[QGIS Commit] r9983 - trunk/qgis/python/plugins/mapserver_export
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jan 19 14:53:23 EST 2009
Author: wonder
Date: 2009-01-19 14:53:23 -0500 (Mon, 19 Jan 2009)
New Revision: 9983
   trunk/qgis/python/plugins/mapserver_export/mapserverexport.py
   trunk/qgis/python/plugins/mapserver_export/ms_export.py
mapserver export: fixed i18n problems, fixed continuous color renderer export
Modified: trunk/qgis/python/plugins/mapserver_export/mapserverexport.py
--- trunk/qgis/python/plugins/mapserver_export/mapserverexport.py	2009-01-19 19:16:14 UTC (rev 9982)
+++ trunk/qgis/python/plugins/mapserver_export/mapserverexport.py	2009-01-19 19:53:23 UTC (rev 9983)
@@ -78,17 +78,17 @@
     if result == 1:
       # get the settings from the dialog and export the map file
       print "Creating exporter using %s and %s" % (self.dlg.ui.txtQgisFilePath.text(), self.dlg.ui.txtMapFilePath.text())
-      exporter = Qgis2Map(str(self.dlg.ui.txtQgisFilePath.text()), str(self.dlg.ui.txtMapFilePath.text()))
+      exporter = Qgis2Map(unicode(self.dlg.ui.txtQgisFilePath.text()), unicode(self.dlg.ui.txtMapFilePath.text()))
       print "Setting options"
       exporter.setOptions(
-          self.dlg.ui.cmbMapUnits.itemData( self.dlg.ui.cmbMapUnits.currentIndex() ).toString(),
-          self.dlg.ui.cmbMapImageType.currentText(),
-          self.dlg.ui.txtMapName.text(),
-          self.dlg.ui.txtMapWidth.text(),
-          self.dlg.ui.txtMapHeight.text(),
-          self.dlg.ui.txtWebTemplate.text(),
-          self.dlg.ui.txtWebFooter.text(),
-          self.dlg.ui.txtWebHeader.text()
+          unicode(self.dlg.ui.cmbMapUnits.itemData( self.dlg.ui.cmbMapUnits.currentIndex() ).toString()),
+          unicode(self.dlg.ui.cmbMapImageType.currentText()),
+          unicode(self.dlg.ui.txtMapName.text()),
+          unicode(self.dlg.ui.txtMapWidth.text()),
+          unicode(self.dlg.ui.txtMapHeight.text()),
+          unicode(self.dlg.ui.txtWebTemplate.text()),
+          unicode(self.dlg.ui.txtWebFooter.text()),
+          unicode(self.dlg.ui.txtWebHeader.text())
       print "Calling writeMapFile"
       result = exporter.writeMapFile()
Modified: trunk/qgis/python/plugins/mapserver_export/ms_export.py
--- trunk/qgis/python/plugins/mapserver_export/ms_export.py	2009-01-19 19:16:14 UTC (rev 9982)
+++ trunk/qgis/python/plugins/mapserver_export/ms_export.py	2009-01-19 19:53:23 UTC (rev 9983)
@@ -53,17 +53,17 @@
   # Set the options collected from the GUI
   def setOptions(self, units, image, mapname, width, height, template, header, footer):
-    self.units = units
-    self.imageType = str(image)
-    self.mapName = mapname
-    self.width = width
-    self.height = height
+    self.units = units.encode('utf-8')
+    self.imageType = image.encode('utf-8')
+    self.mapName = mapname.encode('utf-8')
+    self.width = width.encode('utf-8')
+    self.height = height.encode('utf-8')
     #self.minimumScale = minscale
     #self.maximumScale = maxscale
-    self.template = template
-    self.header = header
-    self.footer = footer
-    print units, image, mapname, width, height, template, header, footer
+    self.template = template.encode('utf-8')
+    self.header = header.encode('utf-8')
+    self.footer = footer.encode('utf-8')
+    #print units, image, mapname, width, height, template, header, footer
   ## All real work happens here by calling methods to write the
   ## various sections of the map file
@@ -121,7 +121,7 @@
   # Write the general parts of the map section
   def writeMapSection(self):
-    self.outFile.write("# Map file created from QGIS project file " + self.project + "\n")
+    self.outFile.write("# Map file created from QGIS project file " + self.project.encode('utf-8') + "\n")
     self.outFile.write("# Edit this file to customize for your map interface\n")
     self.outFile.write("# (Created with PyQgis MapServer Export plugin)\n")
     self.outFile.write("MAP\n")
