[QGIS Commit] r12579 - in trunk/qgis: python/core src/core
svn_qgis at osgeo.org
Tue Dec 22 09:52:54 EST 2009
Author: wonder
Date: 2009-12-22 09:52:54 -0500 (Tue, 22 Dec 2009)
New Revision: 12579
Added:
trunk/qgis/python/core/qgssearchstring.sip
trunk/qgis/python/core/qgssearchtreenode.sip
trunk/qgis/python/core/core.sip
trunk/qgis/src/core/qgssearchtreenode.h
Added python bindings for search strings
Modified: trunk/qgis/python/core/core.sip
--- trunk/qgis/python/core/core.sip 2009-12-22 14:13:49 UTC (rev 12578)
+++ trunk/qgis/python/core/core.sip 2009-12-22 14:52:54 UTC (rev 12579)
@@ -60,6 +60,8 @@
%Include qgsrenderer.sip
%Include qgsrunprocess.sip
%Include qgsscalecalculator.sip
+%Include qgssearchstring.sip
+%Include qgssearchtreenode.sip
%Include qgssinglesymbolrenderer.sip
%Include qgssnapper.sip
%Include qgsspatialindex.sip
Added: trunk/qgis/python/core/qgssearchstring.sip
--- trunk/qgis/python/core/qgssearchstring.sip (rev 0)
+++ trunk/qgis/python/core/qgssearchstring.sip 2009-12-22 14:52:54 UTC (rev 12579)
@@ -0,0 +1,42 @@
+class QgsSearchString
+%TypeHeaderCode
+#include "qgssearchstring.h"
+%End
+ public:
+ //! constructor
+ QgsSearchString();
+ //! copy constructor - makes also copy of search tree
+ QgsSearchString( const QgsSearchString& str );
+ //! destructor - deletes node tree
+ ~QgsSearchString();
+ //! assignment operator takes care to copy search tree correctly
+ // unable to wrap QgsSearchString& operator=( const QgsSearchString& str );
+ /** sets search string and parses search tree
+ on success returns true and sets member variables to the new values */
+ bool setString( QString str );
+ /** copies tree and makes search string for it
+ bool setTree( QgsSearchTreeNode* tree );
+ //! getter functions
+ QgsSearchTreeNode* tree();
+ QString string();
+ //! returns parser error message - valid only after unsuccessfull parsing
+ const QString& parserErrorMsg();
+ //! returns true if no string is set
+ bool isEmpty();
+ //! clear search string
+ void clear();
Added: trunk/qgis/python/core/qgssearchtreenode.sip
--- trunk/qgis/python/core/qgssearchtreenode.sip (rev 0)
+++ trunk/qgis/python/core/qgssearchtreenode.sip 2009-12-22 14:52:54 UTC (rev 12579)
@@ -0,0 +1,146 @@
+class QgsSearchTreeNode
+%TypeHeaderCode
+#include "qgssearchtreenode.h"
+%End
+ public:
+ //! defines possible types of node
+ enum Type
+ tOperator = 1,
+ tNumber,
+ tColumnRef,
+ tString
+ //! possible operators
+ enum Operator
+ // binary
+ opAND = 1,
+ opOR,
+ opNOT,
+ // arithmetic
+ opPLUS,
+ opMINUS,
+ opMUL,
+ opDIV,
+ opPOW,
+ opSQRT,
+ opSIN,
+ opCOS,
+ opTAN,
+ opASIN,
+ opACOS,
+ opATAN,
+ opTOINT,
+ opTOREAL,
+ opTOSTRING,
+ opLENGTH,
+ opAREA,
+ // comparison
+ opEQ, // =
+ opNE, // != resp. <>
+ opGT, // >
+ opLT, // <
+ opGE, // >=
+ opLE, // <=
+ opRegexp, // ~
+ opLike // LIKE
+ //! constructors
+ QgsSearchTreeNode( double number );
+ QgsSearchTreeNode( Operator o, QgsSearchTreeNode* left, QgsSearchTreeNode* right );
+ QgsSearchTreeNode( QString text, bool isColumnRef );
+ //! copy contructor - copies whole tree!
+ QgsSearchTreeNode( const QgsSearchTreeNode& node );
+ //! destructor - deletes children nodes (if any)
+ ~QgsSearchTreeNode();
+ //! returns type of current node
+ Type type();
+ //! node value getters
+ // TODO: for some reason this function is not found by dynamic linker
+ //Operator op();
+ double number();
+ QString columnRef();
+ QString string();
+ //! node value setters (type is set also)
+ void setOp( Operator o );
+ void setNumber( double number );
+ void setColumnRef( QString& str );
+ void setString( QString& str );
+ //! children
+ QgsSearchTreeNode* Left();
+ QgsSearchTreeNode* Right();
+ void setLeft( QgsSearchTreeNode* left );
+ void setRight( QgsSearchTreeNode* right );
+ //! returns search string that should be equal to original parsed string
+ QString makeSearchString();
+ //! checks whether the node tree is valid against supplied attributes
+ bool checkAgainst( const QMap<int,QgsField>& fields, const QMap<int, QVariant>& attributes );
+ //! checks if there were errors during evaluation
+ bool hasError();
+ //! returns error message
+ const QString& errorMsg();
+ //! wrapper around valueAgainst()
+ bool getValue( QgsSearchTreeValue& value /Out/, QgsSearchTreeNode* node,
+ const QMap<int,QgsField>& fields, const QMap<int,QVariant>& attributes, QgsGeometry* geom = 0 );
+ protected:
+ //! returns scalar value of node
+ QgsSearchTreeValue valueAgainst( const QMap<int,QgsField>& fields, const QMap<int,QVariant>& attributes, QgsGeometry* geom = 0 );
+ //! strips mText when node is of string type
+ void stripText();
+class QgsSearchTreeValue
+%TypeHeaderCode
+%End
+ public:
+ enum Type
+ valError,
+ valString,
+ valNumber
+ QgsSearchTreeValue();
+ QgsSearchTreeValue( QString string );
+ QgsSearchTreeValue( double number );
+ QgsSearchTreeValue( int error, QString errorMsg );
+ static int compare( QgsSearchTreeValue& value1, QgsSearchTreeValue& value2,
+ Qt::CaseSensitivity = Qt::CaseSensitive );
+ bool isNumeric();
+ bool isError();
+ QString& string();
+ double number();
Modified: trunk/qgis/src/core/qgssearchtreenode.h
--- trunk/qgis/src/core/qgssearchtreenode.h 2009-12-22 14:13:49 UTC (rev 12578)
+++ trunk/qgis/src/core/qgssearchtreenode.h 2009-12-22 14:52:54 UTC (rev 12579)
@@ -165,8 +165,8 @@
QgsDistanceArea mCalc;
-// TODO: poslat do zvlast suboru
-class QgsSearchTreeValue
+// TODO: put it into separate file
+class CORE_EXPORT QgsSearchTreeValue
public:
