[QGIS Commit] r11220 - in trunk/qgis/src/plugins/grass: modules-6.3 modules-6.4 modules-common
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jul 31 03:32:45 EDT 2009
Author: leolami
Date: 2009-07-31 03:32:43 -0400 (Fri, 31 Jul 2009)
New Revision: 11220
   trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
   trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
   trunk/qgis/src/plugins/grass/modules-common/r.out.gdal.qgm
Update list GRASS modules
Modified: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-31 07:18:42 UTC (rev 11219)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc	2009-07-31 07:32:43 UTC (rev 11220)
@@ -44,8 +44,8 @@
 		</section>
 		<section label="Export">
 			<section label="Export raster">
+				<grass name="r.out.gdal"/>
 				<grass name="r.out.gdal.gtiff"/>
-				<grass name="r.out.gdal"/>
 				<grass name="r.out.ascii"/>
 				<grass name="r.out.xyz"/>
 				<grass name="r.out.arc"/>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-31 07:18:42 UTC (rev 11219)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc	2009-07-31 07:32:43 UTC (rev 11220)
@@ -49,8 +49,8 @@
 		</section>
Modified: trunk/qgis/src/plugins/grass/modules-common/r.out.gdal.qgm
--- trunk/qgis/src/plugins/grass/modules-common/r.out.gdal.qgm	2009-07-31 07:18:42 UTC (rev 11219)
+++ trunk/qgis/src/plugins/grass/modules-common/r.out.gdal.qgm	2009-07-31 07:32:43 UTC (rev 11220)
@@ -1,7 +1,7 @@
 <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
-<qgisgrassmodule label="Export raster to GDAL supported formats" module="r.out.gdal">
+<qgisgrassmodule label="Export raster to various formats (GDAL library)" module="r.out.gdal">
 	<option key="input" region="no"/>
 	<option key="format" />
 	<option key="type" label="Choose appropriate format"/>
More information about the QGIS-commit mailing list
