[QGIS Commit] r10125 - trunk/qgis
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Feb 7 13:57:00 EST 2009
Author: gsherman
Date: 2009-02-07 13:57:00 -0500 (Sat, 07 Feb 2009)
New Revision: 10125
   trunk/qgis/Doxyfile
Added search capability to document generation
Modified: trunk/qgis/Doxyfile
--- trunk/qgis/Doxyfile	2009-02-07 15:03:25 UTC (rev 10124)
+++ trunk/qgis/Doxyfile	2009-02-07 18:57:00 UTC (rev 10125)
@@ -25,7 +25,7 @@
 # automatically updated by the documentation process. If you run doxygen
 # manually, the revision number may not reflect the current revision.
-PROJECT_NUMBER = HEAD-r8279
+PROJECT_NUMBER = HEAD-r10124
 # The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
 # base path where the generated documentation will be put.
@@ -1259,4 +1259,4 @@
 # The SEARCHENGINE tag specifies whether or not a search engine should be
 # used. If set to NO the values of all tags below this one will be ignored.
-SEARCHENGINE           = NO
+SEARCHENGINE           = YES
More information about the QGIS-commit mailing list
