[QGIS Commit] r10005 - in docs: tags/1.0.0_user_guide
trunk/english_us/user_guide
svn_qgis at osgeo.org
Sat Jan 24 01:59:55 EST 2009
Author: dassau
Date: 2009-01-24 01:59:54 -0500 (Sat, 24 Jan 2009)
New Revision: 10005
docs/tags/1.0.0_user_guide/working_with_vector.tex
docs/trunk/english_us/user_guide/working_with_vector.tex
some small fixes
Modified: docs/tags/1.0.0_user_guide/working_with_vector.tex
--- docs/tags/1.0.0_user_guide/working_with_vector.tex 2009-01-23 17:11:30 UTC (rev 10004)
+++ docs/tags/1.0.0_user_guide/working_with_vector.tex 2009-01-24 06:59:54 UTC (rev 10005)
@@ -946,7 +946,7 @@
\begin{Tip}[ht]\caption{\textsc{Vertex Markers}}
\qgistip{
-The current version of QGIS supports several two kinds of vertex-markers -
+The current version of QGIS supports two kinds of vertex-markers -
a semi-transparent circle or a cross. To change the marker style, choose
\dropmenuopttwo{mActionOptions}{Options} from the
\mainmenuopt{Settings} menu and click on the \tab{Digitizing} tab and select
@@ -981,7 +981,7 @@
You can also use the spacebar to temporarily cause mouse movements to pan
then map. The PgUp and PgDown keys on your keyboard will cause the map
-display to zoom in or our without interupting your digitising session.
+display to zoom in or out without interrupting your digitising session.
You can perform the following editing functions:
@@ -1086,7 +1086,7 @@
\end{itemize}
You will need to set the property
-\mainmenuopt{Settings}>\dropmenuopttwo{mActionOptions}{Options}>\tab{Digitizing}
+\mainmenuopt{Settings}>\dropmenuopttwo{mActionOptions}{Options}>\tab{Digitizing}>\selectnumber{Search Radius}{10}
to a number greater than zero. Otherwise QGIS will not be able to tell which feature is being edited.
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2009-01-23 17:11:30 UTC (rev 10004)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2009-01-24 06:59:54 UTC (rev 10005)
@@ -946,7 +946,7 @@
\qgistip{
@@ -981,7 +981,7 @@
\end{itemize}
