[QGIS Commit] r11152 - in trunk/qgis: python/core src/app src/core src/core/renderer src/core/symbology src/ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Jul 23 06:59:59 EDT 2009
Author: jef
Date: 2009-07-23 06:59:59 -0400 (Thu, 23 Jul 2009)
New Revision: 11152
   trunk/qgis/python/core/qgscontinuouscolorrenderer.sip
   trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip
   trunk/qgis/python/core/qgslabel.sip
   trunk/qgis/python/core/qgsmarkercatalogue.sip
   trunk/qgis/python/core/qgsrenderer.sip
   trunk/qgis/python/core/qgssinglesymbolrenderer.sip
   trunk/qgis/python/core/qgsuniquevaluerenderer.sip
   trunk/qgis/src/app/qgssinglesymboldialog.cpp
   trunk/qgis/src/app/qgssinglesymboldialog.h
   trunk/qgis/src/core/CMakeLists.txt
   trunk/qgis/src/core/qgslabel.cpp
   trunk/qgis/src/core/qgslabel.h
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
   trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp
   trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.h
   trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
   trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h
   trunk/qgis/src/core/renderer/qgsrenderer.h
   trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
   trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.h
   trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
   trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h
   trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp
   trunk/qgis/src/core/symbology/qgsmarkercatalogue.h
   trunk/qgis/src/core/symbology/qgssymbol.cpp
   trunk/qgis/src/core/symbology/qgssymbol.h
   trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
[FEATURE] symbology enhancements:
- add QgsMarkerCatalogue::refreshList() to refresh the symbol list w/o restart
- allow refresh of symbols via popup menu on the renderer's symbol selection
- add support for data define symbol(name)s
- add support for font symbol markers (only data define - no gui yet)
- pass QgsRenderContext to rendering methods
- add symbol size in map units (ie. symbols that keep the size in mapunits
  independant of the mapscale)
Modified: trunk/qgis/python/core/qgscontinuouscolorrenderer.sip
--- trunk/qgis/python/core/qgscontinuouscolorrenderer.sip	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/python/core/qgscontinuouscolorrenderer.sip	2009-07-23 10:59:59 UTC (rev 11152)
@@ -10,8 +10,9 @@
     QgsContinuousColorRenderer(QGis::GeometryType type);
     QgsContinuousColorRenderer(const QgsContinuousColorRenderer& other);
     virtual ~QgsContinuousColorRenderer();
-    /**Renders the feature using the minimum and maximum value of the classification field*/
-    void renderFeature(QPainter* p, QgsFeature& f, QImage* img, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0);
+    /**Renders the feature using the minimum and maximum value of the classification field
+      * added in 1.2 */
+    void renderFeature(QgsRenderContext &renderContext, QgsFeature& f, QImage* img, bool selected);
     /**Returns the number of the classification field*/
     int classificationField() const;
     /**Sets the id of the classification field*/
Modified: trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip
--- trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/python/core/qgsgraduatedsymbolrenderer.sip	2009-07-23 10:59:59 UTC (rev 11152)
@@ -48,11 +48,11 @@
 	  @param f a pointer to the feature to determine if rendering will happen*/
     bool willRenderFeature(QgsFeature *f);
-    /**Renders an OGRFeature
+    /**Renders a feature
      \param p a painter (usually the one from the current map canvas)
      \param f a pointer to a feature to render
      \param t the transform object containing the information how to transform the map coordinates to screen coordinates*/
     /**Sets the number of the classicifation field
     \param field the number of the field to classify*/
Modified: trunk/qgis/python/core/qgslabel.sip
--- trunk/qgis/python/core/qgslabel.sip	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/python/core/qgslabel.sip	2009-07-23 10:59:59 UTC (rev 11152)
@@ -45,14 +45,24 @@
       QgsPoint p;
       double angle;
     /** \brief render label
-     *  \param sizeScale global scale factor for size in pixels, labels in map units are not scaled
+        \note deprecated
     void renderLabel ( QPainter* painter, QgsRectangle& viewExtent,
                        QgsCoordinateTransform* coordinateTransform,
                        QgsMapToPixel *transform,
                        QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes=0, double sizeScale = 1, double rasterScaleFactor = 1);
+    /** \brief render label
+     *  \param renderContext renderer context
+     *  \param feature feature to render
+     *  \param selected is to be shown selected
+     *  \param classAttributes attributes to use for labeling
+     *  \note added in 1.2
+    void renderLabel ( QgsRenderContext &renderContext, QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes=0);
     /** Reads the renderer configuration from an XML file
      @param rnode the Dom node to read
Modified: trunk/qgis/python/core/qgsmarkercatalogue.sip
--- trunk/qgis/python/core/qgsmarkercatalogue.sip	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/python/core/qgsmarkercatalogue.sip	2009-07-23 10:59:59 UTC (rev 11152)
@@ -1,6 +1,6 @@
 /** Catalogue of point symbols */
-class QgsMarkerCatalogue /NoDefaultCtors/
+class QgsMarkerCatalogue : QObject /NoDefaultCtors/
 %TypeHeaderCode
 #include <qgsmarkercatalogue.h>
@@ -29,5 +29,15 @@
     /** Returns a pixmap given a file name of a svg marker
      *  NOTE: this method needs to be public static for QgsMarkerDialog::visualizeMarkers */
     static void svgMarker (QPainter * thepPainter, QString name, int size );
+  public slots:
+    // reload the symbols
+    // added in 1.2
+    void refreshList();
+  signals:
+    // symbols were reloaded
+    // added in 1.2
+    void markersRefreshed();
Modified: trunk/qgis/python/core/qgsrenderer.sip
--- trunk/qgis/python/core/qgsrenderer.sip	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/python/core/qgsrenderer.sip	2009-07-23 10:59:59 UTC (rev 11152)
@@ -15,8 +15,22 @@
      @param p the painter storing brush and pen
      @param f a pointer to the feature to be rendered
      @param pic pointer to a marker from SVG (is only used by marker renderers)
-     @param scalefactor pointer to the scale factor for the marker image*/
-	virtual void renderFeature(QPainter* p, QgsFeature& f,QImage* pic, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0)=0;
+     @param selected feature is to be shown selected
+     @param widthScale scale factor
+     @param rasterScaleFactor scale factor for rasters
+     deprecated */
+    void renderFeature(QPainter* p, QgsFeature& f,QImage* pic, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0);
+    /**A vector layer passes features to a renderer object to change the brush ans pen of the qpainter
+      @param renderContext context of the rendering operation
+      @param f the feature to render
+      @param pic pointer to marker to render (is only used by marker renderers)
+      @param selected the feature is to be shown selected
+      added in 1.2 */
+    virtual void renderFeature(QgsRenderContext &renderContext, QgsFeature& f,QImage* pic, bool selected)=0;
     /**Reads the renderer configuration from an XML file
      @param vl the vector layer which will be associated with the renderer*/
Modified: trunk/qgis/python/core/qgssinglesymbolrenderer.sip
--- trunk/qgis/python/core/qgssinglesymbolrenderer.sip	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/python/core/qgssinglesymbolrenderer.sip	2009-07-23 10:59:59 UTC (rev 11152)
@@ -9,12 +9,15 @@
     QgsSingleSymbolRenderer(QGis::GeometryType type);
     QgsSingleSymbolRenderer(const QgsSingleSymbolRenderer& other);
     virtual ~QgsSingleSymbolRenderer();
     /**Replaces the current mSymbol by sy*/
     void addSymbol(QgsSymbol* sy /Transfer/);
     /*Returns a pointer to mSymbol*/
     const QgsSymbol* symbol() const;
-    /**Renders an OGRFeature*/
+    /**Renders a feature added in 1.2 */
Modified: trunk/qgis/python/core/qgsuniquevaluerenderer.sip
--- trunk/qgis/python/core/qgsuniquevaluerenderer.sip	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/python/core/qgsuniquevaluerenderer.sip	2009-07-23 10:59:59 UTC (rev 11152)
@@ -11,7 +11,11 @@
     /** Determines if a feature will be rendered or not
+    /* render feature
+     * added in 1.2 */
Modified: trunk/qgis/src/app/qgssinglesymboldialog.cpp
--- trunk/qgis/src/app/qgssinglesymboldialog.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/app/qgssinglesymboldialog.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -40,7 +40,7 @@
   QgsDebugMsg( "entered." );
-QgsSingleSymbolDialog::QgsSingleSymbolDialog( QgsVectorLayer * layer, bool disabled ): QDialog(), mVectorLayer( layer )
+QgsSingleSymbolDialog::QgsSingleSymbolDialog( QgsVectorLayer * layer, bool disabled ): QDialog(), mVectorLayer( layer ), mDisabled( disabled )
   setupUi( this );
@@ -59,7 +59,44 @@
   // loops can be removed now with changes I have made to use combo
   // boxes for line style and fill style...test and remove if poss.
