[QGIS Commit] r12649 - trunk/qgis/mac/xcode
svn_qgis at osgeo.org
Mon Dec 28 22:52:18 EST 2009
Author: kyngchaos
Date: 2009-12-28 22:52:16 -0500 (Mon, 28 Dec 2009)
New Revision: 12649
trunk/qgis/mac/xcode/ReadMe.rtf
trunk/qgis/mac/xcode/qgis_settings.xcconfig
trunk/qgis/mac/xcode/qgis_user-template.xcconfig
add GSL framework option
Modified: trunk/qgis/mac/xcode/ReadMe.rtf
--- trunk/qgis/mac/xcode/ReadMe.rtf 2009-12-29 03:15:48 UTC (rev 12648)
+++ trunk/qgis/mac/xcode/ReadMe.rtf 2009-12-29 03:52:16 UTC (rev 12649)
@@ -1,4 +1,4 @@
-{\rtf1\ansi\ansicpg1252\cocoartf1038\cocoasubrtf110
+{\rtf1\ansi\ansicpg1252\cocoartf1038\cocoasubrtf250
{\fonttbl\f0\fswiss\fcharset0 Helvetica;\f1\fnil\fcharset0 Monaco;}
{\colortbl;\red255\green255\blue255;}
\vieww10500\viewh12500\viewkind0
@@ -10,7 +10,7 @@
\b0\fs24 \cf0 \
\pard\tx720\tx1440\tx2160\tx2880\tx3600\tx4320\tx5040\tx5760\tx6480\tx7200\tx7920\tx8640\ql\qnatural\pardirnatural
-\i \cf0 2.2.1 2009-9-27\
+\i \cf0 2.3.0 2009-12-28\
\i0 \cf0 \
@@ -51,7 +51,7 @@
\i See note below.
\i0 \
-\ul GSL libraries\ulnone (optional)\
+\ul GSL library or framework\ulnone (optional) - a universal GSL.framework is available.\
\ul Postgres client library\ulnone (optional) - normally available in a full Postgres installation.\
@@ -90,9 +90,9 @@
\cf0 \ul Defaults\
\ulnone \
-The default configuration is for a universal build, with the Leopard (10.5) SDK. GDAL, PROJ, GEOS and SQLite frameworks are used. Spatialite is expected in the SQLite framework. Postgres and GSL are expected in default /usr/local builds. Expat is from the system on Leopard and above, and is expected in /usr/local on Tiger. GRASS support is from a GRASS-6.4.app application. The python.org Python framework is used on Tiger, and the system Python is used on Leopard and above.\
+The default configuration is for a universal build, with the Leopard (10.5) SDK. GDAL, PROJ, GEOS, GSL and SQLite frameworks are used. Spatialite is expected in the SQLite framework. Postgres is expected in default /usr/local builds. Expat is from the system on Leopard and above, and is expected in /usr/local on Tiger. GRASS support is from a GRASS-6.4.app application. The python.org Python framework is used on Tiger, and the system Python is used on Leopard and above.\
-By default, Qt, GSL, the Postgres client library are bundled in the Qgis application.\
+By default, Qt and the Postgres client library are bundled in the Qgis application.\
\ul Minimal Config\ulnone \
@@ -132,16 +132,15 @@
\i space-separated
\i0 list.\
-\pard\tx720\tx1440\tx2160\tx2880\tx3600\tx4320\tx5040\tx5760\tx6480\tx7200\tx7920\tx8640\ql\qnatural\pardirnatural
-\f1\fs20 \cf0 ARCHS_P
+\f1\fs20 ARCHS_P
\f0\fs24 is a list of which architectures to build for Python, this must match the archs in ARCHS. This one is a
\i semicolon-separated
\i0 list.\
-\cf0 \
-\ul Misc Support\
