[QGIS Commit] r11183 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jul 27 11:35:50 EDT 2009
Author: homann
Date: 2009-07-27 11:35:50 -0400 (Mon, 27 Jul 2009)
New Revision: 11183
Added:
   trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.cpp
   trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.h
Removed:
   trunk/qgis/src/plugins/georeferencer/plugin.cpp
   trunk/qgis/src/plugins/georeferencer/plugin.h
Renaming files in georeferencer plugin
Deleted: trunk/qgis/src/plugins/georeferencer/plugin.cpp
--- trunk/qgis/src/plugins/georeferencer/plugin.cpp	2009-07-27 15:19:39 UTC (rev 11182)
+++ trunk/qgis/src/plugins/georeferencer/plugin.cpp	2009-07-27 15:35:50 UTC (rev 11183)
@@ -1,248 +0,0 @@
- *  File Name:               plugin.cpp
- *  The georeferencer plugin is a tool for adding projection info to rasters
- *    begin                : Jan 21, 2004
- *    copyright            : (C) 2004 by Tim Sutton
- *    email                : tim at linfiniti.com
- *   This program is free software; you can redistribute it and/or modify  *
- *   it under the terms of the GNU General Public License as published by  *
- *   the Free Software Foundation; either version 2 of the License, or     *
- *   (at your option) any later version.                                   *
-/*  $Id$ */
- *   QGIS Programming conventions:
- *   mVariableName - a class level member variable
- *   sVariableName - a static class level member variable
- *   variableName() - accessor for a class member (no 'get' in front of name)
- *   setVariableName() - mutator for a class member (prefix with 'set')
- *   Additional useful conventions:
- *   theVariableName - a method parameter (prefix with 'the')
- *   myVariableName - a locally declared variable within a method ('my' prefix)
- *   DO: Use mixed case variable names - myVariableName
- *   DON'T: separate variable names using underscores: my_variable_name (NO!)
-// Required qgis includes
-#include <qgisinterface.h>
-#include <qgsapplication.h>
-#include <qgsmaplayer.h>
-#include <qgsrasterlayer.h>
-#include "plugin.h"
-#include <QFile>
-//the gui subclass
-//#include "plugingui.h"
-#include "qgspointdialog.h"
-#include "qgsgeorefdescriptiondialog.h"
-static const char * const sIdent = "$Id$";
-static const QString sName = QObject::tr( "Georeferencer GDAL" );
-static const QString sDescription = QObject::tr( "Adding projection info to rasters using GDAL" );
-static const QString sPluginVersion = QObject::tr( "Version 0.1" );
-static const QgisPlugin::PLUGINTYPE sPluginType = QgisPlugin::UI;
-// THE FOLLOWING METHODS ARE MANDATORY FOR ALL PLUGINS
- * Constructor for the plugin. The plugin is passed a pointer to the main app
- * and an interface object that provides access to exposed functions in QGIS.