+  QAction *refreshAction = new QAction( tr( "Refresh markers" ), lstSymbols );
+  lstSymbols->addAction( refreshAction );
+  connect( refreshAction, SIGNAL( triggered() ), QgsMarkerCatalogue::instance(), SLOT( refreshList() ) );
+  connect( QgsMarkerCatalogue::instance(), SIGNAL( markersRefreshed() ), this, SLOT( refreshMarkers() ) );
+  lstSymbols->setContextMenuPolicy( Qt::ActionsContextMenu );
+  //do the signal/slot connections
+  connect( btnOutlineColor, SIGNAL( clicked() ), this, SLOT( selectOutlineColor() ) );
+  connect( btnFillColor, SIGNAL( clicked() ), this, SLOT( selectFillColor() ) );
+  connect( outlinewidthspinbox, SIGNAL( valueChanged( double ) ), this, SLOT( resendSettingsChanged() ) );
+  connect( mLabelEdit, SIGNAL( textChanged( const QString& ) ), this, SLOT( resendSettingsChanged() ) );
+  connect( lstSymbols, SIGNAL( currentItemChanged( QListWidgetItem *, QListWidgetItem * ) ),
+           this, SLOT( symbolChanged( QListWidgetItem *, QListWidgetItem * ) ) );
+  connect( mPointSizeSpinBox, SIGNAL( valueChanged( double ) ), this, SLOT( resendSettingsChanged() ) );
+  connect( mPointSizeUnitsCheckBox, SIGNAL( toggled() ), this, SLOT( resendSettingsChanged() ) );
+  connect( mRotationClassificationComboBox, SIGNAL( currentIndexChanged( const QString & ) ),
+           this, SLOT( resendSettingsChanged() ) );
+  connect( mScaleClassificationComboBox, SIGNAL( currentIndexChanged( const QString & ) ),
+  connect( mSymbolComboBox, SIGNAL( currentIndexChanged( const QString & ) ),
+  connect( cboOutlineStyle, SIGNAL(
+             currentIndexChanged( const QString & ) ), this, SLOT( resendSettingsChanged() ) );
+  connect( cboFillStyle, SIGNAL(
+  //need this to deal with when texture fill is selected or deselected
+             currentIndexChanged( int ) ), this, SLOT( fillStyleChanged( int ) ) );
+  connect( toolSelectTexture, SIGNAL( clicked() ), this, SLOT( selectTextureImage() ) );
+  refreshMarkers();
+void QgsSingleSymbolDialog::refreshMarkers()
+  lstSymbols->blockSignals( true );
+  lstSymbols->clear();
   QPen pen( QColor( 0, 0, 255 ) );
   QBrush brush( QColor( 220, 220, 220 ), Qt::SolidPattern );
   int size = 18;
@@ -73,17 +110,18 @@
     myIcon.addPixmap( myPixmap );
     mypItem->setIcon( myIcon );
     mypItem->setText( "" );
+    mypItem->setToolTip( *it );
     //store the symbol offset in the UserData role for later retrieval
     mypItem->setData( Qt::UserRole, *it );
     mypItem->setFlags( Qt::ItemIsSelectable | Qt::ItemIsEnabled );
-    if ( layer->geometryType() != QGis::Point )
+    if ( mVectorLayer && mVectorLayer->geometryType() != QGis::Point )
       break;
     ++myCounter;
-  // Find out the numerical fields of mVectorLayer, and populate the ComboBox
+  // Find out the numerical fields of mVectorLayer, and populate the ComboBoxes
   QgsVectorDataProvider *provider = mVectorLayer->dataProvider();
   if ( provider )
@@ -92,6 +130,7 @@
     mRotationClassificationComboBox->addItem( DO_NOT_USE_STR, -1 );
     mScaleClassificationComboBox->addItem( DO_NOT_USE_STR, -1 );
+    mSymbolComboBox->addItem( DO_NOT_USE_STR, -1 );
     for ( QgsFieldMap::const_iterator it = fields.begin();
           it != fields.end();
           ++it )
@@ -102,6 +141,10 @@
         mRotationClassificationComboBox->addItem( it->name(), it.key() );
         mScaleClassificationComboBox->addItem( it->name(), it.key() );
+      else if ( type == QVariant::String )
+        mSymbolComboBox->addItem( it->name(), it.key() );
   else
@@ -139,13 +182,13 @@
   cboFillStyle->addItem( QIcon( QgsSymbologyUtils::char2PatternPixmap( "NoBrush" ) ), tr( "No Brush" ), "NoBrush" );
   cboFillStyle->addItem( QIcon( QgsSymbologyUtils::char2PatternPixmap( "TexturePattern" ) ), tr( "Texture" ), "TexturePattern" );
-  if ( mVectorLayer && layer->geometryType() != QGis::Point )
     mGroupPoint->setVisible( false );
     mGroupPoint->setEnabled( false );
-  if ( disabled )
+  if ( mDisabled )
     unset();
@@ -173,27 +216,7 @@
-  //do the signal/slot connections
-  connect( btnOutlineColor, SIGNAL( clicked() ), this, SLOT( selectOutlineColor() ) );
-  connect( btnFillColor, SIGNAL( clicked() ), this, SLOT( selectFillColor() ) );
-  connect( outlinewidthspinbox, SIGNAL( valueChanged( double ) ), this, SLOT( resendSettingsChanged() ) );
-  connect( mLabelEdit, SIGNAL( textChanged( const QString& ) ), this, SLOT( resendSettingsChanged() ) );
-  connect( lstSymbols, SIGNAL( currentItemChanged( QListWidgetItem *, QListWidgetItem * ) ),
-           this, SLOT( symbolChanged( QListWidgetItem *, QListWidgetItem * ) ) );
-  connect( mPointSizeSpinBox, SIGNAL( valueChanged( double ) ), this, SLOT( resendSettingsChanged() ) );
-  connect( mRotationClassificationComboBox, SIGNAL( currentIndexChanged( const QString & ) ),
-           this, SLOT( resendSettingsChanged() ) );
-  connect( mScaleClassificationComboBox, SIGNAL( currentIndexChanged( const QString & ) ),
-  connect( cboOutlineStyle, SIGNAL(
-             currentIndexChanged( const QString & ) ), this, SLOT( resendSettingsChanged() ) );
-  connect( cboFillStyle, SIGNAL(
-  //need this to deal with when texture fill is selected or deselected
-             currentIndexChanged( int ) ), this, SLOT( fillStyleChanged( int ) ) );
-  connect( toolSelectTexture, SIGNAL( clicked() ), this, SLOT( selectTextureImage() ) );
+  lstSymbols->blockSignals( false );
 QgsSingleSymbolDialog::~QgsSingleSymbolDialog()
@@ -264,6 +287,8 @@
   if ( mPointSizeSpinBox->isEnabled() )
     sy->setPointSize( mPointSizeSpinBox->value() );
+  if ( mPointSizeUnitsCheckBox->isEnabled() )
+    sy->setPointSizeUnits( mPointSizeUnitsCheckBox->isChecked() );
   std::map<QString, int>::iterator iter;
   if ( mRotationClassificationComboBox->isEnabled() )
@@ -276,6 +301,11 @@
     sy->setScaleClassificationField( mScaleClassificationComboBox->itemData( mScaleClassificationComboBox->currentIndex() ).toInt() );
+  if ( mSymbolComboBox->isEnabled() )
+    sy->setSymbolField( mSymbolComboBox->itemData( mSymbolComboBox->currentIndex() ).toInt() );
   // Apply the line style
@@ -323,8 +353,10 @@
   mLabelEdit->setEnabled( false );
   lstSymbols->setEnabled( false );
   mPointSizeSpinBox->setEnabled( false );
+  mPointSizeUnitsCheckBox->setEnabled( false );
   mRotationClassificationComboBox->setEnabled( false );
   mScaleClassificationComboBox->setEnabled( false );
+  mSymbolComboBox->setEnabled( false );
   outlinewidthspinbox->setEnabled( false );
   btnOutlineColor->setEnabled( false );
   cboOutlineStyle->setEnabled( false );
@@ -350,6 +382,7 @@
   mPointSizeSpinBox->setValue( sy->pointSize() );
+  mPointSizeUnitsCheckBox->setChecked( sy->pointSizeUnits() );
   int index;
@@ -359,6 +392,9 @@
   index = mScaleClassificationComboBox->findData( sy->scaleClassificationField() );
   mScaleClassificationComboBox->setCurrentIndex( index < 0 ? 0 : index );
+  index = mSymbolComboBox->findData( sy->symbolField() );
+  mSymbolComboBox->setCurrentIndex( index < 0 ? 0 : index );
   outlinewidthspinbox->setValue( sy->pen().widthF() );
   //set line width 1 as minimum to avoid confusion between line width 0 and no pen line style
@@ -418,8 +454,10 @@
   mLabelEdit->setEnabled( true );
   lstSymbols->setEnabled( true );
   mPointSizeSpinBox->setEnabled( true );
+  mPointSizeUnitsCheckBox->setEnabled( true );
   mRotationClassificationComboBox->setEnabled( true );
   mScaleClassificationComboBox->setEnabled( true );
+  mSymbolComboBox->setEnabled( true );
   outlinewidthspinbox->setEnabled( true );
   btnOutlineColor->setEnabled( true );
   cboOutlineStyle->setEnabled( true );
@@ -442,6 +480,9 @@
   if ( mPointSizeSpinBox->isEnabled() && mPointSizeSpinBox->value() != sy->pointSize() )
+  if ( mPointSizeUnitsCheckBox->isEnabled() && mPointSizeUnitsCheckBox->isChecked() != sy->pointSizeUnits() )
   if ( mRotationClassificationComboBox->isEnabled() &&
        mRotationClassificationComboBox->itemData( mRotationClassificationComboBox->currentIndex() ).toInt() != sy->rotationClassificationField() )
@@ -450,6 +491,10 @@
        mScaleClassificationComboBox->itemData( mScaleClassificationComboBox->currentIndex() ).toInt() != sy->scaleClassificationField() )
+  if ( mSymbolComboBox->isEnabled() &&
+       mSymbolComboBox->itemData( mSymbolComboBox->currentIndex() ).toInt() != sy->symbolField() )
   if ( outlinewidthspinbox->isEnabled() && outlinewidthspinbox->value() != sy->pen().widthF() )
Modified: trunk/qgis/src/app/qgssinglesymboldialog.h
--- trunk/qgis/src/app/qgssinglesymboldialog.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/app/qgssinglesymboldialog.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -48,6 +48,7 @@
   protected:
     QgsVectorLayer* mVectorLayer;
+    bool mDisabled;
   public slots:
     /* arrange the widgets on this dialog to reflect the current state of QgsSymbol */
@@ -65,6 +66,8 @@
     void fillStyleChanged( int theIndex );
+    void refreshMarkers();
   protected slots:
     void selectOutlineColor();
     void selectFillColor();
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/CMakeLists.txt	2009-07-23 10:59:59 UTC (rev 11152)
@@ -182,6 +182,7 @@
 composer/qgscomposerscalebar.h
 composer/qgscomposeritemgroup.h
 composer/qgslegendmodel.h
+symbology/qgsmarkercatalogue.h
 raster/qgsrasterlayer.h
Modified: trunk/qgis/src/core/qgslabel.cpp
--- trunk/qgis/src/core/qgslabel.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/qgslabel.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -33,6 +33,7 @@
 #include "qgsrectangle.h"
 #include "qgsmaptopixel.h"
 #include "qgscoordinatetransform.h"
+#include "qgsrendercontext.h"
 #include "qgslabelattributes.h"
 #include "qgslabel.h"
@@ -85,11 +86,9 @@
-void QgsLabel::renderLabel( QPainter * painter, const QgsRectangle& viewExtent,
-                            const QgsCoordinateTransform* coordinateTransform,
-                            const QgsMapToPixel *transform,
-                            QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes,
-                            double sizeScale, double rasterScaleFactor )
+void QgsLabel::renderLabel( QgsRenderContext &renderContext,
+                            QgsFeature &feature, bool selected,
+                            QgsLabelAttributes *classAttributes )
   QPen pen;
   QFont font;
@@ -98,9 +97,9 @@
   /* Calc scale (not nice) */
   QgsPoint point;
-  point = transform->transform( 0, 0 );
+  point = renderContext.mapToPixel().transform( 0, 0 );
   double x1 = point.x();
-  point = transform->transform( 1000, 0 );
+  point = renderContext.mapToPixel().transform( 1000, 0 );
   double x2 = point.x();
   double scale = ( x2 - x1 ) * 0.001;
@@ -155,12 +154,12 @@
   else //point units
     double sizeMM = size * 0.3527;
-    size = sizeMM * sizeScale;
+    size = sizeMM * renderContext.scaleFactor();
   //Request font larger (multiplied by rasterScaleFactor) as a workaround for the Qt font bug
   //and scale the painter down by rasterScaleFactor when drawing the label
-  size *= rasterScaleFactor;
+  size *= renderContext.rasterScaleFactor();
   if (( int )size <= 0 )
     // skip too small labels
@@ -333,8 +332,8 @@
   else
-    xoffset = xoffset * 0.3527 * sizeScale;
-    yoffset = yoffset * 0.3527 * sizeScale;
+    xoffset = xoffset * 0.3527 * renderContext.scaleFactor();
+    yoffset = yoffset * 0.3527 * renderContext.scaleFactor();
   // Angle
@@ -355,9 +354,8 @@
   // part.
