[QGIS Commit] r10873 - in trunk/qgis/src: core core/composer
core/pal gui plugins/diagram_overlay plugins/grass/qtermwidget
svn_qgis at osgeo.org
Mon Jun 1 17:20:14 EDT 2009
Author: jef
Date: 2009-06-01 17:20:14 -0400 (Mon, 01 Jun 2009)
New Revision: 10873
trunk/qgis/src/core/composer/qgscomposeritem.cpp
trunk/qgis/src/core/pal/util.cpp
trunk/qgis/src/core/qgsoverlayobject.h
trunk/qgis/src/gui/qgscomposerview.cpp
trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
trunk/qgis/src/plugins/grass/qtermwidget/Session.cpp
trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp
trunk/qgis/src/plugins/grass/qtermwidget/Vt102Emulation.cpp
fix warnings
Modified: trunk/qgis/src/core/composer/qgscomposeritem.cpp
--- trunk/qgis/src/core/composer/qgscomposeritem.cpp 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/core/composer/qgscomposeritem.cpp 2009-06-01 21:20:14 UTC (rev 10873)
@@ -493,7 +493,7 @@
break;
case QgsComposerItem::MoveItem:
//calculate total move difference
double moveX = currentPosition.x() - mouseMoveStartPos.x();
double moveY = currentPosition.y() - mouseMoveStartPos.y();
@@ -516,7 +516,10 @@
originalItem->transform().dy() + moveRectY, \
originalItem->rect().width(), originalItem->rect().height() ) );
- return;
+ return;
+ case QgsComposerItem::NoAction:
+ break;
if ( !changeComposerItem )
@@ -544,7 +547,6 @@
if ( mComposition->plotStyle() == QgsComposition::Preview )
//size of symbol boxes depends on zoom level in composer view
- double viewScaleFactor = horizontalViewScaleFactor();
double rectHandlerSize = rectHandlerBorderTolerance();
double sizeLockSymbol = lockSymbolSize();
Modified: trunk/qgis/src/core/pal/util.cpp
--- trunk/qgis/src/core/pal/util.cpp 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/core/pal/util.cpp 2009-06-01 21:20:14 UTC (rev 10873)
@@ -553,20 +553,22 @@
std::cout << f->x[i] << ";" << f->y[i] << std::endl;
#endif
- // Butterfly detector
- // 3____0
- // \/ <--- not allowed
- // 1/__\2
- // 1____0
- // 2\/5 <--- allowed
- // 3/__\4
+ Butterfly detector
+ 3____0
+ \/ <--- not allowed
+ 1/__\2
+ 1____0
+ 2\/5 <--- allowed
+ 3/__\4
pt_a = -1;
pt_b = -1;
for ( i = 0;i < f->nbPoints - 2;i++ )
Modified: trunk/qgis/src/core/qgsoverlayobject.h
--- trunk/qgis/src/core/qgsoverlayobject.h 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/core/qgsoverlayobject.h 2009-06-01 21:20:14 UTC (rev 10873)
@@ -45,7 +45,7 @@
@note: this function is deprecated. Please use geometry() and QgsGeometry::asGeos instead*/
GEOSGeometry* getGeosGeometry();
/**Feature geometry is released when object is destructed so this function is empty. This function is deprecated and does nothing*/
- void releaseGeosGeometry( GEOSGeometry *the_geom ) {}
+ void releaseGeosGeometry( GEOSGeometry *the_geom ) { Q_UNUSED( the_geom ); }
//getters
int width() const {return mWidth;}
Modified: trunk/qgis/src/gui/qgscomposerview.cpp
--- trunk/qgis/src/gui/qgscomposerview.cpp 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/gui/qgscomposerview.cpp 2009-06-01 21:20:14 UTC (rev 10873)
@@ -226,7 +226,6 @@
else
QPointF scenePoint = mapToScene( e->pos() );
- double newWidth, newHeight; //for rubber band
switch ( mCurrentTool )
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp
--- trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlay.cpp 2009-06-01 21:20:14 UTC (rev 10873)
@@ -149,7 +149,6 @@
if ( it.value() )
QList<QgsPoint> positionList = it.value()->positions();
- const QgsCoordinateTransform* ct = context.coordinateTransform();
QList<QgsPoint>::const_iterator positionIt = positionList.constBegin();
for ( ; positionIt != positionList.constEnd(); ++positionIt )
Modified: trunk/qgis/src/plugins/grass/qtermwidget/Session.cpp
--- trunk/qgis/src/plugins/grass/qtermwidget/Session.cpp 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/plugins/grass/qtermwidget/Session.cpp 2009-06-01 21:20:14 UTC (rev 10873)
@@ -977,8 +977,7 @@
bool wasMaster = _sessions[session];
_sessions[session] = master;
- if ( !wasMaster && !master
- || wasMaster && master )
+ if ( wasMaster==master )
return;
QListIterator<Session*> iter(_sessions.keys());
Modified: trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp
--- trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp 2009-06-01 21:20:14 UTC (rev 10873)
@@ -1771,10 +1771,10 @@
int i;
int selClass;
- bool left_not_right = ( here.y() < _iPntSelCorr.y() ||
- here.y() == _iPntSelCorr.y() && here.x() < _iPntSelCorr.x() );
- bool old_left_not_right = ( _pntSelCorr.y() < _iPntSelCorr.y() ||
- _pntSelCorr.y() == _iPntSelCorr.y() && _pntSelCorr.x() < _iPntSelCorr.x() );
+ bool left_not_right = here.y() < _iPntSelCorr.y() ||
+ ( here.y() == _iPntSelCorr.y() && here.x() < _iPntSelCorr.x() );
+ bool old_left_not_right = _pntSelCorr.y() < _iPntSelCorr.y() ||
+ ( _pntSelCorr.y() == _iPntSelCorr.y() && _pntSelCorr.x() < _iPntSelCorr.x() );
swapping = left_not_right != old_left_not_right;
// Find left (left_not_right ? from here : from start)
@@ -1848,10 +1848,10 @@
int i;
int selClass;
Modified: trunk/qgis/src/plugins/grass/qtermwidget/Vt102Emulation.cpp
--- trunk/qgis/src/plugins/grass/qtermwidget/Vt102Emulation.cpp 2009-06-01 21:18:16 UTC (rev 10872)
+++ trunk/qgis/src/plugins/grass/qtermwidget/Vt102Emulation.cpp 2009-06-01 21:20:14 UTC (rev 10873)
@@ -1248,7 +1248,7 @@
void Vt102Emulation::scan_buffer_report()
- if (ppos == 0 || ppos == 1 && (pbuf[0] & 0xff) >= 32) return;
+ if (ppos == 0 || (ppos == 1 && (pbuf[0] & 0xff) >= 32) ) return;
printf("token: "); hexdump(pbuf,ppos); printf("\n");