- * @param theQGisApp - Pointer to the QGIS main window
- * @param theQGisInterface - Pointer to the QGIS interface object
-QgsGeorefPlugin::QgsGeorefPlugin( QgisInterface * theQgisInterface ):
-    QgisPlugin( sName, sDescription, sPluginVersion, sPluginType ),
-    mQGisIface( theQgisInterface )
-QgsGeorefPlugin::~QgsGeorefPlugin()
- * Initialize the GUI interface for the plugin
-void QgsGeorefPlugin::initGui()
-  // Create the action for tool
-  mQActionPointer = new QAction( QIcon(), tr( "&Georeferencer" ), this );
-  setCurrentTheme( "" );
-  // Connect the action to the run
-  connect( mQActionPointer, SIGNAL( triggered() ), this, SLOT( run() ) );
-  // this is called when the icon theme is changed
-  connect( mQGisIface, SIGNAL( currentThemeChanged( QString ) ), this, SLOT( setCurrentTheme( QString ) ) );
-  // Add to the toolbar & menu
-  mQGisIface->addToolBarIcon( mQActionPointer );
-  mQGisIface->addPluginToMenu( tr( "&Georeferencer" ), mQActionPointer );
-  mQActionPointer = new QAction( QIcon( ":/about.png" ), tr( "&Georeferencer" ), this );
-  mQActionPointer = new QAction( "About", this );
-  connect( mQActionPointer, SIGNAL( triggered() ), SLOT( about() ) );
-  mQActionPointer = new QAction( QIcon( ":/help.png" ), tr( "&Georeferencer" ), this );
-  mQActionPointer = new QAction( "Help", this );
-  connect( mQActionPointer, SIGNAL( triggered() ), SLOT( help() ) );
-//method defined in interface
-void QgsGeorefPlugin::help()
-  QgsGeorefDescriptionDialog dlg( mQGisIface->mainWindow( ) );
-  dlg.exec();
-void QgsGeorefPlugin::about( )
-  QDialog dlg( mQGisIface->mainWindow( ) );
-  dlg.setWindowFlags( dlg.windowFlags( ) | Qt::MSWindowsFixedSizeDialogHint );
-  dlg.setWindowFlags( dlg.windowFlags( ) &~ Qt::WindowContextHelpButtonHint );
-  QVBoxLayout *lines = new QVBoxLayout( &dlg );
-  lines->addWidget( new QLabel( tr( "<b>Georeferencer GDAL</b>" ) ) );
-  lines->addWidget( new QLabel( tr( "    Based on original Georeferencer Plugin" ) ) );
-  lines->addWidget( new QLabel( tr( "<b>Developers:</b>" ) ) );
-  lines->addWidget( new QLabel( tr( "    Lars Luthman (original Georeferencer)" ) ) );
-  lines->addWidget( new QLabel( "    Lynx (lynx21.12.12 at gmail.ru)" ) );
-  lines->addWidget( new QLabel( "    Maxim Dubinin (sim at gis-lab.info)" ) );
-  lines->addWidget( new QLabel( tr( "<b>Links:</b>" ) ) );
-  QLabel *link = new QLabel( "     <a href=\"http://gis-lab.info/qa/qgis-georef-new-eng.html\">http://gis-lab.info/qa/qgis-georef-new-eng.html</a>" );
-  link->setOpenExternalLinks( true );
-  lines->addWidget( link );
-  dlg.exec( );
-// Slot called when the buffer menu item is triggered
-void QgsGeorefPlugin::run()
-//  QgsGeorefPluginGui *myPluginGui = new QgsGeorefPluginGui( mQGisIface, QgsGeorefPluginGui::findMainWindow(), Qt::Window | Qt::WindowMinimizeButtonHint);
-//  myPluginGui->show();
-//  myPluginGui->setFocus();
-  QgsPointDialog *myPlugin = new QgsPointDialog( mQGisIface, QgsPointDialog::findMainWindow(), Qt::Window | Qt::WindowMinimizeButtonHint | Qt::WindowTitleHint );
-  myPlugin->move( 0, 0 );
-  myPlugin->show();
-  myPlugin->setFocus();
-// Unload the plugin by cleaning up the GUI
-void QgsGeorefPlugin::unload()
-  // remove the GUI
-  mQGisIface->removePluginMenu( tr( "&Georeferencer" ), mQActionPointer );
-  mQGisIface->removeToolBarIcon( mQActionPointer );
-  delete mQActionPointer;
-//! Set icons to the current theme
-void QgsGeorefPlugin::setCurrentTheme( QString theThemeName )