   if ( useOverridePoint )
-    renderLabel( painter, overridePoint, coordinateTransform,
-                 transform, text, font, pen, dx, dy,
-                 xoffset, yoffset, ang, width, height, alignment, sizeScale, rasterScaleFactor );
+    renderLabel( renderContext, overridePoint, text, font, pen, dx, dy,
+                 xoffset, yoffset, ang, width, height, alignment );
   else
@@ -365,28 +363,28 @@
     labelPoint( points, feature );
     for ( uint i = 0; i < points.size(); ++i )
-      renderLabel( painter, points[i].p, coordinateTransform,
-                   xoffset, yoffset, mLabelAttributes->angleIsAuto() ? points[i].angle : ang, width, height, alignment, sizeScale, rasterScaleFactor );
+      renderLabel( renderContext, points[i].p, text, font, pen, dx, dy,
+                   xoffset, yoffset, mLabelAttributes->angleIsAuto() ? points[i].angle : ang, width, height, alignment );
-void QgsLabel::renderLabel( QPainter* painter, QgsPoint point,
-                            const QgsMapToPixel* transform,
+                            QgsPoint point,
                             QString text, QFont font, QPen pen,
                             int dx, int dy,
                             double xoffset, double yoffset,
                             double ang,
-                            int width, int height, int alignment, double sizeScale, double rasterScaleFactor )
+                            int width, int height, int alignment )
+  QPainter *painter = renderContext.painter();
   // Convert point to projected units
-  if ( coordinateTransform )
+  if ( renderContext.coordinateTransform() )
     try
-      point = coordinateTransform->transform( point );
+      point = renderContext.coordinateTransform()->transform( point );
     catch ( QgsCsException &cse )
@@ -397,7 +395,7 @@
   // and then to canvas units
-  transform->transform( &point );
+  renderContext.mapToPixel().transform( &point );
   double x = point.x();
   double y = point.y();
@@ -411,7 +409,7 @@
   painter->setFont( font );
   painter->translate( x, y );
   //correct oversampled font size back by scaling painter down
-  painter->scale( 1.0 / rasterScaleFactor, 1.0 / rasterScaleFactor );
+  painter->scale( 1.0 / renderContext.rasterScaleFactor(), 1.0 / renderContext.rasterScaleFactor() );
   painter->rotate( -ang );
@@ -419,7 +417,7 @@
   if ( mLabelAttributes->bufferSizeIsSet() && mLabelAttributes->bufferEnabled() )
-    double myBufferSize = mLabelAttributes->bufferSize() * 0.3527 * sizeScale * rasterScaleFactor;
+    double myBufferSize = mLabelAttributes->bufferSize() * 0.3527 * renderContext.scaleFactor() * renderContext.rasterScaleFactor();
     QPen bufferPen;
     if ( mLabelAttributes->bufferColorIsSet() )
@@ -432,13 +430,13 @@
     painter->setPen( bufferPen );
     double bufferStepSize; //hack to distinguish pixel devices from logical devices
-    if (( sizeScale - 1 ) > 1.5 )
+    if (( renderContext.scaleFactor() - 1 ) > 1.5 )
       bufferStepSize = 1;
     else //draw more dense in case of logical devices
-      bufferStepSize = 1 / rasterScaleFactor;
+      bufferStepSize = 1 / renderContext.rasterScaleFactor();
     for ( double i = dx - myBufferSize; i <= dx + myBufferSize; i += bufferStepSize )
Modified: trunk/qgis/src/core/qgslabel.h
--- trunk/qgis/src/core/qgslabel.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/qgslabel.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -35,11 +35,10 @@
 class QgsFeature;
 class QgsField;
 class QgsLabelAttributes;
-class QgsRectangle;
-class QgsMapToPixel;
-class QgsCoordinateTransform;
 #include "qgsfield.h"
+#include "qgsrectangle.h"
 typedef QList<int> QgsAttributeList;
@@ -93,12 +92,29 @@
+     *  \note deprecated
     void renderLabel( QPainter* painter, const QgsRectangle& viewExtent,
+                      QgsCoordinateTransform* coordinateTransform,
-                      QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes = 0, double sizeScale = 1., double rasterScaleFactor = 1.0 );
+                      QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes = 0, double sizeScale = 1., double rasterScaleFactor = 1.0 )
+      QgsRenderContext r;
+      r.setExtent( viewExtent );
+      r.setCoordinateTransform( new QgsCoordinateTransform( coordinateTransform->sourceCrs(), coordinateTransform->destCRS() ) );
+      r.setMapToPixel( *transform );
+      r.setPainter( painter );
+      r.setScaleFactor( sizeScale );
+      r.setRasterScaleFactor( rasterScaleFactor );
+      renderLabel( r, feature, selected, classAttributes );
+     *  \param sizeScale global scale factor for size in pixels, labels in map units are not scaled
+    void renderLabel( QgsRenderContext &renderContext, QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes = 0 );
@@ -151,14 +167,12 @@
     /** Does the actual rendering of a label at the given point
-    void renderLabel( QPainter* painter, QgsPoint point,
+    void renderLabel( QgsRenderContext &renderContext, QgsPoint point,
                       int dx, int dy,
                       double ang,
-                      int width, int height, int alignment, double sizeScale = 1.0, double rasterScaleFactor = 1.0 );
+                      int width, int height, int alignment );
     bool readLabelField( QDomElement &el, int attr, QString prefix );
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -325,7 +325,7 @@
         if ( mRenderer->willRenderFeature( &fet ) )
           bool sel = mSelectedFeatureIds.contains( fet.id() );
-          mLabel->renderLabel( rendererContext.painter(), rendererContext.extent(), rendererContext.coordinateTransform(), &( rendererContext.mapToPixel() ), fet, sel, 0, rendererContext.scaleFactor(), rendererContext.rasterScaleFactor() );
+          mLabel->renderLabel( rendererContext, fet, sel, 0 );
         featureCount++;
@@ -348,13 +348,9 @@
-unsigned char* QgsVectorLayer::drawLineString(
-  unsigned char *feature,
-  QPainter* p,
-  const QgsMapToPixel* mtp,
-  const QgsCoordinateTransform* ct,
-  bool drawingToEditingCanvas )
+unsigned char *QgsVectorLayer::drawLineString( unsigned char *feature, QgsRenderContext &renderContext )
+  QPainter *p = renderContext.painter();
   unsigned char *ptr = feature + 5;
   unsigned int wkbType = *(( int* )( feature + 1 ) );
   unsigned int nPoints = *(( int* )ptr );
@@ -381,7 +377,7 @@
   // Transform the points into map coordinates (and reproject if
   // necessary)
-  transformPoints( x, y, z, mtp, ct );
+  transformPoints( x, y, z, renderContext );
 #if defined(Q_WS_X11)
   // Work around a +/- 32768 limitation on coordinates in X11
@@ -440,7 +436,7 @@
   p->drawPolyline( pa );
   // draw vertex markers if in editing mode, but only to the main canvas
-  if ( mEditable && drawingToEditingCanvas )
+  if ( mEditable && renderContext.drawEditingInformation() )
     std::vector<double>::const_iterator xIt;
@@ -457,13 +453,9 @@
   return ptr;
-unsigned char *QgsVectorLayer::drawPolygon(
-  QPainter *p,
-  const QgsMapToPixel *mtp,
-  const QgsCoordinateTransform *ct,
+unsigned char *QgsVectorLayer::drawPolygon( unsigned char *feature, QgsRenderContext &renderContext )
   typedef std::pair<std::vector<double>, std::vector<double> > ringType;
   typedef ringType* ringTypePtr;
   typedef std::vector<ringTypePtr> ringsType;
@@ -517,7 +509,7 @@
       continue;
-    transformPoints( ring->first, ring->second, zVector, mtp, ct );
+    transformPoints( ring->first, ring->second, zVector, renderContext );
@@ -642,7 +634,7 @@
       for ( int i = 0; i < path.elementCount(); ++i )
@@ -683,7 +675,7 @@
     /*Pointer to a marker image*/
     QImage marker;
     //vertex marker type for selection
-    QgsVectorLayer::VertexMarkerType vertexMarker;
+    QgsVectorLayer::VertexMarkerType vertexMarker = QgsVectorLayer::NoMarker;
     if ( mEditable )
@@ -747,26 +739,13 @@
         //QgsDebugMsg(QString("markerScale before renderFeature(): %1").arg(markerScaleFactor));
         // markerScalerFactore reflects the wanted scaling of the marker
-        mRenderer->renderFeature(
-          rendererContext.painter(),
-          fet,
-          &marker,
-          sel,
-          rendererContext.scaleFactor(),
-          rendererContext.rasterScaleFactor() );
+        mRenderer->renderFeature( rendererContext, fet, &marker, sel );
         // markerScalerFactore now reflects the actual scaling of the marker that the render performed.