@@ -417,10 +417,10 @@
     # outline color
     outlineNode = symbolNode.getElementsByTagName('outlinecolor')[0]
-    class_def += "         OUTLINECOLOR " + outlineNode.getAttribute('red') + ' ' + outlineNode.getAttribute('green') + ' ' + outlineNode.getAttribute('blue') + "\n"
+    class_def += "         OUTLINECOLOR " + outlineNode.getAttribute('red').encode('utf-8') + ' ' + outlineNode.getAttribute('green').encode('utf-8') + ' ' + outlineNode.getAttribute('blue').encode('utf-8') + "\n"
     # color
     colorNode = symbolNode.getElementsByTagName('fillcolor')[0]
-    class_def += "         COLOR " + colorNode.getAttribute('red') + ' ' + colorNode.getAttribute('green') + ' ' + colorNode.getAttribute('blue') + "\n"
+    class_def += "         COLOR " + colorNode.getAttribute('red').encode('utf-8') + ' ' + colorNode.getAttribute('green').encode('utf-8') + ' ' + colorNode.getAttribute('blue').encode('utf-8') + "\n"
     class_def += "       END\n"
@@ -469,10 +469,10 @@
       # outline color
       outlineNode = cls.getElementsByTagName('outlinecolor')[0]
       # color
       colorNode = cls.getElementsByTagName('fillcolor')[0]
@@ -493,7 +493,7 @@
     classField = layerNode.getElementsByTagName('classificationattribute')[0].childNodes[0].nodeValue.encode('utf-8')
     # write the rendering info for each class
-    class_def += "    CLASS\n"
+    class_def = "    CLASS\n"
     # Class name irrelevant for color ramps since mapserver can't render their legend
     #self.outFile.write("      NAME '" + classField + "'\n")
@@ -510,7 +510,7 @@
     class_def += "      STYLE\n"
     # The first and last color of the ramp ( r g b r g b )
-    class_def += "        COLORRANGE " + lowerColor.getAttribute('red') + " " + lowerColor.getAttribute('green') + " " + lowerColor.getAttribute('blue') + " " + upperColor.getAttribute('red') + " " + upperColor.getAttribute('green') + " " + upperColor.getAttribute('blue') + "\n"
+    class_def += "        COLORRANGE " + lowerColor.getAttribute('red').encode('utf-8') + " " + lowerColor.getAttribute('green').encode('utf-8') + " " + lowerColor.getAttribute('blue').encode('utf-8') + " " + upperColor.getAttribute('red').encode('utf-8') + " " + upperColor.getAttribute('green').encode('utf-8') + " " + upperColor.getAttribute('blue').encode('utf-8') + "\n"
     # The range of values over which to ramp the colors
     class_def += "        DATARANGE " + lower.getElementsByTagName('lowervalue')[0].childNodes[0].nodeValue.encode('utf-8') + ' ' + upper.getElementsByTagName('lowervalue')[0].childNodes[0].nodeValue.encode('utf-8') + '\n'
@@ -519,7 +519,7 @@
-    class_def += "        OUTLINECOLOR " + outlineNode.getAttribute('red') + " " + outlineNode.getAttribute('green') + " " + outlineNode.getAttribute('blue') + "\n"
+    class_def += "        OUTLINECOLOR " + outlineNode.getAttribute('red').encode('utf-8') + " " + outlineNode.getAttribute('green').encode('utf-8') + " " + outlineNode.getAttribute('blue').encode('utf-8') + "\n"
     # label
@@ -577,17 +577,17 @@
       # outline color
       class_def += "         OUTLINECOLOR "  \
-            + outlineNode.getAttribute('red') + ' ' \
-            + outlineNode.getAttribute('green') + ' ' \
-            + outlineNode.getAttribute('blue') \
+            + outlineNode.getAttribute('red').encode('utf-8') + ' ' \
+            + outlineNode.getAttribute('green').encode('utf-8') + ' ' \
+            + outlineNode.getAttribute('blue').encode('utf-8') \
             + "\n"
       # color
       class_def += "         COLOR "  \
-            + colorNode.getAttribute('red') + ' ' \
-            + colorNode.getAttribute('green') + ' ' \
-            + colorNode.getAttribute('blue') \
+            + colorNode.getAttribute('red').encode('utf-8') + ' ' \
+            + colorNode.getAttribute('green').encode('utf-8') + ' ' \
+            + colorNode.getAttribute('blue').encode('utf-8') \
             + "\n"
More information about the QGIS-commit mailing list
