[QGIS Commit] r10990 - in trunk/qgis/src: app app/attributetable
core
svn_qgis at osgeo.org
Wed Jul 1 03:29:10 EDT 2009
Author: mhugent
Date: 2009-07-01 03:29:08 -0400 (Wed, 01 Jul 2009)
New Revision: 10990
trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
trunk/qgis/src/app/qgsattributedialog.cpp
trunk/qgis/src/app/qgsmaptoolidentify.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.h
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/core/qgsvectorlayer.h
[FEATURE] Possibility to add attribute aliases for vector layers. The aliases are shown in the infotool and attribute table to have more descriptive names
Modified: trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp
--- trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-06-30 14:48:27 UTC (rev 10989)
+++ trunk/qgis/src/app/attributetable/qgsattributetablemodel.cpp 2009-07-01 07:29:08 UTC (rev 10990)
@@ -144,6 +144,7 @@
loadLayer();
emit modelChanged();
+ emit headerDataChanged ( Qt::Horizontal, 0, columnCount());
void QgsAttributeTableModel::loadLayer()
@@ -272,8 +273,13 @@
else
- QgsField field = mLayer->pendingFields()[ mAttributes[section] ]; //column
- return QVariant( field.name() );
+ QString attributeName = mLayer->attributeAlias( mAttributes[section] );
+ if(attributeName.isEmpty())
+ QgsField field = mLayer->pendingFields()[ mAttributes[section] ];
+ attributeName = field.name();
+ return QVariant(attributeName);
else return QVariant();
Modified: trunk/qgis/src/app/qgsattributedialog.cpp
--- trunk/qgis/src/app/qgsattributedialog.cpp 2009-06-30 14:48:27 UTC (rev 10989)
+++ trunk/qgis/src/app/qgsattributedialog.cpp 2009-07-01 07:29:08 UTC (rev 10990)
@@ -101,7 +101,13 @@
++it )
const QgsField &field = theFieldMap[it.key()];
- QString myFieldName = field.name();
+ //show attribute alias if available
+ QString myFieldName = vl->attributeAlias(it.key());
+ if(myFieldName.isEmpty())
+ myFieldName = field.name();
int myFieldType = field.type();
QLabel * mypLabel = new QLabel();
mypInnerLayout->addWidget( mypLabel, index, 0 );
Modified: trunk/qgis/src/app/qgsmaptoolidentify.cpp
--- trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-06-30 14:48:27 UTC (rev 10989)
+++ trunk/qgis/src/app/qgsmaptoolidentify.cpp 2009-07-01 07:29:08 UTC (rev 10990)
@@ -337,7 +337,12 @@
featureNode->setText( 1, it->toString() );
- mResults->addAttribute( featureNode, fields[it.key()].name(), it->isNull() ? "NULL" : it->toString() );
+ QString attributeName = layer->attributeAlias(it.key());
+ attributeName = fields[it.key()].name();
+ mResults->addAttribute( featureNode, attributeName, it->isNull() ? "NULL" : it->toString() );
// Calculate derived attributes and insert:
@@ -531,4 +536,4 @@
\ No newline at end of file
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-06-30 14:48:27 UTC (rev 10989)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2009-07-01 07:29:08 UTC (rev 10990)
@@ -146,7 +146,7 @@
tblAttributes->clear();
- tblAttributes->setColumnCount( 8 );
+ tblAttributes->setColumnCount( 9 );
tblAttributes->setRowCount( fields.size() );
tblAttributes->setHorizontalHeaderItem( 0, new QTableWidgetItem( tr( "id" ) ) );
tblAttributes->setHorizontalHeaderItem( 1, new QTableWidgetItem( tr( "name" ) ) );
@@ -156,6 +156,7 @@
tblAttributes->setHorizontalHeaderItem( 5, new QTableWidgetItem( tr( "comment" ) ) );
tblAttributes->setHorizontalHeaderItem( 6, new QTableWidgetItem( tr( "edit widget" ) ) );
tblAttributes->setHorizontalHeaderItem( 7, new QTableWidgetItem( tr( "values" ) ) );
+ tblAttributes->setHorizontalHeaderItem( 8, new QTableWidgetItem( tr( "alias" ) ) );
tblAttributes->setSelectionBehavior( QAbstractItemView::SelectRows );
tblAttributes->setSelectionMode( QAbstractItemView::MultiSelection );
@@ -174,7 +175,7 @@
tblAttributes->setItem( row, 2, new QTableWidgetItem( field.typeName() ) );
tblAttributes->setItem( row, 3, new QTableWidgetItem( QString::number( field.length() ) ) );
tblAttributes->setItem( row, 4, new QTableWidgetItem( QString::number( field.precision() ) ) );
- tblAttributes->setItem( row, 5, new QTableWidgetItem( field.comment() ) );
+ tblAttributes->setItem( row, 5, new QTableWidgetItem( field.comment() ) );
for ( int i = 0; i < 6; i++ )
tblAttributes->item( row, i )->setFlags( tblAttributes->item( row, i )->flags() & ~Qt::ItemIsEditable );
@@ -223,6 +224,9 @@
+ //set the alias for the attribute
+ tblAttributes->setItem( row, 8, new QTableWidgetItem(layer->attributeAlias(idx)));
@@ -381,6 +385,8 @@
//! @note in raster props, this method is called sync()
void QgsVectorLayerProperties::reset( void )
+ QObject::disconnect(tblAttributes, SIGNAL(cellChanged(int, int)), this, SLOT(on_tblAttributes_cellChanged(int,int)));
// populate the general information
txtDisplayName->setText( layer->name() );