         //QgsDebugMsg(QString("markerScale after renderFeature(): %1").arg(markerScaleFactor));
         //double scale = rendererContext.scaleFactor() /  markerScaleFactor;
-        drawFeature(
-          fet,
-          &rendererContext.mapToPixel(),
-          rendererContext.coordinateTransform(),
-          &marker,
-          rendererContext.rasterScaleFactor(),
-          rendererContext.drawEditingInformation() );
+        drawFeature( rendererContext, fet, &marker );
         ++featureCount;
@@ -1558,7 +1537,7 @@
       geometry = mChangedGeometries[atFeatureId];
-    if (!geometry.deleteVertex( atVertex ))
+    if ( !geometry.deleteVertex( atVertex ) )
       return false;
@@ -3487,15 +3466,11 @@
-void QgsVectorLayer::drawFeature( QPainter* p,
+void QgsVectorLayer::drawFeature( QgsRenderContext &renderContext,
                                   QgsFeature& fet,
-                                  const QgsMapToPixel* theMapToPixelTransform,
-                                  QImage * marker,
-                                  double widthScale,
-                                  double rasterScaleFactor,
+                                  QImage * marker )
   // Only have variables, etc outside the switch() statement that are
   // used in all cases of the statement (otherwise they may get
   // executed, but never used, in a bit of code where performance is
@@ -3518,13 +3493,14 @@
       double x = *(( double * )( feature + 5 ) );
       double y = *(( double * )( feature + 5 + sizeof( double ) ) );
-      transformPoint( x, y, theMapToPixelTransform, ct );
+      transformPoint( x, y, &renderContext.mapToPixel(), renderContext.coordinateTransform() );
       //QPointF pt(x - (marker->width()/2),  y - (marker->height()/2));
-      QPointF pt( x*rasterScaleFactor - ( marker->width() / 2 ),  y*rasterScaleFactor - ( marker->height() / 2 ) );
+      QPointF pt( x*renderContext.rasterScaleFactor() - ( marker->width() / 2 ),
+                  y*renderContext.rasterScaleFactor() - ( marker->height() / 2 ) );
       p->save();
       //p->scale(markerScaleFactor,markerScaleFactor);
-      p->scale( 1.0 / rasterScaleFactor, 1.0 / rasterScaleFactor );
+      p->scale( 1.0 / renderContext.rasterScaleFactor(), 1.0 / renderContext.rasterScaleFactor() );
       p->drawImage( pt, *marker );
       p->restore();
@@ -3539,7 +3515,7 @@
       p->save();
       //p->scale(markerScaleFactor, markerScaleFactor);
       for ( register unsigned int i = 0; i < nPoints; ++i )
@@ -3552,10 +3528,11 @@
         if ( wkbType == QGis::WKBMultiPoint25D ) // ignore Z value
           ptr += sizeof( double );
         //QPointF pt(x/markerScaleFactor - (marker->width()/2),  y/markerScaleFactor - (marker->height()/2));
         //QPointF pt( x, y );
@@ -3574,11 +3551,7 @@
     case QGis::WKBLineString:
     case QGis::WKBLineString25D:
-      drawLineString( feature,
-                      p,
-                      theMapToPixelTransform,
-                      ct,
-                      drawingToEditingCanvas );
+      drawLineString( feature, renderContext );
       break;
     case QGis::WKBMultiLineString:
@@ -3590,22 +3563,14 @@
       for ( register unsigned int jdx = 0; jdx < numLineStrings; jdx++ )
-        ptr = drawLineString( ptr,
-                              p,
-                              ct,
+        ptr = drawLineString( ptr, renderContext );
       break;
     case QGis::WKBPolygon:
     case QGis::WKBPolygon25D:
-      drawPolygon( feature,
-                   p,
-                   ct,
+      drawPolygon( feature, renderContext );
       break;
     case QGis::WKBMultiPolygon:
@@ -3615,11 +3580,7 @@
       unsigned int numPolygons = *(( int* )ptr );
       ptr = feature + 9;
       for ( register unsigned int kdx = 0; kdx < numPolygons; kdx++ )
-        ptr = drawPolygon( ptr,
-                           p,
-                           ct,
+        ptr = drawPolygon( ptr, renderContext );
       break;
     default:
@@ -3672,15 +3633,15 @@
 inline void QgsVectorLayer::transformPoints(
   std::vector<double>& x, std::vector<double>& y, std::vector<double>& z,
-  const QgsMapToPixel* mtp, const QgsCoordinateTransform* ct )
+  QgsRenderContext &renderContext )
   // transform the point
-  if ( ct )
-    ct->transformInPlace( x, y, z );
+    renderContext.coordinateTransform()->transformInPlace( x, y, z );
   // transform from projected coordinate system to pixel
   // position on map canvas
-  mtp->transformInPlace( x, y );
+  renderContext.mapToPixel().transformInPlace( x, y );
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -550,41 +550,26 @@
     bool setDataProvider( QString const & provider );
     /** Draws features. May cause projections exceptions to be generated
-     *  (i.e., code that calls this function needs to catch them)
-    void drawFeature( QPainter* p,
+     *  (i.e., code that calls this function needs to catch them) */
+    void drawFeature( QgsRenderContext &renderContext,
                       QgsFeature& fet,
-                      const QgsMapToPixel* cXf,
-                      QImage* marker,
-                      double markerScaleFactor,
-                      bool drawingToEditingCanvas );
+                      QImage* marker );
     /** Convenience function to transform the given point */
     void transformPoint( double& x, double& y,
                          const QgsMapToPixel* mtp, const QgsCoordinateTransform* ct );
-    void transformPoints( std::vector<double>& x, std::vector<double>& y, std::vector<double>& z,
-                          const QgsMapToPixel* mtp, const QgsCoordinateTransform* ct );
+    void transformPoints( std::vector<double>& x, std::vector<double>& y, std::vector<double>& z, QgsRenderContext &renderContext );
     /** Draw the linestring as given in the WKB format. Returns a pointer
      * to the byte after the end of the line string binary data stream (WKB).
-    unsigned char *drawLineString( unsigned char *WKBlinestring,
-                                   QPainter *p,
+    unsigned char *drawLineString( unsigned char *WKBlinestring, QgsRenderContext &renderContext );
     /** Draw the polygon as given in the WKB format. Returns a pointer to
      *  the byte after the end of the polygon binary data stream (WKB).
