[QGIS Commit] r12617 - trunk/qgis/src/core
svn_qgis at osgeo.org
Thu Dec 24 11:09:20 EST 2009
Author: jef
Date: 2009-12-24 11:09:19 -0500 (Thu, 24 Dec 2009)
New Revision: 12617
trunk/qgis/src/core/qgsdistancearea.cpp
trunk/qgis/src/core/qgsgeometry.cpp
don't measure empty geometries and also return success when exports geos points to wkb
Modified: trunk/qgis/src/core/qgsdistancearea.cpp
--- trunk/qgis/src/core/qgsdistancearea.cpp 2009-12-24 16:02:02 UTC (rev 12616)
+++ trunk/qgis/src/core/qgsdistancearea.cpp 2009-12-24 16:09:19 UTC (rev 12617)
@@ -175,6 +175,9 @@
double QgsDistanceArea::measure( QgsGeometry* geometry )
+ if ( !geometry )
+ return 0.0;
unsigned char* wkb = geometry->asWkb();
unsigned char* ptr;
unsigned int wkbType;
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp 2009-12-24 16:02:02 UTC (rev 12616)
+++ trunk/qgis/src/core/qgsgeometry.cpp 2009-12-24 16:09:19 UTC (rev 12617)
@@ -1198,8 +1198,8 @@
// Bounds checking
if ( beforeVertex < 0 )
- ( *new_sequence ) = 0;
- return FALSE;
+ *new_sequence = 0;
+ return false;
unsigned int numPoints;
@@ -4335,7 +4335,8 @@
memcpy( mGeometry + 5, &x, sizeof( double ) );
memcpy( mGeometry + 13, &y, sizeof( double ) );
- break;
+ mDirtyWkb = false;
+ return true;
} // case GEOS_GEOM::GEOS_POINT
case GEOS_LINESTRING: // a linestring