-  QString myCurThemePath = QgsApplication::activeThemePath() + "/plugins/georeferencer.png";
-  QString myDefThemePath = QgsApplication::defaultThemePath() + "/plugins/georeferencer.png";
-  QString myQrcPath = ":/georeferencer.png";
-  if ( QFile::exists( myCurThemePath ) )
-    mQActionPointer->setIcon( QIcon( myCurThemePath ) );
-  else if ( QFile::exists( myDefThemePath ) )
-    mQActionPointer->setIcon( QIcon( myDefThemePath ) );
-  else if ( QFile::exists( myQrcPath ) )
-    mQActionPointer->setIcon( QIcon( myQrcPath ) );
-  else
-    mQActionPointer->setIcon( QIcon() );
-//                  END OF MANDATORY PLUGIN METHODS
-//  THE FOLLOWING CODE IS AUTOGENERATED BY THE PLUGIN BUILDER SCRIPT
-//    YOU WOULD NORMALLY NOT NEED TO MODIFY THIS, AND YOUR PLUGIN
-//      MAY NOT WORK PROPERLY IF YOU MODIFY THIS INCORRECTLY
- * Required extern functions needed  for every plugin
- * These functions can be called prior to creating an instance
- * of the plugin class
-// Class factory to return a new instance of the plugin class
-QGISEXTERN QgisPlugin * classFactory( QgisInterface * theQgisInterfacePointer )
-  return new QgsGeorefPlugin( theQgisInterfacePointer );
-// Return the name of the plugin - note that we do not user class members as
-// the class may not yet be insantiated when this method is called.
-QGISEXTERN QString name()
-  return sName;
-// Return the description
-QGISEXTERN QString description()
-  return sDescription;
-// Return the type (either UI or MapLayer plugin)
-QGISEXTERN int type()
-  return sPluginType;
-// Return the version number for the plugin
-QGISEXTERN QString version()
-  return sPluginVersion;
-// Delete ourself
-QGISEXTERN void unload( QgisPlugin * thePluginPointer )
-  delete thePluginPointer;
Deleted: trunk/qgis/src/plugins/georeferencer/plugin.h
--- trunk/qgis/src/plugins/georeferencer/plugin.h	2009-07-27 15:19:39 UTC (rev 11182)
+++ trunk/qgis/src/plugins/georeferencer/plugin.h	2009-07-27 15:35:50 UTC (rev 11183)
@@ -1,119 +0,0 @@
-*  File Name:               plugin.h
-*  The georeferencer plugin is a tool for adding projection info to rasters
-*    begin                : Jan 21, 2004
-*    copyright            : (C) 2004 by Tim Sutton
-*    email                : tim at linfiniti.com
-/*  $Id$ */
-#ifndef QGSGEOREFPLUGIN
-#define QGSGEOREFPLUGIN
-//QGIS Includes
-#include <qgisplugin.h>
-class QgisInterface;
-//QT Includes
-#include <QWidget>
-* \class Plugin
-* \brief [name] plugin for QGIS
-* [description]
-class QgsGeorefPlugin: public QObject, public QgisPlugin
-  Q_OBJECT public:
-    //                MANDATORY PLUGIN METHODS FOLLOW
-    * Constructor for a plugin. The QgisApp and QgisIface pointers are passed by
-    * QGIS when it attempts to instantiate the plugin.
-    * @param Pointer to the QgisApp object
-    * @param Pointer to the QgisIface object.
-    QgsGeorefPlugin( QgisInterface * );
-    //! Destructor
-    virtual ~ QgsGeorefPlugin();
-  public slots:
-    //! init the gui
-    virtual void initGui();
-    //! Show the dialog box
-    void run();
-    //! unload the plugin
-    void unload();
-    //! show the help document
-    void help();
-    //! update the plugins theme when the app tells us its theme is changed
-    void setCurrentTheme( QString theThemeName );
-    void about( );
-    //                  END OF MANDATORY PLUGIN METHODS
-  private:
-    // MANDATORY PLUGIN MEMBER DECLARATIONS  .....