pbnQueryBuilder->setWhatsThis( tr( "This button opens the PostgreSQL query "
@@ -487,6 +493,7 @@
sliderTransparency_valueChanged( 255 - layer->getTransparency() );
loadRows();
+ QObject::connect(tblAttributes, SIGNAL(cellChanged(int, int)), this, SLOT(on_tblAttributes_cellChanged(int,int)));
} // reset()
@@ -1066,6 +1073,27 @@
+void QgsVectorLayerProperties::on_tblAttributes_cellChanged(int row, int column)
+ if(column == 8 && layer) //only consider attribute aliases in this function
+ const QgsFieldMap &fields = layer->pendingFields();
+ if(row >= fields.size())
+ return; //index must be wrong
+ QgsFieldMap::const_iterator f_it = fields.constBegin();
+ f_it += row;
+ int index = f_it.key();
+ QTableWidgetItem* aliasItem = tblAttributes->item(row, column);
+ if(aliasItem)
+ layer->addAttributeAlias(index, aliasItem->text());
QList<QgsVectorOverlayPlugin*> QgsVectorLayerProperties::overlayPlugins() const
QList<QgsVectorOverlayPlugin*> pluginList;
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.h
--- trunk/qgis/src/app/qgsvectorlayerproperties.h 2009-06-30 14:48:27 UTC (rev 10989)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.h 2009-07-01 07:29:08 UTC (rev 10990)
@@ -96,6 +96,7 @@
void on_pbnSaveDefaultStyle_clicked();
void on_pbnLoadStyle_clicked();
void on_pbnSaveStyleAs_clicked();
+ void on_tblAttributes_cellChanged(int row, int column);
void addAttribute();
void deleteAttribute();
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2009-06-30 14:48:27 UTC (rev 10989)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2009-07-01 07:29:08 UTC (rev 10990)
@@ -2401,6 +2401,24 @@
+ mAttributeAliasMap.clear();
+ QDomNode aliasesNode = node.namedItem("aliases");
+ if(!aliasesNode.isNull())
+ QDomElement aliasElem;
+ int index;
+ QString name;
+ QDomNodeList aliasNodeList = aliasesNode.toElement().elementsByTagName("alias");
+ for(int i = 0; i < aliasNodeList.size(); ++i)
+ aliasElem = aliasNodeList.at(i).toElement();
+ index = aliasElem.attribute("index").toInt();
+ name = aliasElem.attribute("name");
+ mAttributeAliasMap.insert(index, name);
// create and bind a renderer to this layer
QDomNode singlenode = node.namedItem( "singlesymbol" );
@@ -2492,6 +2510,7 @@
node.appendChild( classificationElement );
+ //edit types
if ( mEditTypes.size() > 0 )
QDomElement editTypesElement = doc.createElement( "edittypes" );
@@ -2533,6 +2552,21 @@
node.appendChild( editTypesElement );
+ //attribute aliases
+ if(mAttributeAliasMap.size() > 0)
+ QDomElement aliasElem = doc.createElement("aliases");
+ QMap<int, QString>::const_iterator a_it = mAttributeAliasMap.constBegin();
+ for(; a_it != mAttributeAliasMap.constEnd(); ++a_it)
+ QDomElement aliasEntryElem = doc.createElement("alias");
+ aliasEntryElem.setAttribute("index", QString::number(a_it.key()));
+ aliasEntryElem.setAttribute("name", a_it.value());
+ aliasElem.appendChild(aliasEntryElem);
+ node.appendChild(aliasElem);
// add the display field
QDomElement dField = doc.createElement( "displayfield" );
QDomText dFieldText = doc.createTextNode( displayField() );
@@ -2679,6 +2713,25 @@
return addAttribute( QgsField( name, map[ type ], type ) );
+void QgsVectorLayer::addAttributeAlias(int attIndex, QString aliasString)
+ mAttributeAliasMap.insert(attIndex, aliasString);
+ emit layerModified(false);
+QString QgsVectorLayer::attributeAlias(int attributeIndex) const
+ QMap<int, QString>::const_iterator alias_it = mAttributeAliasMap.find(attributeIndex);
+ if(alias_it != mAttributeAliasMap.constEnd())
+ return alias_it.value();
+ else
+ return QString();
bool QgsVectorLayer::deleteAttribute( int index )
if ( !isEditable() )
@@ -2699,6 +2752,7 @@
mDeletedAttributeIds.insert( index );
mAddedAttributeIds.remove( index );
mUpdatedFields.remove( index );
+ mAttributeAliasMap.remove(index);
setModified( true, false );
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h 2009-06-30 14:48:27 UTC (rev 10989)
+++ trunk/qgis/src/core/qgsvectorlayer.h 2009-07-01 07:29:08 UTC (rev 10990)
@@ -401,6 +401,14 @@
@note deprecated */
bool addAttribute( QString name, QString type );
+ /**Sets an alias (a display name) for attributes to display in dialogs
+ @note added in version 1.2*/
+ void addAttributeAlias(int attIndex, QString aliasString);
+ /**Returns the alias of an attribute name or an empty string if there is no alias
+ QString attributeAlias(int attributeIndex) const;
/** delete an attribute field (but does not commit it) */
bool deleteAttribute( int attr );
@@ -682,6 +690,9 @@
/** field map to commit */
QgsFieldMap mUpdatedFields;
+ /**Map that stores the aliases for attributes. Key is the attribute index and value the alias for that attribute*/
+ QMap<int, QString> mAttributeAliasMap;
/** max field index */
int mMaxUpdatedIndex;
