeo.org
Tue Dec 22 02:59:31 EST 2009
Author: pcav
Date: 2009-12-22 02:59:30 -0500 (Tue, 22 Dec 2009)
New Revision: 12572
trunk/qgis/i18n/qgis_it.ts
More improvements in the IT translation - Thanks Flavio Rigolon
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts 2009-12-22 07:33:03 UTC (rev 12571)
+++ trunk/qgis/i18n/qgis_it.ts 2009-12-22 07:59:30 UTC (rev 12572)
@@ -776,7 +776,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmGeometry.ui" line="110"/>
<source>Output point shapefile</source>
- <translation>Shapefile poligoni in output</translation>
+ <translation>Shapefile di punti in output</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmGeoprocessing.ui" line="19"/>
@@ -26573,7 +26573,7 @@
<location filename="../src/gui/qgsquickprint.cpp" line="659"/>
<source>Please wait while your report is generated</source>
<comment>COMMENTED OUT</comment>
- <translation type="unfinished">Un po' di pazienza mentre il report viene generato</translation>
+ <translation>Attendere la generazione del report</translation>
</message>
</context>
<context>
@@ -28466,7 +28466,7 @@
<message>
<location filename="../src/plugins/scale_bar/plugin.cpp" line="166"/>
<source> metres/km</source>
- <translation>. metri/km</translation>
+ <translation> metri/km</translation>
</message>
<message>
<location filename="../src/plugins/scale_bar/plugin.cpp" line="289"/>
@@ -28562,7 +28562,7 @@
<message>
<location filename="../src/plugins/scale_bar/plugin.cpp" line="105"/>
<source>Creates a scale bar that is displayed on the map canvas</source>
- <translation>Crea una barra di scala che verrà visualizzata sopra sulla mappa</translation>
+ <translation>Crea una barra di scala che verrà visualizzata sulla mappa</translation>
</message>
<message>
<location filename="../src/plugins/scale_bar/plugin.cpp" line="114"/>
@@ -32819,11 +32819,11 @@
<name>VisualDialog</name>
<message>
<source>Please specify input vector layer</source>
- <translation type="unfinished">Selezionare vettoriale in input</translation>
+ <translation>Selezionare vettoriale in input</translation>
</message>
<message>
<source>Please specify input field</source>
- <translation type="unfinished">Specificare il campo di input</translation>
+ <translation>Specificare il campo di input</translation>
</message>
<message>
<source>Check geometry validity</source>