-    unsigned char *drawPolygon( unsigned char *WKBpolygon,
-                                QPainter *p,
+    unsigned char *drawPolygon( unsigned char *WKBpolygon, QgsRenderContext &renderContext );
     /** Goes through all features and finds a free id (e.g. to give it temporarily to a not-commited feature) */
     int findFreeId();
Modified: trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp
--- trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -22,6 +22,7 @@
 #include "qgssymbologyutils.h"
 #include "qgsvectordataprovider.h"
 #include "qgsvectorlayer.h"
 #include <cfloat>
 #include <QDomElement>
@@ -73,8 +74,10 @@
   mMaximumSymbol = sy;
-void QgsContinuousColorRenderer::renderFeature( QPainter * p, QgsFeature & f, QImage* img, bool selected, double widthScale, double rasterScaleFactor )
+void QgsContinuousColorRenderer::renderFeature( QgsRenderContext &renderContext, QgsFeature & f, QImage* img, bool selected )
   if (( mMinimumSymbol && mMaximumSymbol ) )
     //first find out the value for the classification attribute
@@ -129,7 +132,7 @@
       // later add support for both pen and brush to dialog
       QPen pen = mMinimumSymbol->pen();
       pen.setColor( QColor( red, green, blue ) );
-      pen.setWidthF( widthScale * pen.widthF() );
+      pen.setWidthF( renderContext.scaleFactor() * pen.widthF() );
       QBrush brush = mMinimumSymbol->brush();
@@ -145,13 +148,13 @@
       brush.setStyle( Qt::SolidPattern );
       *img = QgsMarkerCatalogue::instance()->imageMarker( mMinimumSymbol->pointSymbolName(),
-             mMinimumSymbol->pointSize() * widthScale * rasterScaleFactor, pen, brush );
+             mMinimumSymbol->pointSize() * renderContext.scaleFactor() * renderContext.rasterScaleFactor(), pen, brush );
     else if ( mGeometryType == QGis::Line )
       QPen linePen;
       linePen.setColor( QColor( red, green, blue ) );
-      linePen.setWidthF( widthScale*mMinimumSymbol->pen().widthF() );
+      linePen.setWidthF( renderContext.scaleFactor()*mMinimumSymbol->pen().widthF() );
       p->setPen( linePen );
     else //polygon
@@ -161,7 +164,7 @@
         QPen pen;
         pen.setColor( QColor( 0, 0, 0 ) );
-        pen.setWidthF( widthScale*mMinimumSymbol->pen().widthF() );
+        pen.setWidthF( renderContext.scaleFactor()*mMinimumSymbol->pen().widthF() );
         p->setPen( pen );
       else
Modified: trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.h
--- trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgscontinuouscolorrenderer.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -35,8 +35,11 @@
     QgsContinuousColorRenderer( const QgsContinuousColorRenderer& other );
     QgsContinuousColorRenderer& operator=( const QgsContinuousColorRenderer& other );
-    void renderFeature( QPainter* p, QgsFeature& f, QImage* img, bool selected,  double widthScale = 1.0, double rasterScaleFactor = 1.0 );
+     * added in 1.2 */
+    void renderFeature( QgsRenderContext &renderContext, QgsFeature& f, QImage* img, bool selected );
Modified: trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp
--- trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -24,6 +24,7 @@
 #include <math.h>
 #include <QDomNode>
@@ -115,8 +116,9 @@
   return ( symbolForFeature( f ) != 0 );
-void QgsGraduatedSymbolRenderer::renderFeature( QPainter * p, QgsFeature & f, QImage* img, bool selected, double widthScale, double rasterScaleFactor )
+void QgsGraduatedSymbolRenderer::renderFeature( QgsRenderContext &renderContext, QgsFeature & f, QImage* img, bool selected )
   QgsSymbol* theSymbol = symbolForFeature( &f );
   if ( !theSymbol )
@@ -144,15 +146,31 @@
       //first find out the value for the scale classification attribute
       const QgsAttributeMap& attrs = f.attributeMap();
       fieldScale = sqrt( fabs( attrs[theSymbol->scaleClassificationField()].toDouble() ) );
-      QgsDebugMsg( QString( "Feature has field scale factor %1" ).arg( fieldScale ) );
+      QgsDebugMsgLevel( QString( "Feature has field scale factor %1" ).arg( fieldScale ), 3 );
     if ( theSymbol->rotationClassificationField() >= 0 )
       rotation = attrs[theSymbol->rotationClassificationField()].toDouble();
-      QgsDebugMsg( QString( "Feature has rotation factor %1" ).arg( rotation ) );
+      QgsDebugMsgLevel( QString( "Feature has rotation factor %1" ).arg( rotation ), 3 );
-    *img = theSymbol->getPointSymbolAsImage( widthScale, selected, mSelectionColor, fieldScale, rotation, rasterScaleFactor );
+    QString oldName;
+    if ( theSymbol->symbolField() >= 0 )
+      const QgsAttributeMap& attrs = f.attributeMap();
+      QString name = attrs[theSymbol->symbolField()].toString();
+      QgsDebugMsgLevel( QString( "Feature has name %1" ).arg( name ), 3 );
+      oldName = theSymbol->pointSymbolName();
+      theSymbol->setNamedPointSymbol( name );
+    *img = theSymbol->getPointSymbolAsImage( renderContext.scaleFactor(), selected, mSelectionColor, fieldScale, rotation, renderContext.rasterScaleFactor() );
+    if ( !oldName.isNull() )
+      theSymbol->setNamedPointSymbol( oldName );
   // Line, polygon
@@ -161,25 +179,25 @@
     if ( !selected )
       QPen pen = theSymbol->pen();
       p->setPen( pen );
       if ( mGeometryType == QGis::Polygon )
         QBrush brush = theSymbol->brush();
-        scaleBrush( brush, rasterScaleFactor ); //scale brush content for printout
+        scaleBrush( brush, renderContext.rasterScaleFactor() ); //scale brush content for printout
         p->setBrush( brush );
     else
         brush.setColor( mSelectionColor );
@@ -283,15 +301,20 @@
   for ( it = mSymbols.begin(); it != mSymbols.end(); ++it )
     int rotationField = ( *it )->rotationClassificationField();
-    if ( rotationField >= 0 && !( mSymbolAttributes.contains( rotationField ) ) )
+    if ( rotationField >= 0 && !mSymbolAttributes.contains( rotationField ) )
       mSymbolAttributes.append( rotationField );
     int scaleField = ( *it )->scaleClassificationField();
-    if ( scaleField >= 0 && !( mSymbolAttributes.contains( scaleField ) ) )
+    if ( scaleField >= 0 && !mSymbolAttributes.contains( scaleField ) )
       mSymbolAttributes.append( scaleField );
+    int symbolField = ( *it )->symbolField();
+    if ( symbolField >= 0 && !mSymbolAttributes.contains( symbolField ) )
+      mSymbolAttributes.append( symbolField );
Modified: trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h
--- trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgsgraduatedsymbolrenderer.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -66,11 +66,12 @@
     virtual bool willRenderFeature( QgsFeature *f );
-     \param t the transform object containing the information how to transform the map coordinates to screen coordinates*/
+     \param t the transform object containing the information how to transform the map coordinates to screen coordinates
+     \note added in 1.2 */
     /**Sets the classicifation field by index
Modified: trunk/qgis/src/core/renderer/qgsrenderer.h
--- trunk/qgis/src/core/renderer/qgsrenderer.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgsrenderer.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -27,6 +27,7 @@
 class QColor;
 #include "qgis.h"
 #include <QList>
 class QgsSymbol;
@@ -58,8 +59,21 @@
      @param pic pointer to an image (used for point symbols)
-    virtual void renderFeature( QPainter* p, QgsFeature& f, QImage* pic, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0 ) = 0;
+     @param scalefactor pointer to the scale factor for the marker image
+     @note deprecated */
+    void renderFeature( QPainter* p, QgsFeature& f, QImage* img, bool selected, double widthScale = 1.0, double rasterScaleFactor = 1.0 )
+      r.setPainter( p );
+      r.setScaleFactor( widthScale );
+      renderFeature( r, f, img, selected );
+    /**A vector layer passes features to a renderer object to change the brush and pen of the qpainter
+      @note added in 1.2 */
+    virtual void renderFeature( QgsRenderContext &renderContext, QgsFeature& f, QImage* pic, bool selected ) = 0;
Modified: trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp
--- trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -24,6 +24,7 @@
 #include "qgssymbol.h"
 #include <QDomNode>
 #include <QImage>
@@ -53,15 +54,14 @@
     sy->setFillStyle( Qt::SolidPattern );
     sy->setColor( QColor( 0, 0, 0 ) );
-  mSymbol = sy;
+  mSymbol0 = sy;
+  mSymbols[ QString()] = sy;
   updateSymbolAttributes();
 QgsSingleSymbolRenderer::QgsSingleSymbolRenderer( const QgsSingleSymbolRenderer& other )
-  mGeometryType = other.mGeometryType;
-  mSymbol = new QgsSymbol( *other.mSymbol );
-  updateSymbolAttributes();
+  *this = other;
 QgsSingleSymbolRenderer& QgsSingleSymbolRenderer::operator=( const QgsSingleSymbolRenderer & other )
@@ -69,8 +69,9 @@
   if ( this != &other )
-    delete mSymbol;
+    for ( QMap<QString, QgsSymbol *>::const_iterator it = other.mSymbols.begin(); it != other.mSymbols.end(); it++ )
+      mSymbols[ it.key()] = new QgsSymbol( *it.value() );
   return *this;
@@ -78,18 +79,25 @@
 QgsSingleSymbolRenderer::~QgsSingleSymbolRenderer()
-  delete mSymbol;
+  for ( QMap<QString, QgsSymbol *>::iterator it = mSymbols.begin(); it != mSymbols.end(); it++ )
+    delete it.value();
-void QgsSingleSymbolRenderer::addSymbol( QgsSymbol* sy )
+void QgsSingleSymbolRenderer::addSymbol( QgsSymbol *sy )
-  delete mSymbol;
-  mSymbol = sy;
+  mSymbol0 = sy;
-void QgsSingleSymbolRenderer::renderFeature( QPainter * p, QgsFeature & f, QImage* img, bool selected, double widthScale, double rasterScaleFactor )
+void QgsSingleSymbolRenderer::renderFeature( QgsRenderContext &renderContext, QgsFeature & f, QImage* img, bool selected )
   // Point
   if ( img && mGeometryType == QGis::Point )
@@ -97,49 +105,84 @@
     // If scale field is non-negative, use it to scale.