-    int mPluginType;
-    //! Pointer to the QGIS interface object
-    QgisInterface *mQGisIface;
-    //!pointer to the qaction for this plugin
-    QAction * mQActionPointer;
-    // ADD YOUR OWN MEMBER DECLARATIONS AFTER THIS POINT.....
-#endif
Copied: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.cpp (from rev 11182, trunk/qgis/src/plugins/georeferencer/plugin.cpp)
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.cpp	                        (rev 0)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.cpp	2009-07-27 15:35:50 UTC (rev 11183)
@@ -0,0 +1,248 @@
+ *  File Name:               plugin.cpp
+ *  The georeferencer plugin is a tool for adding projection info to rasters
+ *    begin                : Jan 21, 2004
+ *    copyright            : (C) 2004 by Tim Sutton
+ *    email                : tim at linfiniti.com
+ *   This program is free software; you can redistribute it and/or modify  *
+ *   it under the terms of the GNU General Public License as published by  *
+ *   the Free Software Foundation; either version 2 of the License, or     *
+ *   (at your option) any later version.                                   *
+/*  $Id$ */
+ *   QGIS Programming conventions:
+ *   mVariableName - a class level member variable
+ *   sVariableName - a static class level member variable
+ *   variableName() - accessor for a class member (no 'get' in front of name)
+ *   setVariableName() - mutator for a class member (prefix with 'set')
+ *   Additional useful conventions:
+ *   theVariableName - a method parameter (prefix with 'the')
+ *   myVariableName - a locally declared variable within a method ('my' prefix)
+ *   DO: Use mixed case variable names - myVariableName
+ *   DON'T: separate variable names using underscores: my_variable_name (NO!)
+// Required qgis includes
+#include <qgisinterface.h>
+#include <qgsapplication.h>
+#include <qgsmaplayer.h>
+#include <qgsrasterlayer.h>
+#include "qgsgeorefplugin.h"
+#include <QFile>
+//the gui subclass
+//#include "plugingui.h"
+#include "qgspointdialog.h"
+#include "qgsgeorefdescriptiondialog.h"
+static const char * const sIdent = "$Id$";
+static const QString sName = QObject::tr( "Georeferencer GDAL" );
+static const QString sDescription = QObject::tr( "Adding projection info to rasters using GDAL" );
+static const QString sPluginVersion = QObject::tr( "Version 0.1" );
+static const QgisPlugin::PLUGINTYPE sPluginType = QgisPlugin::UI;
+// THE FOLLOWING METHODS ARE MANDATORY FOR ALL PLUGINS
+ * Constructor for the plugin. The plugin is passed a pointer to the main app
+ * and an interface object that provides access to exposed functions in QGIS.
+ * @param theQGisApp - Pointer to the QGIS main window
+ * @param theQGisInterface - Pointer to the QGIS interface object
+QgsGeorefPlugin::QgsGeorefPlugin( QgisInterface * theQgisInterface ):
+    QgisPlugin( sName, sDescription, sPluginVersion, sPluginType ),
+    mQGisIface( theQgisInterface )
+QgsGeorefPlugin::~QgsGeorefPlugin()
+ * Initialize the GUI interface for the plugin
+void QgsGeorefPlugin::initGui()
+  // Create the action for tool
+  mQActionPointer = new QAction( QIcon(), tr( "&Georeferencer" ), this );
+  setCurrentTheme( "" );
+  // Connect the action to the run
+  connect( mQActionPointer, SIGNAL( triggered() ), this, SLOT( run() ) );
+  // this is called when the icon theme is changed
+  connect( mQGisIface, SIGNAL( currentThemeChanged( QString ) ), this, SLOT( setCurrentTheme( QString ) ) );
+  // Add to the toolbar & menu
+  mQGisIface->addToolBarIcon( mQActionPointer );
+  mQGisIface->addPluginToMenu( tr( "&Georeferencer" ), mQActionPointer );
+  mQActionPointer = new QAction( QIcon( ":/about.png" ), tr( "&Georeferencer" ), this );
