[QGIS Commit] r11112 - in trunk/qgis/src/plugins/grass: modules-6.3 modules-6.4 scripts
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jul 20 08:05:26 EDT 2009
Author: rugginoso
Date: 2009-07-20 08:05:25 -0400 (Mon, 20 Jul 2009)
New Revision: 11112
   trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
   trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
   trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt
Cleaned grass plug-in modules.
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-20 10:39:45 UTC (rev 11111)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-20 12:05:25 UTC (rev 11112)
@@ -60,7 +60,6 @@
 			</section>
 			<section label="Export vector">
 				<grass name="v.out.ogr"/>
-				<grass name="qgis.v.out.ogr.pg"/>
 				<grass name="v.out.ogr.gml"/>
 				<grass name="v.out.ogr.mapinfo"/>
 				<grass name="v.out.ogr.postgis"/>
@@ -428,7 +427,6 @@
 		<section label="Database management">
 			<grass name="db.connect"/>
 			<grass name="db.connect.schema"/>
-			<grass name="qgis.db.connect-login.pg"/>
 			<grass name="v.db.reconnect.all"/>
 			<grass name="db.login"/>
 			<grass name="db.in.ogr"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-20 10:39:45 UTC (rev 11111)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-20 12:05:25 UTC (rev 11112)
@@ -68,7 +68,6 @@
 				<grass name="v.out.ogr.pg"/>
-				<grass name="v.out.ogr.postgis"/>
 				<grass name="v.out.ascii"/>
 				<grass name="v.out.dxf"/>
 				<grass name="v.out.pov"/>
Modified: trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt	2009-07-20 10:39:45 UTC (rev 11111)
+++ trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt	2009-07-20 12:05:25 UTC (rev 11112)
@@ -1,5 +1,6 @@
+IF (GRASS_NUM_VERSION GREATER 60400)
 FILE (GLOB MODULE_FILES *.py )
 INSTALL (FILES ${MODULE_FILES}
          DESTINATION ${QGIS_DATA_DIR}/grass/scripts
 	 PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE )
+ENDIF (GRASS_NUM_VERSION GREATER 60400)
More information about the QGIS-commit mailing list
