[QGIS Commit] r11077 - in trunk/qgis/src/plugins/grass: modules-6.4
modules-common
svn_qgis at osgeo.org
Wed Jul 15 03:31:20 EDT 2009
Author: rugginoso
Date: 2009-07-15 03:31:15 -0400 (Wed, 15 Jul 2009)
New Revision: 11077
Added:
trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.1.png
trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm
trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.1.png
trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.2.png
trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm
Removed:
trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.1.png
trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.qgm
trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.1.png
trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.2.png
trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.qgm
Moved qgis.v.out.ogr.pg and qgis.db.connect-login.pg into the right directory
Setted the default value of port to fix #1777.
Copied: trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.1.png (from rev 11074, trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.1.png)
(Binary files differ)
Copied: trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm (from rev 11074, trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.qgm)
--- trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.4/qgis.db.connect-login.pg.qgm 2009-07-15 07:31:15 UTC (rev 11077)
@@ -0,0 +1,11 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Set PostgreSQL DB connection" module="qgis.db.connect-login.pg.py">
+ <option key="database" />
+ <option key="schema" />
+ <option key="host" />
+ <option key="port" answer="5432"/>
+ <option key="user"/>
+ <option key="password"/>
+</qgisgrassmodule>
Copied: trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.1.png (from rev 11074, trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.1.png)
Copied: trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.2.png (from rev 11074, trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.2.png)
Copied: trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm (from rev 11074, trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.qgm)
--- trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.4/qgis.v.out.ogr.pg.qgm 2009-07-15 07:31:15 UTC (rev 11077)
@@ -0,0 +1,13 @@
+<qgisgrassmodule label="Export vector to PostGIS (PostgreSQL) database table." module="qgis.v.out.ogr.pg.py">
+ <option key="input" layeroption="layer" typeoption="type" />
+ <option key="olayer" />
+ <!--option key="schema" /-->
+</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.1.png
Deleted: trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.qgm
--- trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.qgm 2009-07-15 06:58:32 UTC (rev 11076)
+++ trunk/qgis/src/plugins/grass/modules-common/qgis.db.connect-login.pg.qgm 2009-07-15 07:31:15 UTC (rev 11077)
@@ -1,11 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Set PostgreSQL DB connection" module="qgis.db.connect-login.pg.py">
- <option key="database" />
- <option key="schema" />
- <option key="host" />
- <option key="port"/>
- <option key="user"/>
- <option key="password"/>
-</qgisgrassmodule>
Deleted: trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.1.png
Deleted: trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.2.png
Deleted: trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.qgm
--- trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.qgm 2009-07-15 06:58:32 UTC (rev 11076)
+++ trunk/qgis/src/plugins/grass/modules-common/qgis.v.out.ogr.pg.qgm 2009-07-15 07:31:15 UTC (rev 11077)
@@ -1,13 +0,0 @@
-<qgisgrassmodule label="Export vector to PostGIS (PostgreSQL) database table." module="qgis.v.out.ogr.pg.py">
- <option key="input" layeroption="layer" typeoption="type" />
- <option key="olayer" />
- <!--option key="schema" /-->
-</qgisgrassmodule>
