[QGIS Commit] r12640 - trunk/qgis/src/core
svn_qgis at osgeo.org
Mon Dec 28 16:33:39 EST 2009
Author: jef
Date: 2009-12-28 16:33:39 -0500 (Mon, 28 Dec 2009)
New Revision: 12640
trunk/qgis/src/core/qgscoordinatetransform.cpp
fix #2315
Modified: trunk/qgis/src/core/qgscoordinatetransform.cpp
--- trunk/qgis/src/core/qgscoordinatetransform.cpp 2009-12-28 21:32:09 UTC (rev 12639)
+++ trunk/qgis/src/core/qgscoordinatetransform.cpp 2009-12-28 21:33:39 UTC (rev 12640)
@@ -22,7 +22,6 @@
//qt includes
#include <QDomNode>
#include <QDomElement>
-#include <QTextStream>
#include <QApplication>
#include "qgslogger.h"
@@ -227,7 +226,7 @@
catch ( QgsCsException &cse )
// rethrow the exception
- QgsLogger::warning( "Throwing exception " + QString( __FILE__ ) + QString::number( __LINE__ ) );
+ QgsDebugMsg( "rethrowing exception" );
throw cse;
@@ -244,7 +243,7 @@
throw cse;
@@ -270,7 +269,7 @@
throw cse;
@@ -304,7 +303,7 @@
throw cse;
@@ -330,7 +329,7 @@
throw cse;
@@ -394,7 +393,7 @@
throw cse;
@@ -454,42 +453,44 @@
if ( direction == ReverseTransform )
projResult = pj_transform( mDestinationProjection, mSourceProjection, numPoints, 0, x, y, z );
- dir = "inverse";
+ dir = tr( "inverse" );
else
assert( mSourceProjection != 0 );
assert( mDestinationProjection != 0 );
projResult = pj_transform( mSourceProjection, mDestinationProjection, numPoints, 0, x, y, z );
- dir = "forward";
+ dir = tr( "forward" );
if ( projResult != 0 )
//something bad happened....
- QString msg;
- QTextStream pjErr( &msg );
+ QString points;
- pjErr << tr( "Failed" ) << " " << dir << " " << tr( "transform of" ) << '\n';
for ( int i = 0; i < numPoints; ++i )
if ( direction == ForwardTransform )
- pjErr << "(" << x[i] << ", " << y[i] << ")\n";
+ points += QString("(%1, %2)\n").arg( x[i] ).arg( y[i] );
else
- pjErr << "(" << x[i] * RAD_TO_DEG << ", " << y[i] * RAD_TO_DEG << ")\n";
+ points += QString("(%1, %2)\n").arg( x[i]*RAD_TO_DEG ).arg( y[i]*RAD_TO_DEG );
- pjErr << tr( "with error: " ) << QString::fromUtf8( pj_strerrno( projResult ) ) << '\n';
+ QString msg = tr("%1 transform of\n%2\nfailed with error: %3\n")
+ .arg( dir )
+ .arg( points )
+ .arg( QString::fromUtf8( pj_strerrno( projResult ) ) ) );
- QgsDebugMsg( "Projection failed emitting invalid transform signal: " + QString( msg.toLocal8Bit().data() ) );
+ QgsDebugMsg( "Projection failed emitting invalid transform signal: " + msg );
emit invalidTransformInput();
+ QgsDebugMsg( "throwing exception" );
throw QgsCsException( msg );