     double fieldScale = 1.0;
     double rotation = 0.0;
+    QgsSymbol *sy = mSymbol0;
-    if ( mSymbol->scaleClassificationField() >= 0 )
+    if ( mSymbol0->symbolField() >= 0 )
+      QString name = attrs[ mSymbol0->symbolField()].toString();
+      if ( !mSymbols.contains( name ) )
+        sy = new QgsSymbol( mGeometryType );
+        sy->setNamedPointSymbol( name );
+        mSymbols[ name ] = sy;
+      else
+        sy = mSymbols[ name ];
+      sy->setPointSize( mSymbol0->pointSize() );
+      sy->setPointSizeUnits( mSymbol0->pointSizeUnits() );
+    if ( mSymbol0->scaleClassificationField() >= 0 )
-      fieldScale = sqrt( fabs( attrs[mSymbol->scaleClassificationField()].toDouble() ) );
+      fieldScale = sqrt( fabs( attrs[ mSymbol0->scaleClassificationField()].toDouble() ) );
-    if ( mSymbol->rotationClassificationField() >= 0 )
+    if ( mSymbol0->rotationClassificationField() >= 0 )
-      rotation = attrs[mSymbol->rotationClassificationField()].toDouble();
+      rotation = attrs[ mSymbol0->rotationClassificationField()].toDouble();
-    *img = mSymbol->getPointSymbolAsImage( widthScale, selected, mSelectionColor, fieldScale, rotation, rasterScaleFactor );
+    double scale = renderContext.scaleFactor();
+    if ( sy->pointSizeUnits() )
+      /* Calc scale (still not nice) */
+      QgsPoint point;
+      double x1 = point.x();
+      double x2 = point.x();
+      scale *= ( x2 - x1 ) * 0.001;
+    *img = sy->getPointSymbolAsImage( scale, selected, mSelectionColor, fieldScale, rotation, renderContext.rasterScaleFactor() );
   // Line, polygon
   if ( mGeometryType != QGis::Point )
     if ( !selected )
-      QPen pen = mSymbol->pen();
+      QPen pen = mSymbol0->pen();
       p->setPen( pen );
-        QBrush brush = mSymbol->brush();
+        QBrush brush = mSymbol0->brush();
     else
@@ -184,9 +227,9 @@
   QDomElement singlesymbol = document.createElement( "singlesymbol" );
   layer_node.appendChild( singlesymbol );
-  if ( mSymbol )
+  if ( mSymbol0 )
-    returnval = mSymbol->writeXML( singlesymbol, document, &vl );
+    returnval = mSymbol0->writeXML( singlesymbol, document, &vl );
   return returnval;
@@ -203,16 +246,21 @@
   // Timing is not so important.
   mSymbolAttributes.clear();
-  int rotationField = mSymbol->rotationClassificationField();
+  int rotationField = mSymbol0->rotationClassificationField();
-  int scaleField = mSymbol->scaleClassificationField();
+  int scaleField = mSymbol0->scaleClassificationField();
+  int symbolField = mSymbol0->symbolField();
+  if ( symbolField >= 0 && !( mSymbolAttributes.contains( symbolField ) ) )
 QString QgsSingleSymbolRenderer::name() const
@@ -222,9 +270,7 @@
 const QList<QgsSymbol*> QgsSingleSymbolRenderer::symbols() const
-  QList<QgsSymbol*> list;
-  list.append( mSymbol );
-  return list;
+  return mSymbols.values();
 QgsRenderer* QgsSingleSymbolRenderer::clone() const
Modified: trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.h
--- trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgssinglesymbolrenderer.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -19,7 +19,9 @@
 #ifndef QGSSINGLESYMBOLRENDERER_H
 #define QGSSINGLESYMBOLRENDERER_H
+#include <QMap>
 #include "qgsrenderer.h"
 /**Render class to display all the features with a single QgsSymbol*/
@@ -30,12 +32,16 @@
     QgsSingleSymbolRenderer( const QgsSingleSymbolRenderer& other );
     QgsSingleSymbolRenderer& operator=( const QgsSingleSymbolRenderer& other );
     void addSymbol( QgsSymbol* sy );
-    /**Renders a feature*/
+     * added in 1.2 */
@@ -60,14 +66,15 @@
     QgsRenderer* clone() const;
   protected:
     /**Object containing symbology information*/
-    QgsSymbol* mSymbol;
+    QgsSymbol *mSymbol0;
+    QMap<QString, QgsSymbol*> mSymbols;
     /**Cached copy of all underlying symbols required attribute fields*/
     QgsAttributeList mSymbolAttributes;
 inline const QgsSymbol* QgsSingleSymbolRenderer::symbol() const
-  return mSymbol;
+  return mSymbol0;
 inline bool QgsSingleSymbolRenderer::needsAttributes() const
Modified: trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp
--- trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -20,6 +20,7 @@
 #include "qgsfeature.h"
 #include "qgslogger.h"
@@ -104,8 +105,9 @@
-void QgsUniqueValueRenderer::renderFeature( QPainter* p, QgsFeature& f, QImage* img, bool selected, double widthScale, double rasterScaleFactor )
+void QgsUniqueValueRenderer::renderFeature( QgsRenderContext &renderContext, QgsFeature& f, QImage* img, bool selected )
   QgsSymbol* symbol = symbolForFeature( &f );
   if ( !symbol ) //no matching symbol
@@ -138,8 +140,23 @@
       rotation = attrs[symbol->rotationClassificationField()].toDouble();
-    *img = symbol->getPointSymbolAsImage( widthScale, selected, mSelectionColor,
-                                          fieldScale, rotation, rasterScaleFactor );
+    QString oldName;
+    if ( symbol->symbolField() >= 0 )
+      QString name = attrs[symbol->symbolField()].toString();
+      oldName = symbol->pointSymbolName();
+      symbol->setNamedPointSymbol( name );
+    *img = symbol->getPointSymbolAsImage( renderContext.scaleFactor(), selected, mSelectionColor,
+                                          fieldScale, rotation, renderContext.rasterScaleFactor() );
+      symbol->setNamedPointSymbol( oldName );
   // Line, polygon
   else if ( mGeometryType != QGis::Point )
@@ -147,23 +164,23 @@
     if ( !selected )
       QPen pen = symbol->pen();
       p->setPen( pen );
         QBrush brush = symbol->brush();
     else
@@ -259,6 +276,11 @@
Modified: trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h
--- trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/renderer/qgsuniquevaluerenderer.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -31,7 +31,11 @@
+    /** Render feature
+     * added in 1.2 */
Modified: trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp
--- trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/symbology/qgsmarkercatalogue.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -47,7 +47,13 @@
 QgsMarkerCatalogue::QgsMarkerCatalogue()
+  refreshList();
+void QgsMarkerCatalogue::refreshList()
   // Init list
+  mList.clear();
   // Hardcoded markers
   mList.append( "hard:circle" );
@@ -65,7 +71,7 @@
   // SVG
   QString svgPath = QgsApplication::svgPath();
-  // TODO recursiv ?
+  // TODO recursive ?
   QDir dir( svgPath );
   QStringList dl = dir.entryList( QDir::Dirs );
@@ -84,6 +90,8 @@
       mList.append( "svg:" + svgPath + *it + "/" + *it2 );
+  emit markersRefreshed();
 QStringList QgsMarkerCatalogue::list()
@@ -120,7 +128,7 @@
   QImage myImage;
   int imageSize;
-  if ( fullName.left( 5 ) == "hard:" )
+  if ( fullName.startsWith( "hard:" ) )
     int pw = (( pen.width() == 0 ? 1 : pen.width() ) + 1 ) / 2 * 2; // make even (round up); handle cosmetic pen
     imageSize = (( int ) size + pw ) / 2 * 2 + 1; //  make image width, height odd; account for pen width
@@ -145,7 +153,7 @@
   // Now pass the paintdevice along to have the marker rendered on it
-  if ( fullName.left( 4 ) == "svg:" )
+  if ( fullName.startsWith( "svg:" ) )
     if ( svgMarker( &myPainter, fullName.mid( 4 ), size ) )
       return myImage;
@@ -154,8 +162,26 @@
     fullName = "hard:circle";
+  if ( fullName.startsWith( "font:" ) )
+    if ( fontMarker( &myPainter, fullName.mid( 5 ), size ) )
+      return myImage;
+    QgsDebugMsg( QString( "%1 not found - replacing with hard:circle" ).arg( fullName ) );
+    fullName = "hard:circle";
+  if ( fullName.endsWith( ".svg", Qt::CaseInsensitive ) )
+    if ( svgMarker( &myPainter, fullName, size ) )
+      return myImage;
     hardMarker( &myPainter, imageSize, fullName.mid( 5 ), size, pen, brush, qtBug );
 #ifdef IMAGEDEBUG
     QgsDebugMsg( "*** Saving hard marker to hardMarker.png ***" );
@@ -214,6 +240,40 @@
   return QPicture(); // empty
+bool QgsMarkerCatalogue::fontMarker( QPainter *thepPainter, QString fullName, double scaleFactor )
+  QStringList args = fullName.split( "," );
+  if ( args.size() == 0 )
+    return false;
+  QChar c;
+  if ( args.size() > 0 )
+    if ( args[0] == "#" )
+      c = QChar( '#' );
+    else if ( args[0].startsWith( "#" ) )
+      c = QChar( args[0].mid( 1 ).toInt() );
+    else
+      c = args[0][0];
+  QString family = args.size() >= 2 ? args[1] : "Helvetica";
+  int weight = args.size() >= 3 ? args[2].toInt() : -1;
+  int italic = args.size() >= 4 ? args[3].toInt() != 0 : false;
+  thepPainter->setFont( QFont( family, scaleFactor, weight, italic ) );
+  thepPainter->drawText( 0, 0, c );
+  return true;
 bool QgsMarkerCatalogue::svgMarker( QPainter * thepPainter, QString fileName, double scaleFactor )
   QSvgRenderer mySVG;
Modified: trunk/qgis/src/core/symbology/qgsmarkercatalogue.h
--- trunk/qgis/src/core/symbology/qgsmarkercatalogue.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/symbology/qgsmarkercatalogue.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -27,9 +27,9 @@
-class CORE_EXPORT QgsMarkerCatalogue
+class CORE_EXPORT QgsMarkerCatalogue : public QObject
+    Q_OBJECT
   public:
     //! Destructor
     ~QgsMarkerCatalogue();
@@ -53,6 +53,13 @@
     static bool svgMarker( QPainter * thepPainter, QString name, double size );
+  public slots:
+  signals:
   private:
     /**Constructor*/
@@ -66,6 +73,8 @@
     /** Hard coded */
     void hardMarker( QPainter * thepPainter, int imageSize, QString name, double size, QPen pen, QBrush brush, bool qtBug = true );
+    bool fontMarker( QPainter * thepPainter, QString name, double size );
 #endif // QGSMARKERCATALOGUE_H
Modified: trunk/qgis/src/core/symbology/qgssymbol.cpp
--- trunk/qgis/src/core/symbology/qgssymbol.cpp	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/symbology/qgssymbol.cpp	2009-07-23 10:59:59 UTC (rev 11152)
@@ -43,13 +43,15 @@
     mLabel( label ),
     mType( t ),
     mPointSymbolName( "hard:circle" ),
-    mPointSize( DEFAULT_POINT_SIZE ),
+    mSize( DEFAULT_POINT_SIZE ),
+    mSizeInMapUnits( false ),
     mPointSymbolImage( 1, 1, QImage::Format_ARGB32_Premultiplied ),
     mWidthScale( -1.0 ),
     mCacheUpToDate( false ),
     mCacheUpToDate2( false ),
     mRotationClassificationField( -1 ),
-    mScaleClassificationField( -1 )
+    mScaleClassificationField( -1 ),
+    mSymbolField( -1 )
   mPen.setWidthF( DEFAULT_LINE_WIDTH );
@@ -63,26 +65,30 @@
     mPen( c ),
     mBrush( c ),
 QgsSymbol::QgsSymbol()
     : mPointSymbolName( "hard:circle" ),
@@ -92,13 +98,15 @@
     : mPen( c ),
     mBrush( c ),
@@ -115,7 +123,8 @@
     mBrush = s.mBrush;
     mTextureFilePath = s.mTextureFilePath;
     mPointSymbolName = s.mPointSymbolName;
-    mPointSize = s.mPointSize;
+    mSize = s.mSize;
+    mSizeInMapUnits = s.mSizeInMapUnits;
     mPointSymbolImage = s.mPointSymbolImage;
     mPointSymbolImageSelected = s.mPointSymbolImageSelected;
     mWidthScale = s.mWidthScale;
@@ -127,6 +136,7 @@
     mSelectionColor2 = s.mSelectionColor2;
     mRotationClassificationField = s.mRotationClassificationField;
     mScaleClassificationField = s.mScaleClassificationField;
+    mSymbolField = s.mSymbolField;
@@ -196,50 +206,53 @@
 void QgsSymbol::setNamedPointSymbol( QString name )
-  // do some sanity checking for svgs...
