[QGIS Commit] r12611 - in trunk/qgis: debian resources/context_help
svn_qgis at osgeo.org
Thu Dec 24 03:37:54 EST 2009
Author: pcav
Date: 2009-12-24 03:37:52 -0500 (Thu, 24 Dec 2009)
New Revision: 12611
Added:
trunk/qgis/resources/context_help/MapServerExport-it_IT
trunk/qgis/resources/context_help/QgsMeasureDialog-it_IT
trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-it_IT
trunk/qgis/debian/control
First IT translations of context_help by Flavio Rigolon
Modified: trunk/qgis/debian/control
--- trunk/qgis/debian/control 2009-12-24 07:06:24 UTC (rev 12610)
+++ trunk/qgis/debian/control 2009-12-24 08:37:52 UTC (rev 12611)
@@ -70,7 +70,7 @@
Package: qgis-plugin-grass
Architecture: any
-Depends: qgis (= ${binary:Version}), qgis-plugin-grass-common (= ${source:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.6.0-grass, grass640-5
+Depends: qgis (= ${binary:Version}), qgis-plugin-grass-common (= ${source:Version}), ${shlibs:Depends}, ${misc:Depends}, libgdal1-1.6.0-grass, grass640-5+40109
Description: GRASS plugin for Quantum GIS
Quantum GIS is a Geographic Information System (GIS) which manages, analyzes
and display databases of geographic information.
Added: trunk/qgis/resources/context_help/MapServerExport-it_IT
--- trunk/qgis/resources/context_help/MapServerExport-it_IT (rev 0)
+++ trunk/qgis/resources/context_help/MapServerExport-it_IT 2009-12-24 08:37:52 UTC (rev 12611)
@@ -0,0 +1,36 @@
+<h3>Esporta un progetto QGIS su Map File di MapServer</h3>
+<p>
+Questo strumento consente di esportare un progetto QGIS su un Map File pronto per MapServer
+Sono richiesti il <b>Map file</b> e il <b>progetto QGIS</b>.
+</p>
+Spuntare il checkbox <label>Usa progetto corrente</label> o inserisci il percorso assoluto al file di progetto QGIS (.qgs) che si vuole esportare. Clic sul pulsante "Sfoglia" che si trova a destra per cercare un file di progetto (.qgs).
+<h4>Map file</h4>
+<label>Map file</label> Inserire un nome per il map file da creare. E' possibile
+usare il pulsante a destra per cercare la directory in cui salvare il map
+file creato.
+<h4>Mappa</h4>
+Questi valori vengono scritto nel map file nel posto giusto al fine di impostare
+la dimensione della immagine in output, unita' di misura e tipo di immagine.
+<dl>
+ <dt><label>Nome</label></dt>
+ <dd>Un nome per la mappa. Questo nome vera' usato come prefisso per tutte le immagini generate da MapServer.</dd>
+ <dt><label>Larghezza</label></dt>
+ <dd>Larghezza dell'immagine in pixel.</dd>
+ <dt><label>Altezza</label></dt>
+ <dd>Altezza dell'immagine in pixel.</dd>
+ <dt><label>Unita'</label></dt>
+ <dd>Unita' di misura usata per l'output.</dd>
+ <dt><label>Tipo di immagine</label></dt>
+ <dd>Formato per l'immagine di output generata da MapServer</dd>
+</dl>
+<h4>Percorsi</h4>
+<dl>
+ <dt><label>Template</label></dt>
+ <dd>Percorso assoluto al file template di MapServer da usare con il map file.</dd>
+ <dt><label>Header</label></dt>
+ <dd>Percorso assoluto al file header di MapServer da usare con il map file.</dd>
+ <dt><label>Footer</label></dt>
+ <dd>Percorso assoluto al file footer di MapServer da usare con il map file.</dd>
Added: trunk/qgis/resources/context_help/QgsMeasureDialog-it_IT
--- trunk/qgis/resources/context_help/QgsMeasureDialog-it_IT (rev 0)
+++ trunk/qgis/resources/context_help/QgsMeasureDialog-it_IT 2009-12-24 08:37:52 UTC (rev 12611)
@@ -0,0 +1,6 @@
+<h3>Strumenti di misura</h3>
+Ci sono due strumenti di misura: lunghezza e area. Con questi strumenti di possono misurare distanze e aree sull'area mappa. Attualmente i risultati delle misuresono espressi in unità metriche. Un clic singolo con il tasto destro del mouse interrompe la misura, mentre un doppio clic con il tasto destro inizia una nuova misurazione.
+<h4>Misura di lunghezze</h4>
+Per misurare lunghezze lineari, selezionare il tool e fare clic lungo il percorso da misurare. Viene visualizzata la lunghezza di igni segmento e, al contempo, la lunghezza totale del percorso.
+<h4>Misura di aree</h4>
+Per misurare aree, selezionare il tool e fare clic per disegnare un'area. L'area del poligono disegnato viene dinamicamente calcolata e visualizzata.
\ No newline at end of file
Added: trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-it_IT
--- trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-it_IT (rev 0)
+++ trunk/qgis/resources/context_help/eVisDatabaseConnectionGui-it_IT 2009-12-24 08:37:52 UTC (rev 12611)
@@ -0,0 +1 @@
+<h3>Connessione a Database</h3>
