[QGIS Commit] r10111 - in trunk/qgis/src/plugins: delimited_text
georeferencer
svn_qgis at osgeo.org
Thu Feb 5 09:25:51 EST 2009
Author: jef
Date: 2009-02-05 09:25:51 -0500 (Thu, 05 Feb 2009)
New Revision: 10111
trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp
trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp
fix compile errors
Modified: trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp
--- trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp 2009-02-05 12:08:40 UTC (rev 10110)
+++ trunk/qgis/src/plugins/delimited_text/qgsdelimitedtextplugingui.cpp 2009-02-05 14:25:51 UTC (rev 10111)
@@ -213,7 +213,7 @@
// put a few more lines into the sample box
int counter = 0;
line = QgsDelimitedTextPluginGui::readLine( stream );
- while ( not line.isEmpty() && ( counter < 20 ) )
+ while ( !line.isEmpty() && ( counter < 20 ) )
txtSample->insertPlainText( line + "\n" );
counter++;
@@ -273,15 +273,15 @@
// Strip leading newlines
c = stream.read( 1 );
- if ( c == NULL or c.size() == 0 )
+ if ( c == NULL || c.size() == 0 )
// Reach end of file
return buffer;
- while ( c == (char *)"\r" or c == (char *)"\n" )
+ while ( c == (char *)"\r" || c == (char *)"\n" )
return buffer;
@@ -292,18 +292,18 @@
buffer.append( c );
return buffer;
- while ( not ( c == (char *)"\r" or c == (char *)"\n" ) )
+ while ( !( c == (char *)"\r" || c == (char *)"\n" ) )
buffer.append( c );
return buffer;
Modified: trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp
--- trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp 2009-02-05 12:08:40 UTC (rev 10110)
+++ trunk/qgis/src/plugins/georeferencer/mapcoordsdialog.cpp 2009-02-05 14:25:51 UTC (rev 10111)
@@ -21,10 +21,10 @@
MapCoordsDialog::MapCoordsDialog()
- this->setWindowFlags(!Qt::Dialog);
- this->setWindowFlags(Qt::WindowSystemMenuHint);
- this->setWindowFlags(Qt::WindowMinimizeButtonHint);
- this->setWindowFlags(Qt::WindowMaximizeButtonHint);
+ // setWindowFlags(!Qt::Dialog);
+ setWindowFlags(Qt::WindowSystemMenuHint);
+ setWindowFlags(Qt::WindowMinimizeButtonHint);
+ setWindowFlags(Qt::WindowMaximizeButtonHint);
