[QGIS Commit] r12593 - trunk/qgis/src/app/legend
svn_qgis at osgeo.org
Wed Dec 23 08:01:49 EST 2009
Author: jef
Date: 2009-12-23 08:01:48 -0500 (Wed, 23 Dec 2009)
New Revision: 12593
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/legend/qgslegendlayer.cpp
fix #2314
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2009-12-23 13:00:26 UTC (rev 12592)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2009-12-23 13:01:48 UTC (rev 12593)
@@ -537,14 +537,6 @@
setCurrentItem( llayer );
//make the QTreeWidget item up-to-date
doItemsLayout();
- // setup connections that will update the layer icons
- if ( qobject_cast<QgsVectorLayer *>( layer ) )
- QgsDebugMsg( "Connecting signals for updating icons, layer " + layer->name() );
- connect( layer, SIGNAL( editingStarted() ), llayer, SLOT( updateIcon() ) );
- connect( layer, SIGNAL( editingStopped() ), llayer, SLOT( updateIcon() ) );
QgsLegendLayer* QgsLegend::currentLegendLayer()
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp 2009-12-23 13:00:26 UTC (rev 12592)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp 2009-12-23 13:01:48 UTC (rev 12593)
@@ -77,16 +77,14 @@
// not in overview by default
mLyr.setInOverview( FALSE );
- // Add check if vector layer when connecting to selectionChanged slot
- // Ticket #811 - racicot
- QgsMapLayer *currentLayer = mLyr.layer();
- QgsVectorLayer *isVectLyr = qobject_cast<QgsVectorLayer *>( currentLayer );
- if ( isVectLyr )
+ // setup connections that will update the layer icons
+ if ( qobject_cast<QgsVectorLayer *>( layer ) )
- connect( mLyr.layer(), SIGNAL( editingStarted() ), this, SLOT( updateLegendItem() ) );
- connect( mLyr.layer(), SIGNAL( editingStopped() ), this, SLOT( updateLegendItem() ) );
+ QgsDebugMsg( "Connecting signals for updating icons, layer " + layer->name() );
+ connect( layer, SIGNAL( editingStarted() ), this, SLOT( updateIcon() ) );
+ connect( layer, SIGNAL( editingStopped() ), this, SLOT( updateIcon() ) );
- connect( mLyr.layer(), SIGNAL( layerNameChanged() ), this, SLOT( layerNameChanged() ) );
+ connect( layer, SIGNAL( layerNameChanged() ), this, SLOT( layerNameChanged() ) );
QgsLegendLayer::~QgsLegendLayer()
