[QGIS Commit] r12582 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org
Tue Dec 22 14:37:48 EST 2009
Author: jef
Date: 2009-12-22 14:37:47 -0500 (Tue, 22 Dec 2009)
New Revision: 12582
trunk/qgis/src/app/qgslabeldialog.cpp
trunk/qgis/src/ui/qgslabeldialogbase.ui
fix offset labels in label dialog
Modified: trunk/qgis/src/app/qgslabeldialog.cpp
--- trunk/qgis/src/app/qgslabeldialog.cpp 2009-12-22 16:46:46 UTC (rev 12581)
+++ trunk/qgis/src/app/qgslabeldialog.cpp 2009-12-22 19:37:47 UTC (rev 12582)
@@ -188,7 +188,15 @@
mFont.setItalic( false );
- mFont.setUnderline( myLabelAttributes->underline() );
+ if ( myLabelAttributes->underlineIsSet() )
+ mFont.setUnderline( myLabelAttributes->underline() );
+ else
+ mFont.setUnderline( false );
mFontColor = myLabelAttributes->color();
if ( myLabelAttributes->offsetIsSet() )
Modified: trunk/qgis/src/ui/qgslabeldialogbase.ui
--- trunk/qgis/src/ui/qgslabeldialogbase.ui 2009-12-22 16:46:46 UTC (rev 12581)
+++ trunk/qgis/src/ui/qgslabeldialogbase.ui 2009-12-22 19:37:47 UTC (rev 12582)
@@ -449,14 +449,14 @@
<item row="0" column="0">
<widget class="QLabel" name="textLabel1_2_2_2_3">
<property name="text">
- <string>Y Offset (pts)</string>
+ <string>X Offset (pts)</string>
</property>
</widget>
</item>
<item row="0" column="1">
<widget class="QLabel" name="textLabel1_2_3_2">
- <string>X Offset (pts)</string>
+ <string>Y Offset (pts)</string>
</property>
</widget>
</item>