-  QString myTempName = name;
-  myTempName.replace( "svg:", "" );
-  QFile myFile( myTempName );
-  if ( !myFile.exists() )
+  if ( name.startsWith( "svg:" ) )
-    QgsDebugMsg( "\n\n\n *** Svg Symbol not found on fs ***" );
-    QgsDebugMsg( "Name: " + name );
-    //see if we can resolve the problem...
-    //by using the qgis svg dir from this local machine
-    //one day when user specified svg are allowed we need
-    //to adjust this logic probably...
-    QString svgPath = QgsApplication::svgPath();
-    QgsDebugMsg( "SvgPath: " + svgPath );
-    QFileInfo myInfo( myTempName );
-    QString myFileName = myInfo.fileName(); // foo.svg
-    QString myLowestDir = myInfo.dir().dirName();
-    QString myLocalPath = svgPath + QDir::separator() +
-                          myLowestDir + QDir::separator() +
-                          myFileName;
-    QgsDebugMsg( "Alternative svg path: " + myLocalPath );
-    if ( QFile( myLocalPath ).exists() )
+    // do some sanity checking for svgs...
+    QString myTempName = name;
+    myTempName.replace( "svg:", "" );
+    QFile myFile( myTempName );
+    if ( !myFile.exists() )
-      name = "svg:" + myLocalPath;
-      QgsDebugMsg( "Svg found in alternative path" );
-    else if ( myInfo.isRelative() )
-      QFileInfo pfi( QgsProject::instance()->fileName() );
-      if ( pfi.exists() && QFile( pfi.canonicalPath() + QDir::separator() + myTempName ).exists() )
+      QgsDebugMsg( "\n\n\n *** Svg Symbol not found on fs ***" );
+      QgsDebugMsg( "Name: " + name );
+      //see if we can resolve the problem...
+      //by using the qgis svg dir from this local machine
+      //one day when user specified svg are allowed we need
+      //to adjust this logic probably...
+      QString svgPath = QgsApplication::svgPath();
+      QgsDebugMsg( "SvgPath: " + svgPath );
+      QFileInfo myInfo( myTempName );
+      QString myFileName = myInfo.fileName(); // foo.svg
+      QString myLowestDir = myInfo.dir().dirName();
+      QString myLocalPath = svgPath + QDir::separator() +
+                            myLowestDir + QDir::separator() +
+                            myFileName;
+      QgsDebugMsg( "Alternative svg path: " + myLocalPath );
+      if ( QFile( myLocalPath ).exists() )
-        name = "svg:" + pfi.canonicalPath() + QDir::separator() + myTempName;
+        name = "svg:" + myLocalPath;
+      else if ( myInfo.isRelative() )
+        QFileInfo pfi( QgsProject::instance()->fileName() );
+        if ( pfi.exists() && QFile( pfi.canonicalPath() + QDir::separator() + myTempName ).exists() )
+          name = "svg:" + pfi.canonicalPath() + QDir::separator() + myTempName;
+          QgsDebugMsg( "Svg found in alternative path" );
+        else
+          QgsDebugMsg( "Svg not found in project path" );
       else
-        QgsDebugMsg( "Svg not found in project path" );
+        //couldnt find the file, no happy ending :-(
+        QgsDebugMsg( "Computed alternate path but no svg there either" );
-    else
-      //couldnt find the file, no happy ending :-(
-      QgsDebugMsg( "Computed alternate path but no svg there either" );
   mPointSymbolName = name;
   mCacheUpToDate = mCacheUpToDate2 = false;
@@ -250,22 +263,35 @@
   return mPointSymbolName;
+void QgsSymbol::setPointSizeUnits( bool sizeInMapUnits )
+  mSizeInMapUnits = sizeInMapUnits;
+bool QgsSymbol::pointSizeUnits() const
+  return mSizeInMapUnits;
 void QgsSymbol::setPointSize( double s )
-  if ( s < MINIMUM_POINT_SIZE )
-    mPointSize = MINIMUM_POINT_SIZE;
+  if ( mSizeInMapUnits )
+    mSize = s;
+  else if ( s < MINIMUM_POINT_SIZE )
+    mSize = MINIMUM_POINT_SIZE;
   else
-    mPointSize = s;
+    mSize = s;
 double QgsSymbol::pointSize() const
-  return mPointSize;
+  return mSize;
 QImage QgsSymbol::getLineSymbolAsImage()
   //Note by Tim: dont use premultiplied - it causes
@@ -374,15 +400,19 @@
     pen.setColor( selectionColor );
     QBrush brush = mBrush;
     preRotateImage = QgsMarkerCatalogue::instance()->imageMarker(
-                       mPointSymbolName, ( float )( mPointSize * scale * widthScale *
-                                                    rasterScaleFactor ),
+                       mPointSymbolName,
+                       ( float )( mSize * scale * widthScale * rasterScaleFactor ),
                        pen, mBrush );
   else
+    QgsDebugMsg( QString( "marker:%1 mPointSize:%2 mPointSizeUnits:%3 scale:%4 widthScale:%5 rasterScaleFactor:%6" )
+                 .arg( mPointSymbolName )
+                 .arg( mSize ).arg( mSizeInMapUnits ? "true" : "false" )
+                 .arg( scale ).arg( widthScale ).arg( rasterScaleFactor ) );
+                       mPointSymbolName,
                        pen, mBrush );
@@ -403,11 +433,11 @@
   // composer. Not sure why...
