[QGIS Commit] r10039 - trunk/qgis/python/plugins/ftools/tools
svn_qgis at osgeo.org
Wed Jan 28 20:35:32 EST 2009
Author: cfarmer
Date: 2009-01-28 20:35:32 -0500 (Wed, 28 Jan 2009)
New Revision: 10039
trunk/qgis/python/plugins/ftools/tools/doGeoprocessing.py
handle problem geometries more gracefully, check for crs differences
Modified: trunk/qgis/python/plugins/ftools/tools/doGeoprocessing.py
--- trunk/qgis/python/plugins/ftools/tools/doGeoprocessing.py 2009-01-29 00:31:27 UTC (rev 10038)
+++ trunk/qgis/python/plugins/ftools/tools/doGeoprocessing.py 2009-01-29 01:35:32 UTC (rev 10039)
@@ -152,14 +152,18 @@
def cancelThread( self ):
self.testThread.stop()
- def runFinishedFromThread( self, success ):
+ def runFinishedFromThread( self, results ):
self.cancel_close.setText( "Close" )
- if success:
- QObject.disconnect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
+ QObject.disconnect( self.cancel_close, SIGNAL( "clicked()" ), self.cancelThread )
+ if results[0]:
+ if not results[1]:
+ out_text = self.tr( "\n\nWarning: Different input coordinate reference systems detected, results may not be as expected.")
+ else:
+ out_text = ""
addToTOC = QMessageBox.question( self, "Geoprocessing", self.tr( "Created output shapefile:" ) + "\n" +
- unicode( self.shapefileName ) + "\n\n" + self.tr( "Would you like to add the new layer to the TOC?" ),
- QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton )
+ unicode( self.shapefileName ) + "\n\n" + self.tr( "Would you like to add the new layer to the TOC?" )
+ + out_text, QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton )
if addToTOC == QMessageBox.Yes:
ftools_utils.addShapeToCanvas( unicode( self.shapefileName ) )
else:
@@ -193,24 +197,24 @@
( self.myParam, useField ) = self.checkParameter( self.vlayerA, self.myParam )
if not self.myParam is None:
if self.myFunction == 1:
- success = self.buffering( useField )
+ success, match = self.buffering( useField )
elif self.myFunction == 2:
- success = self.convex_hull( useField )
+ success, match = self.convex_hull( useField )
elif self.myFunction == 4:
- success = self.dissolve( useField )
+ success, match = self.dissolve( useField )
else:
self.vlayerB = ftools_utils.getVectorLayerByName( self.myLayerB )
if self.myFunction == 3:
- success = self.difference()
+ success, match = self.difference()
elif self.myFunction == 5:
- success = self.intersect()
+ success, match = self.intersect()
elif self.myFunction == 6:
- success = self.union()
+ success, match = self.union()
elif self.myFunction == 7:
- success = self.symetrical_difference()
+ success, match = self.symetrical_difference()
elif self.myFunction == 8:
- success = self.clip()
- self.emit( SIGNAL( "runFinished(PyQt_PyObject)" ), success )
+ success, match = self.clip()
+ self.emit( SIGNAL( "runFinished(PyQt_PyObject)" ), (success, match) )
self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
def stop(self):
@@ -242,13 +246,13 @@
value = atMap[ self.myParam ].toDouble()[ 0 ]
else:
value = self.myParam
- inGeom = inFeat.geometry()
- outGeom = inGeom.buffer( float( value ), 5 )
+ inGeom = QgsGeometry( inFeat.geometry() )
+ outGeom = QgsGeometry( inGeom.buffer( float( value ), 5 ) )
if first:
tempGeom = QgsGeometry( outGeom )
first = False
else:
- tempGeom = tempGeom.combine( QgsGeometry( outGeom ) )
+ tempGeom = QgsGeometry( tempGeom.combine( outGeom ) )
outFeat.setGeometry( tempGeom )
writer.addFeature( outFeat )
else:
@@ -261,13 +265,13 @@
else:
outFeat.setGeometry( outGeom )
outFeat.setAttributeMap( atMap )
- del writer
- return True
+ del writer
+ return True, True
def convex_hull(self, useField ):
vproviderA = self.vlayerA.dataProvider()
@@ -300,11 +304,12 @@
if first:
outID = idVar
first = False
points = ftools_utils.extractPoints( inGeom )
hull.extend( points )
if len( hull ) >= 3:
- outGeom = outGeom.fromMultiPoint( hull ).convexHull()
+ tmpGeom = QgsGeometry( outGeom.fromMultiPoint( hull ) )
+ outGeom = QgsGeometry( tmpGeom.convexHull() )
(area, perim) = self.simpleMeasure( outGeom )
outFeat.addAttribute( 0, QVariant( outID ) )
@@ -321,14 +326,15 @@
while vproviderA.nextFeature( inFeat ):
nElement += 1
self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
- outFeat.setGeometry(outGeom)
+ outFeat.setGeometry( outGeom )
del writer
- return True
+ return True, True
def dissolve( self, useField ):
@@ -339,42 +345,55 @@
fields, vproviderA.geometryType(), vproviderA.crs() )
inFeat = QgsFeature()
outFeat = QgsFeature()
- inGeom = QgsGeometry()
- outGeom = QgsGeometry()
vproviderA.rewind()
- if useField:
- unique = ftools_utils.getUniqueValues( vproviderA, int( self.myParam ) )
- else:
- unique = [ 1 ]
- nFeat = vproviderA.featureCount() * len( unique )
+ nFeat = vproviderA.featureCount()
nElement = 0