+  mQActionPointer = new QAction( "About", this );
+  connect( mQActionPointer, SIGNAL( triggered() ), SLOT( about() ) );
+  mQActionPointer = new QAction( QIcon( ":/help.png" ), tr( "&Georeferencer" ), this );
+  mQActionPointer = new QAction( "Help", this );
+  connect( mQActionPointer, SIGNAL( triggered() ), SLOT( help() ) );
+//method defined in interface
+void QgsGeorefPlugin::help()
+  QgsGeorefDescriptionDialog dlg( mQGisIface->mainWindow( ) );
+  dlg.exec();
+void QgsGeorefPlugin::about( )
+  QDialog dlg( mQGisIface->mainWindow( ) );
+  dlg.setWindowFlags( dlg.windowFlags( ) | Qt::MSWindowsFixedSizeDialogHint );
+  dlg.setWindowFlags( dlg.windowFlags( ) &~ Qt::WindowContextHelpButtonHint );
+  QVBoxLayout *lines = new QVBoxLayout( &dlg );
+  lines->addWidget( new QLabel( tr( "<b>Georeferencer GDAL</b>" ) ) );
+  lines->addWidget( new QLabel( tr( "    Based on original Georeferencer Plugin" ) ) );
+  lines->addWidget( new QLabel( tr( "<b>Developers:</b>" ) ) );
+  lines->addWidget( new QLabel( tr( "    Lars Luthman (original Georeferencer)" ) ) );
+  lines->addWidget( new QLabel( "    Lynx (lynx21.12.12 at gmail.ru)" ) );
+  lines->addWidget( new QLabel( "    Maxim Dubinin (sim at gis-lab.info)" ) );
+  lines->addWidget( new QLabel( tr( "<b>Links:</b>" ) ) );
+  QLabel *link = new QLabel( "     <a href=\"http://gis-lab.info/qa/qgis-georef-new-eng.html\">http://gis-lab.info/qa/qgis-georef-new-eng.html</a>" );
+  link->setOpenExternalLinks( true );
+  lines->addWidget( link );
+  dlg.exec( );
+// Slot called when the buffer menu item is triggered
+void QgsGeorefPlugin::run()
+//  QgsGeorefPluginGui *myPluginGui = new QgsGeorefPluginGui( mQGisIface, QgsGeorefPluginGui::findMainWindow(), Qt::Window | Qt::WindowMinimizeButtonHint);
+//  myPluginGui->show();
+//  myPluginGui->setFocus();
+  QgsPointDialog *myPlugin = new QgsPointDialog( mQGisIface, QgsPointDialog::findMainWindow(), Qt::Window | Qt::WindowMinimizeButtonHint | Qt::WindowTitleHint );
+  myPlugin->move( 0, 0 );
+  myPlugin->show();
+  myPlugin->setFocus();
+// Unload the plugin by cleaning up the GUI
+void QgsGeorefPlugin::unload()
+  // remove the GUI
+  mQGisIface->removePluginMenu( tr( "&Georeferencer" ), mQActionPointer );
+  mQGisIface->removeToolBarIcon( mQActionPointer );
+  delete mQActionPointer;
+//! Set icons to the current theme
+void QgsGeorefPlugin::setCurrentTheme( QString theThemeName )
+  QString myCurThemePath = QgsApplication::activeThemePath() + "/plugins/georeferencer.png";
+  QString myDefThemePath = QgsApplication::defaultThemePath() + "/plugins/georeferencer.png";
+  QString myQrcPath = ":/georeferencer.png";
+  if ( QFile::exists( myCurThemePath ) )
+    mQActionPointer->setIcon( QIcon( myCurThemePath ) );
+  else if ( QFile::exists( myDefThemePath ) )
+    mQActionPointer->setIcon( QIcon( myDefThemePath ) );
+  else if ( QFile::exists( myQrcPath ) )
+    mQActionPointer->setIcon( QIcon( myQrcPath ) );
+  else
+    mQActionPointer->setIcon( QIcon() );
+//                  END OF MANDATORY PLUGIN METHODS
+//  THE FOLLOWING CODE IS AUTOGENERATED BY THE PLUGIN BUILDER SCRIPT
+//    YOU WOULD NORMALLY NOT NEED TO MODIFY THIS, AND YOUR PLUGIN
+//      MAY NOT WORK PROPERLY IF YOU MODIFY THIS INCORRECTLY
+ * Required extern functions needed  for every plugin
+ * These functions can be called prior to creating an instance
+ * of the plugin class
+// Class factory to return a new instance of the plugin class
+QGISEXTERN QgisPlugin * classFactory( QgisInterface * theQgisInterfacePointer )
+  return new QgsGeorefPlugin( theQgisInterfacePointer );
+// Return the name of the plugin - note that we do not user class members as
+// the class may not yet be insantiated when this method is called.
