[QGIS Commit] r11095 - in trunk/qgis/src/plugins/grass: modules-6.3 modules-6.4 modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 16 07:21:07 EDT 2009
Author: rugginoso
Date: 2009-07-16 07:21:07 -0400 (Thu, 16 Jul 2009)
New Revision: 11095
Added:
   trunk/qgis/src/plugins/grass/modules-common/v.split.1.png
   trunk/qgis/src/plugins/grass/modules-common/v.split.2.png
   trunk/qgis/src/plugins/grass/modules-common/v.split.qgm
   trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
   trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
Added v.split module for the grass plug-in to fix #1783.
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-16 11:13:20 UTC (rev 11094)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-16 11:21:07 UTC (rev 11095)
@@ -292,6 +292,7 @@
 				<grass name="v.centroids"/>
 				<grass name="v.build.polylines"/>
 				<grass name="v.segment"/>
+				<grass name="v.split"/>
 				<grass name="v.to.points"/>
 				<grass name="v.parallel"/>
 				<grass name="v.dissolve"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-16 11:13:20 UTC (rev 11094)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-16 11:21:07 UTC (rev 11095)
@@ -303,6 +303,7 @@
Added: trunk/qgis/src/plugins/grass/modules-common/v.split.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules-common/v.split.1.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules-common/v.split.2.png
Property changes on: trunk/qgis/src/plugins/grass/modules-common/v.split.2.png
Added: trunk/qgis/src/plugins/grass/modules-common/v.split.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.split.qgm	                        (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-common/v.split.qgm	2009-07-16 11:21:07 UTC (rev 11095)
@@ -0,0 +1,9 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Split lines to shorter segments" module="v.split">
+        <option key="input" typemask="line,boundary"/>
+        <option key="output"/>
+	<option key="length"/>
+	<option key="vertices"/>
+</qgisgrassmodule>
More information about the QGIS-commit mailing list