+\pard\tx720\tx1440\tx2160\tx2880\tx3600\tx4320\tx5040\tx5760\tx6480\tx7200\tx7920\tx8640\ql\qnatural\pardirnatural
+\cf0 \ul Misc Support\
\ulnone \
Modified: trunk/qgis/mac/xcode/qgis_settings.xcconfig
--- trunk/qgis/mac/xcode/qgis_settings.xcconfig 2009-12-29 03:15:48 UTC (rev 12648)
+++ trunk/qgis/mac/xcode/qgis_settings.xcconfig 2009-12-29 03:52:16 UTC (rev 12649)
@@ -1,6 +1,6 @@
// QGIS Xcode project common build settings
-CURRENT_PROJECT_VERSION = 2.2.2
+CURRENT_PROJECT_VERSION = 2.3.0
// SDKSYS must be set to valid value
SDKSYS = leo // tig (Tiger), leo (Leopard), snow (Snow Leopard)
@@ -67,7 +67,7 @@
SPATIALITE_GEOS = yes
SPATIALITE_PROJ = yes
-GSL_FORM = shared // static or shared
+GSL_FORM = fw // fw, static or shared
PGSQL_FORM = shared // static or shared
// system expat only on Leopard+
@@ -91,10 +91,10 @@
// bundling GRASS doesn't make sense, as a full GRASS install is required
// Qt always bundled - else Qt plugins will load that cause grief
-BUNDLE_GSL = YES
BUNDLE_PGSQL = YES
BUNDLE_GPSBABEL = YES
// frameworks not bundled
+BUNDLE_GSL = YES
BUNDLE_GDAL = YES
BUNDLE_GEOS = YES
BUNDLE_PROJ = YES
@@ -111,7 +111,8 @@
PROJ_PREFIX_shared = /usr/local
GEOS_PREFIX_shared = /usr/local
-GSL_PREFIX = /usr/local
+GSL_PREFIX_shared = /usr/local
+GSL_PREFIX_static = /usr/local
// This must match exactly how GRASS was built and installed.
// If it was moved or renamed, qgis GRASS plugin will not work.
@@ -278,7 +279,13 @@
EXPAT_LIB_static = $(EXPAT_PREFIX)/lib/libexpat.a
EXPAT_LIB = $(EXPAT_LIB_$(EXPAT_FORM))
-GSL_INC = $(GSL_PREFIX)/include
+GSL_PREFIX_fw = /Library/Frameworks/GSL.framework
+GSL_PREFIX = $(GSL_PREFIX_$(GSL_FORM))
+GSL_INC_fw = $(GSL_PREFIX_fw)/Headers
+GSL_INC_shared = $(GSL_PREFIX)/include
+GSL_INC_static = $(GSL_PREFIX)/include
+GSL_INC = $(GSL_INC_$(GSL_FORM))
+GSL_LIB_fw = -framework GSL
GSL_LIB_shared = -L$(GSL_PREFIX)/lib -lgsl -lm
GSL_LIB_static = $(GSL_PREFIX)/lib/libgsl.a $(GSL_PREFIX)/lib/libgslcblas.a -lm
GSL_LIB = $(GSL_LIB_$(GSL_FORM))
Modified: trunk/qgis/mac/xcode/qgis_user-template.xcconfig
--- trunk/qgis/mac/xcode/qgis_user-template.xcconfig 2009-12-29 03:15:48 UTC (rev 12648)
+++ trunk/qgis/mac/xcode/qgis_user-template.xcconfig 2009-12-29 03:52:16 UTC (rev 12649)
@@ -51,7 +51,7 @@
//SPATIALITE_GEOS = yes
//SPATIALITE_PROJ = yes
-//GSL_FORM = shared // static or shared
+//GSL_FORM = fw // fw, static or shared
//PGSQL_FORM = shared // static or shared
@@ -100,7 +100,8 @@
//PROJ_PREFIX_shared = /usr/local
//GEOS_PREFIX_shared = /usr/local
-//GSL_PREFIX = /usr/local
+//GSL_PREFIX_shared = /usr/local
+//GSL_PREFIX_static = /usr/local
@@ -140,7 +141,7 @@
//EXPAT_INC = $(EXPAT_INC_$(EXPAT_FORM))
//EXPAT_LIB = $(EXPAT_LIB_$(EXPAT_FORM))
-//GSL_INC = $(GSL_PREFIX)/include
+//GSL_INC = $(GSL_INC_$(GSL_FORM))
//GSL_LIB = $(GSL_LIB_$(GSL_FORM))
//PGSQL_INC = $(PGSQL_PREFIX)/include