   // brush.setColor ( selectionColor );
-  mPointSymbolImage = QgsMarkerCatalogue::instance()->imageMarker( mPointSymbolName, mPointSize,
+  mPointSymbolImage = QgsMarkerCatalogue::instance()->imageMarker( mPointSymbolName, mSize,
                       mPen, mBrush );
   mPointSymbolImageSelected = QgsMarkerCatalogue::instance()->imageMarker(
-                                mPointSymbolName, mPointSize, pen, brush );
+                                mPointSymbolName, mSize, pen, brush );
   mSelectionColor = selectionColor;
   mCacheUpToDate = true;
@@ -420,7 +450,7 @@
   QPen pen = mPen;
-  mPointSymbolImage2 = QgsMarkerCatalogue::instance()->imageMarker( mPointSymbolName, mPointSize * widthScale,
+  mPointSymbolImage2 = QgsMarkerCatalogue::instance()->imageMarker( mPointSymbolName, mSize * widthScale,
                        pen, mBrush, false );
@@ -428,7 +458,7 @@
   mPointSymbolImageSelected2 = QgsMarkerCatalogue::instance()->imageMarker(
-                                 mPointSymbolName, mPointSize * widthScale, pen, brush,  false );
+                                 mPointSymbolName, mSize * widthScale, pen, brush,  false );
   mSelectionColor2 = selectionColor;
@@ -492,6 +522,7 @@
     appendField( symbol, document, *vl, "rotationclassificationfieldname", mRotationClassificationField );
     appendField( symbol, document, *vl, "scaleclassificationfieldname", mScaleClassificationField );
+    appendField( symbol, document, *vl, "symbolfieldname", mSymbolField );
   QDomElement outlinecolor = document.createElement( "outlinecolor" );
@@ -580,16 +611,25 @@
   QDomNode psizenode = synode.namedItem( "pointsize" );
-  if ( !  psizenode.isNull() )
+  if ( ! psizenode.isNull() )
     QDomElement psizeelement = psizenode.toElement();
     setPointSize( psizeelement.text().toFloat() );
+  QDomNode psizeunitnodes = synode.namedItem( "pointsizeunits" );
+  if ( ! psizeunitnodes.isNull() )
+    QDomElement psizeunitelement = psizeunitnodes.toElement();
+    QgsDebugMsg( QString( "psizeunitelement:%1" ).arg( psizeunitelement.text() ) );
+    setPointSizeUnits( psizeunitelement.text().compare( "mapunits", Qt::CaseInsensitive ) == 0 );
   if ( vl )
     mRotationClassificationField = readFieldName( synode, "rotationclassificationfield", *vl );
     mScaleClassificationField = readFieldName( synode, "scaleclassificationfield", *vl );
+    mSymbolField = readFieldName( synode, "symbolfield", *vl );
   else
@@ -650,3 +690,13 @@
   mScaleClassificationField = field;
+int QgsSymbol::symbolField() const
+  return mSymbolField;
+void QgsSymbol::setSymbolField( int field )
+  mSymbolField = field;
Modified: trunk/qgis/src/core/symbology/qgssymbol.h
--- trunk/qgis/src/core/symbology/qgssymbol.h	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/core/symbology/qgssymbol.h	2009-07-23 10:59:59 UTC (rev 11152)
@@ -34,7 +34,6 @@
   (lower value, upper value)*/
 class CORE_EXPORT QgsSymbol
   public:
     /**Constructor*/
     QgsSymbol( QGis::GeometryType t, QString lvalue = "", QString uvalue = "", QString label = "" );
@@ -86,10 +85,17 @@
     virtual void setNamedPointSymbol( QString name );
     /**Get point symbol*/
     virtual QString pointSymbolName() const;
-    /**Set size*/
+    /**Set point size*/
     virtual void setPointSize( double s );
     /**Get size*/
     virtual double pointSize() const;
+    /**Set point size units*/
+    virtual void setPointSizeUnits( bool sizeInMapUnits );
+    /**get point size units*/
+    virtual bool pointSizeUnits() const;
     //! Destructor
     virtual ~QgsSymbol();
@@ -135,6 +141,12 @@
     \param field the number of the field to classify for scale*/
     void setScaleClassificationField( int field );
+    /**Returns the number of the symbol field*/
+    int symbolField() const;
+    /**Sets the number of the symbol field
+    \param field the number of the field to select the symbol*/
+    void setSymbolField( int field );
   protected:
     /**Lower value for classification*/
@@ -150,9 +162,12 @@
     QString mTextureFilePath;
     /* Point symbol name */
     QString mPointSymbolName;
-    /* Point size */
-    double mPointSize;
+    /* size */
+    double mSize;
+    /* units of size */
+    bool mSizeInMapUnits;
     /* TODO Because for printing we always need a symbol without oversampling but with line width scale,
      *      we keep also separate picture with line width scale */
@@ -197,6 +212,7 @@
     /**Index of the classification fields (it must be a numerical field index)*/
     int mRotationClassificationField;
     int mScaleClassificationField;
+    int mSymbolField;
   private:
     int readFieldName( QDomNode &synode, QString name, const QgsVectorLayer &vl );
Modified: trunk/qgis/src/ui/qgssinglesymboldialogbase.ui
--- trunk/qgis/src/ui/qgssinglesymboldialogbase.ui	2009-07-23 09:41:59 UTC (rev 11151)
+++ trunk/qgis/src/ui/qgssinglesymboldialogbase.ui	2009-07-23 10:59:59 UTC (rev 11152)
@@ -5,7 +5,7 @@
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>486</width>
+    <width>717</width>
     <height>529</height>
    </rect>
   </property>
@@ -64,109 +64,6 @@
      </item>
     </layout>
    </item>
-   <item row="1" column="0" >
-    <widget class="QGroupBox" name="mGroupPoint" >
-     <property name="sizePolicy" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
-       <horstretch>0</horstretch>
-       <verstretch>0</verstretch>
-      </sizepolicy>
-     </property>
-     <property name="title" >
-      <string>Point Symbol</string>
-     </property>
-     <layout class="QGridLayout" >
-      <item row="0" column="0" colspan="3" >
-       <widget class="QListWidget" name="lstSymbols" >
-        <property name="showDropIndicator" stdset="0" >
-         <bool>false</bool>
-        </property>
-        <property name="dragDropMode" >
-         <enum>QAbstractItemView::NoDragDrop</enum>
-        </property>
-        <property name="alternatingRowColors" >
-        </property>
-        <property name="iconSize" >
-         <size>
-          <width>0</width>
-          <height>-1</height>
-         </size>
-        </property>
-        <property name="resizeMode" >
-         <enum>QListView::Adjust</enum>
-        </property>
-        <property name="viewMode" >
-         <enum>QListView::IconMode</enum>
-        </property>
-        <property name="uniformItemSizes" >
-         <bool>true</bool>
-        </property>
-        <property name="wordWrap" >
-        </property>
-       </widget>
-      </item>
-       <widget class="QLabel" name="textLabel1_3" >
-        <property name="text" >
-         <string>Rotation field</string>
-        </property>
-        <property name="buddy" >
-         <cstring>mRotationClassificationComboBox</cstring>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="1" >
-       <widget class="QLabel" name="textLabel9" >
-         <string>Area scale field</string>
-        </property>
-         <cstring>mScaleClassificationComboBox</cstring>
-        </property>
-       </widget>
-      </item>
-      <item row="1" column="2" >
-       <widget class="QLabel" name="textLabel1_2" >
-         <string>Size</string>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="0" >
-       <widget class="QComboBox" name="mRotationClassificationComboBox" >
-        <property name="minimumSize" >
-         <size>
-          <width>0</width>
-          <height>20</height>
-         </size>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="1" >
-       <widget class="QComboBox" name="mScaleClassificationComboBox" >
-         <size>
-          <width>0</width>
-         </size>
-        </property>
-       </widget>
-      </item>
-      <item row="2" column="2" >
-       <widget class="QDoubleSpinBox" name="mPointSizeSpinBox" >
-        <property name="singleStep" >
-         <double>0.100000000000000</double>
-        </property>
-        <property name="value" >
-         <double>1.000000000000000</double>
-        </property>
-       </widget>
-      </item>
-     </layout>
-    </widget>
-   </item>
     <widget class="QGroupBox" name="groupBox_3" >
@@ -345,8 +242,135 @@
        </layout>
       </item>
      </layout>
+     <zorder>outlinecolorlabel_2</zorder>
+     <zorder>cboOutlineStyle</zorder>
+     <zorder>outlinecolorlabel</zorder>
+     <zorder>btnOutlineColor</zorder>
+     <zorder>outlinewidthlabel</zorder>
+     <zorder>outlinewidthspinbox</zorder>
+     <zorder>fillcolorlabel</zorder>
+     <zorder>btnFillColor</zorder>
+     <zorder>fillcolorlabel_2</zorder>
+     <zorder>mGroupPoint</zorder>
     </widget>
    </item>
+   <item row="1" column="0" >
+    <widget class="QGroupBox" name="mGroupPoint" >
+     <property name="sizePolicy" >
+      <sizepolicy vsizetype="Fixed" hsizetype="Expanding" >
+       <horstretch>0</horstretch>
+       <verstretch>0</verstretch>
+      </sizepolicy>
+     </property>
+     <property name="title" >
+      <string>Point Symbol</string>
+     </property>
+     <layout class="QGridLayout" >
+      <item row="0" column="0" colspan="5" >
+       <widget class="QListWidget" name="lstSymbols" >
+        <property name="dragDropMode" >
+         <enum>QAbstractItemView::DragDrop</enum>
+        </property>
+        <property name="alternatingRowColors" >
+         <bool>false</bool>
+        </property>
+        <property name="iconSize" >
+         <size>
+          <width>0</width>
+          <height>-1</height>
+         </size>
+        </property>
+        <property name="resizeMode" >
+         <enum>QListView::Adjust</enum>
+        </property>
+        <property name="viewMode" >
+         <enum>QListView::IconMode</enum>
+        </property>
+        <property name="uniformItemSizes" >
+         <bool>true</bool>
+        </property>
+        <property name="wordWrap" >
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="0" >
+       <widget class="QLabel" name="textLabel1_3" >
+        <property name="text" >
+         <string>Rotation field</string>
+        </property>
+        <property name="buddy" >
+         <cstring>mRotationClassificationComboBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="1" >
+       <widget class="QComboBox" name="mRotationClassificationComboBox" >
+        <property name="minimumSize" >
+         <size>
+          <width>0</width>
+          <height>20</height>
+         </size>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="1" >
+       <widget class="QComboBox" name="mScaleClassificationComboBox" >
+         <size>
+          <width>0</width>
+         </size>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="0" >
+       <widget class="QLabel" name="textLabel9" >
+         <string>Area scale field</string>
+        </property>
+         <cstring>mScaleClassificationComboBox</cstring>
+        </property>
+       </widget>
+      </item>
+      <item row="2" column="3" >
+       <widget class="QComboBox" name="mSymbolComboBox" />
+      </item>
+      <item row="2" column="2" >
+       <widget class="QLabel" name="label" >
+         <string>Symbol field</string>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="2" >
+       <widget class="QLabel" name="textLabel1_2" >
+         <string>Size</string>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="3" >
+       <widget class="QDoubleSpinBox" name="mPointSizeSpinBox" >
+        <property name="singleStep" >
+         <double>0.100000000000000</double>
+        </property>
+        <property name="value" >
+         <double>1.000000000000000</double>
+        </property>
+       </widget>
+      </item>
+      <item row="3" column="4" >
+       <widget class="QCheckBox" name="mPointSizeUnitsCheckBox" >
+         <string>Size in map units</string>
+        </property>
+       </widget>
+      </item>
+     </layout>
+    </widget>
+   </item>
   </layout>
  </widget>
  <layoutdefault spacing="6" margin="11" />
@@ -360,9 +384,6 @@
  <tabstops>
   <tabstop>mLabelEdit</tabstop>
   <tabstop>lstSymbols</tabstop>
-  <tabstop>mRotationClassificationComboBox</tabstop>
-  <tabstop>mScaleClassificationComboBox</tabstop>
-  <tabstop>mPointSizeSpinBox</tabstop>
   <tabstop>cboOutlineStyle</tabstop>
   <tabstop>btnOutlineColor</tabstop>
   <tabstop>outlinewidthspinbox</tabstop>
More information about the QGIS-commit mailing list