- self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0)
- self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, nFeat ) )
- for item in unique:
+ if not useField:
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0)
+ self.emit( SIGNAL( "runRange(PyQt_PyObject)" ), ( 0, nFeat ) )
first = True
- vproviderA.rewind()
nElement += 1
- if not useField:
- if first:
- attrs = inFeat.attributeMap()
- outFeat.setGeometry( QgsGeometry( inFeat.geometry() ) )
- first = False
- else:
- outFeat.setGeometry( QgsGeometry( outFeat.geometry().combine( inFeat.geometry() ) ) )
+ if first:
+ attrs = inFeat.attributeMap()
+ tmpInGeom = QgsGeometry( inFeat.geometry() )
+ outFeat.setGeometry( tmpInGeom )
+ first = False
else:
+ tmpOutGeom = QgsGeometry( outFeat.geometry() )
+ tmpOutGeom = QgsGeometry( tmpOutGeom.combine( tmpInGeom ) )
+ outFeat.setGeometry( tmpOutGeom )
+ outFeat.setAttributeMap( attrs )
+ writer.addFeature( outFeat )
+ else:
+ unique = ftools_utils.getUniqueValues( vproviderA, int( self.myParam ) )
+ nFeat = nFeat * len( unique )
+ for item in unique:
+ first = True
+ vproviderA.rewind()
+ while vproviderA.nextFeature( inFeat ):
+ nElement += 1
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), nElement )
if inFeat.attributeMap()[ self.myParam ].toString().trimmed() == item.toString().trimmed():
if first:
+ QgsGeometry( inFeat.geometry() )
first = False
else:
- outFeat.setAttributeMap( attrs )
- writer.addFeature( outFeat )
del writer
- return True
+ return True, True
def difference( self ):
@@ -384,12 +403,13 @@
allAttrsB = vproviderB.attributeIndexes()
vproviderB.select( allAttrsB )
fields = vproviderA.fields()
+ if vproviderA.crs() == vproviderB.crs(): crs_match = True
+ else: crs_match = False
writer = QgsVectorFileWriter( self.myName, self.myEncoding,
inFeatA = QgsFeature()
inFeatB = QgsFeature()
- geom = QgsGeometry()
index = ftools_utils.createIndex( vproviderB )
nElement = 0
@@ -399,18 +419,19 @@
while vproviderA.nextFeature( inFeatA ):
nElement += 1
- geom = inFeatA.geometry()
+ geom = QgsGeometry( inFeatA.geometry() )
atMap = inFeatA.attributeMap()
intersects = index.intersects( geom.boundingBox() )
- for _id in intersects:
- vproviderB.featureAtId( int( _id ), inFeatB , True, allAttrsB )
- if geom.intersects( inFeatB.geometry() ):
- geom = geom.difference( inFeatB.geometry() )
+ for id in intersects:
+ vproviderB.featureAtId( int( id ), inFeatB , True, allAttrsB )
+ tmpGeom = QgsGeometry( inFeatB.geometry() )
+ if geom.intersects( tmpGeom ):
+ geom = geom.difference( tmpGeom )
outFeat.setGeometry( geom )
del writer
- return True
+ return True, crs_match
def intersect( self ):
@@ -419,13 +440,14 @@
vproviderB = self.vlayerB.dataProvider()
fields = ftools_utils.combineVectorFields( self.vlayerA, self.vlayerB )
nElement = 0
@@ -435,20 +457,21 @@
nElement += 1
atMapA = inFeatA.attributeMap()
atMapB = inFeatB.attributeMap()
- result = geom.intersection( inFeatB.geometry() )
- outFeat.setGeometry( result )
+ geom = geom.intersection( tmpGeom )
+ outFeat.setGeometry( geom )
outFeat.setAttributeMap( ftools_utils.combineVectorAttributes( atMapA, atMapB ) )
del writer
- return True
def union( self ):
allAttrsA = vproviderA.attributeIndexes()
@@ -456,14 +479,14 @@
- diffGeom = QgsGeometry()
indexA = ftools_utils.createIndex( vproviderB )
indexB = ftools_utils.createIndex( vproviderA )
nFeat = vproviderA.featureCount() * vproviderB.featureCount()
@@ -484,21 +507,22 @@
outFeat.setAttributeMap( atMapA )
else:
found = True
- diffGeom = diffGeom.difference( inFeatB.geometry() )
+ diffGeom = diffGeom.difference( tmpGeom )
if found:
outFeat.setGeometry( diffGeom )
- length = len( atMapA.values() )
+ length = len( vproviderA.fields().values() )
vproviderB.rewind()
while vproviderB.nextFeature( inFeatA ):
nElement += 1
@@ -512,16 +536,17 @@
else:
- vproviderA.featureAtId( int( _id ), inFeatB , True, allAttrsA )
+ vproviderA.featureAtId( int( id ), inFeatB , True, allAttrsA )
del writer
- return True
def symetrical_difference( self ):
@@ -530,13 +555,14 @@
@@ -547,34 +573,36 @@
nElement += 1
intersects = indexA.intersects( geom.boundingBox() )
vproviderB.rewind()
nElement += 1
atMap = inFeatA.attributeMap().values()
atMap = dict( zip( range( length, length + len( atMap ) ), atMap ) )
intersects = indexB.intersects( geom.boundingBox() )
del writer
- return True
def clip( self ):
@@ -583,35 +611,36 @@
- index = ftools_utils.createIndex(vproviderB)
+ index = ftools_utils.createIndex( vproviderB )
nElement = 0
+ self.emit( SIGNAL( "runStatus(PyQt_PyObject)" ), 0 )
vproviderA.rewind()
nElement += 1
- outGeom = geom.intersection( inFeatB.geometry() )
- outFeat.setGeometry( outGeom )
+ geom= geom.intersection( tmpGeom )
del writer
- return True
def checkParameter( self, layer, param ):