+QGISEXTERN QString name()
+  return sName;
+// Return the description
+QGISEXTERN QString description()
+  return sDescription;
+// Return the type (either UI or MapLayer plugin)
+QGISEXTERN int type()
+  return sPluginType;
+// Return the version number for the plugin
+QGISEXTERN QString version()
+  return sPluginVersion;
+// Delete ourself
+QGISEXTERN void unload( QgisPlugin * thePluginPointer )
+  delete thePluginPointer;
Property changes on: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.cpp
___________________________________________________________________
Added: svn:keywords
   + Author Date Id Revision
Added: svn:mergeinfo
Added: svn:eol-style
   + native
Copied: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.h (from rev 11182, trunk/qgis/src/plugins/georeferencer/plugin.h)
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.h	                        (rev 0)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.h	2009-07-27 15:35:50 UTC (rev 11183)
@@ -0,0 +1,119 @@
+*  File Name:               plugin.h
+*  The georeferencer plugin is a tool for adding projection info to rasters
+*    begin                : Jan 21, 2004
+*    copyright            : (C) 2004 by Tim Sutton
+*    email                : tim at linfiniti.com
+/*  $Id$ */
+#ifndef QGSGEOREFPLUGIN
+#define QGSGEOREFPLUGIN
+//QGIS Includes
+#include <qgisplugin.h>
+class QgisInterface;
+//QT Includes
+#include <QWidget>
+* \class Plugin
+* \brief [name] plugin for QGIS
+* [description]
+class QgsGeorefPlugin: public QObject, public QgisPlugin
+  Q_OBJECT public:
+    //                MANDATORY PLUGIN METHODS FOLLOW
+    * Constructor for a plugin. The QgisApp and QgisIface pointers are passed by
+    * QGIS when it attempts to instantiate the plugin.
+    * @param Pointer to the QgisApp object
+    * @param Pointer to the QgisIface object.
+    QgsGeorefPlugin( QgisInterface * );
+    //! Destructor
+    virtual ~ QgsGeorefPlugin();
+  public slots:
+    //! init the gui
+    virtual void initGui();
+    //! Show the dialog box
+    void run();
+    //! unload the plugin
+    void unload();
+    //! show the help document
+    void help();
+    //! update the plugins theme when the app tells us its theme is changed
+    void setCurrentTheme( QString theThemeName );
+    void about( );
+    //                  END OF MANDATORY PLUGIN METHODS
+  private:
+    // MANDATORY PLUGIN MEMBER DECLARATIONS  .....
+    int mPluginType;
+    //! Pointer to the QGIS interface object
+    QgisInterface *mQGisIface;
+    //!pointer to the qaction for this plugin
+    QAction * mQActionPointer;
+    // ADD YOUR OWN MEMBER DECLARATIONS AFTER THIS POINT.....
+#endif
Property changes on: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugin.h
Added: svn:keywords
   + native
More information about the QGIS-commit mailing list
