[QGIS Commit] r11180 - in branches/symbology-ng-branch/src:
core/pal plugins/labeling
svn_qgis at osgeo.org
Sun Jul 26 11:57:32 EDT 2009
Author: wonder
Date: 2009-07-26 11:57:31 -0400 (Sun, 26 Jul 2009)
New Revision: 11180
branches/symbology-ng-branch/src/core/pal/pal.cpp
branches/symbology-ng-branch/src/core/pal/pal.h
branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.cpp
branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.ui
branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp
branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h
Added an option to show also colliding labels (in engine configuration)
Modified: branches/symbology-ng-branch/src/core/pal/pal.cpp
--- branches/symbology-ng-branch/src/core/pal/pal.cpp 2009-07-26 11:04:17 UTC (rev 11179)
+++ branches/symbology-ng-branch/src/core/pal/pal.cpp 2009-07-26 15:57:31 UTC (rev 11180)
@@ -956,7 +956,7 @@
return prob;
- std::list<LabelPosition*>* Pal::solveProblem(Problem* prob)
+ std::list<LabelPosition*>* Pal::solveProblem(Problem* prob, bool displayAll )
if (prob == NULL)
return new std::list<LabelPosition*>();
@@ -970,7 +970,7 @@
else
prob->popmusic();
- return prob->getSolution( false );
+ return prob->getSolution( displayAll );
Modified: branches/symbology-ng-branch/src/core/pal/pal.h
--- branches/symbology-ng-branch/src/core/pal/pal.h 2009-07-26 11:04:17 UTC (rev 11179)
+++ branches/symbology-ng-branch/src/core/pal/pal.h 2009-07-26 15:57:31 UTC (rev 11180)
@@ -340,7 +340,7 @@
Problem* extractProblem(double scale, double bbox[4]);
- std::list<LabelPosition*>* solveProblem(Problem* prob);
+ std::list<LabelPosition*>* solveProblem(Problem* prob, bool displayAll);
* \brief Set map resolution
Modified: branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.cpp
--- branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.cpp 2009-07-26 11:04:17 UTC (rev 11179)
+++ branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.cpp 2009-07-26 15:57:31 UTC (rev 11180)
@@ -20,6 +20,8 @@
spinCandPolygon->setValue(candPolygon);
chkShowCandidates->setChecked( mLBL->isShowingCandidates() );
+ chkShowAllLabels->setChecked( mLBL->isShowingAllLabels() );
@@ -34,5 +36,7 @@
mLBL->setShowingCandidates( chkShowCandidates->isChecked() );
+ mLBL->setShowingAllLabels( chkShowAllLabels->isChecked() );
accept();
Modified: branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.ui
--- branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.ui 2009-07-26 11:04:17 UTC (rev 11179)
+++ branches/symbology-ng-branch/src/plugins/labeling/engineconfigdialog.ui 2009-07-26 15:57:31 UTC (rev 11180)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>286</width>
- <height>250</height>
+ <width>316</width>
+ <height>271</height>
</rect>
</property>
<property name="windowTitle">
@@ -173,6 +173,13 @@
</spacer>
</item>
<item>
+ <widget class="QCheckBox" name="chkShowAllLabels">
+ <property name="text">
+ <string>Show all labels (i.e. including colliding labels)</string>
+ </property>
+ </widget>
+ </item>
+ <item>
<widget class="QCheckBox" name="chkShowCandidates">
<string>Show label candidates (for debugging)</string>
Modified: branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp
--- branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp 2009-07-26 11:04:17 UTC (rev 11179)
+++ branches/symbology-ng-branch/src/plugins/labeling/pallabeling.cpp 2009-07-26 15:57:31 UTC (rev 11180)
@@ -184,6 +184,7 @@
mShowingCandidates = FALSE;
+ mShowingAllLabels = FALSE;
initPal();
@@ -380,7 +381,7 @@
// find the solution
- labels = mPal->solveProblem( problem );
+ labels = mPal->solveProblem( problem, mShowingAllLabels );
std::cout << "LABELING work: " << t.elapsed() << "ms ... labels# " << labels->size() << std::endl;
t.restart();
Modified: branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h
--- branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h 2009-07-26 11:04:17 UTC (rev 11179)
+++ branches/symbology-ng-branch/src/plugins/labeling/pallabeling.h 2009-07-26 15:57:31 UTC (rev 11180)
@@ -116,6 +116,9 @@
void setShowingCandidates(bool showing) { mShowingCandidates = showing; }
const QList<LabelCandidate>& candidates() { return mCandidates; }
+ bool isShowingAllLabels() const { return mShowingAllLabels; }
+ void setShowingAllLabels(bool showing) { mShowingAllLabels = showing; }
//! hook called when drawing layer before issuing select()
static int prepareLayerHook(void* context, void* layerContext, int& attrIndex);
//! hook called when drawing for every feature in a layer
@@ -143,6 +146,8 @@
// list of candidates from last labeling
QList<LabelCandidate> mCandidates;
bool mShowingCandidates;
+ bool mShowingAllLabels; // whether to avoid collisions or not
#endif // PALLABELING_H
