[QGIS Commit] r10185 -
branches/vector_overlay_branch/src/plugins/diagram_overlay
svn_qgis at osgeo.org
Tue Feb 17 07:22:25 EST 2009
Author: mhugent
Date: 2009-02-17 07:22:25 -0500 (Tue, 17 Feb 2009)
New Revision: 10185
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.cpp
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp
branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp
more diagram improvements
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp 2009-02-17 09:05:11 UTC (rev 10184)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramdialog.cpp 2009-02-17 12:22:25 UTC (rev 10185)
@@ -173,7 +173,7 @@
//attList comes from the diagram factory widget
- QgsAttributeList attList = diagramFactory->categoryAttributes();
+ QgsAttributeList attList;
QgsDiagramRenderer* diagramRenderer = 0;
QgsDiagramFactory::SizeUnit diagramSizeUnit = QgsDiagramFactory::MM; //mm on output medium is default
@@ -195,7 +195,9 @@
diagramRenderer->setFactory(diagramFactory);
- diagramFactory->setScalingAttributes(attList);
+ QgsAttributeList scalingAttributeList;
+ scalingAttributeList.push_back(classAttr);
+ diagramFactory->setScalingAttributes(scalingAttributeList);
//also set units to the diagram factory
diagramFactory->setSizeUnit(diagramSizeUnit);
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.cpp 2009-02-17 09:05:11 UTC (rev 10184)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.cpp 2009-02-17 12:22:25 UTC (rev 10185)
@@ -46,3 +46,43 @@
return 1.0;
+ bool QgsDiagramFactory::writeScalingAttributesToXML(QDomElement& factoryElem, QDomDocument& doc) const
+ if(factoryElem.isNull())
+ return false;
+ QgsAttributeList::const_iterator it = mScalingAttributes.constBegin();
+ for(; it != mScalingAttributes.constEnd(); ++it)
+ QDomElement scalingAttributeElem = doc.createElement("scalingAttribute");
+ QDomText scalingAttributeText = doc.createTextNode(QString::number(*it));
+ scalingAttributeElem.appendChild(scalingAttributeText);
+ factoryElem.appendChild(scalingAttributeElem);
+ return false;
+ bool QgsDiagramFactory::readScalingAttributesFromXML(const QDomElement& factoryElem)
+ return false;
+ mScalingAttributes.clear();
+ QDomNodeList scalingAttributeList = factoryElem.elementsByTagName("scalingAttribute");
+ for(int i = 0; i < scalingAttributeList.size(); ++i)
+ QDomElement currentScalingElem = scalingAttributeList.at(i).toElement();
+ bool conversionSuccess = false;
+ int currentIndex = currentScalingElem.text().toInt(&conversionSuccess);
+ if(conversionSuccess)
+ mScalingAttributes.push_back(currentIndex);
+ return true;
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h 2009-02-17 09:05:11 UTC (rev 10184)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramfactory.h 2009-02-17 12:22:25 UTC (rev 10185)
@@ -25,6 +25,7 @@
class QgsFeature;
class QgsRenderContext;
class QDomDocument;
+class QDomElement;
class QDomNode;
class QImage;
@@ -83,13 +84,10 @@
void setSizeUnit(SizeUnit u){mSizeUnit = u;}
SizeUnit sizeUnit() const {return mSizeUnit;}
- //setters and getters for scaling attribute
+ //setters and getters for scaling attributes
QgsAttributeList scalingAttributes() const {return mScalingAttributes;}
void setScalingAttributes(const QgsAttributeList& att){mScalingAttributes = att;}
- /**Returns the attributes represented in the pies / bars*/
- virtual QgsAttributeList categoryAttributes() const {return QgsAttributeList();}
/**Read settings from project file*/
virtual bool readXML(const QDomNode& factoryNode) = 0;
@@ -98,8 +96,14 @@
SizeUnit mSizeUnit;
/**List of scaling attribute indexes (the values are summed up to
- receive the scaling value)*/
+ receive the value that is used for diagram size calculation)*/
QgsAttributeList mScalingAttributes;
+ /**Writes the scaling attributes indices to project file. Usually called from subclasses*/
+ bool writeScalingAttributesToXML(QDomElement& factoryElem, QDomDocument& doc) const;
+ /**Reads the scaling attributes from project file. Usually called from subclasses*/
+ bool readScalingAttributesFromXML(const QDomElement& factoryElem);
#endif
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-02-17 09:05:11 UTC (rev 10184)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-02-17 12:22:25 UTC (rev 10185)
@@ -238,7 +238,7 @@
return false;
- if(!newFactory->readXML(overlayNode))
+ if(!newFactory->readXML(factoryElem))
delete newFactory;
return false;
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp 2009-02-17 09:05:11 UTC (rev 10184)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgssvgdiagramfactory.cpp 2009-02-17 12:22:25 UTC (rev 10185)
@@ -97,12 +97,39 @@
svgPathElem.appendChild(svgPathText);
factoryElem.appendChild(svgPathElem);
overlay_node.appendChild(factoryElem);
+ //and superclass specific information
+ writeScalingAttributesToXML(factoryElem, doc);
return true;
bool QgsSVGDiagramFactory::readXML(const QDomNode& factoryNode)
- //soon...
+ QDomElement factoryElem = factoryNode.toElement();
+ return false;
+ //get <svgPath> element
+ QDomElement svgPathElem = factoryElem.namedItem("svgPath").toElement();
+ if(svgPathElem.isNull())
+ return false;
+ QString svgFilePath = svgPathElem.text();
+ if(!mRenderer.load(svgFilePath))
+ return false;
+ mSvgFilePath = svgFilePath;
+ //read scaling attributes by superclass
+ readScalingAttributesFromXML(factoryElem);
+ return true;
Modified: branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp
--- branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp 2009-02-17 09:05:11 UTC (rev 10184)
+++ branches/vector_overlay_branch/src/plugins/diagram_overlay/qgswkndiagramfactory.cpp 2009-02-17 12:22:25 UTC (rev 10185)
@@ -56,7 +56,7 @@
QDomText wknText = doc.createTextNode(mDiagramType);
wellKnownNameElem.appendChild(wknText);
factoryElement.appendChild(wellKnownNameElem);
//classification fields
QList<int>::const_iterator scaling_it = mScalingAttributes.constBegin();
for(; scaling_it != mScalingAttributes.constEnd(); ++scaling_it)
@@ -99,6 +99,9 @@
//write subclass specific information
_writeXML(factoryElement, doc);
+ writeScalingAttributesToXML(factoryElement, doc);
return true;
@@ -191,5 +194,9 @@
mCategories.push_back(newCategory);
return true;
