[QGIS Commit] r10895 - trunk/qgis/src/app/legend
svn_qgis at osgeo.org
Tue Jun 9 18:28:08 EDT 2009
Author: wonder
Date: 2009-06-09 18:28:08 -0400 (Tue, 09 Jun 2009)
New Revision: 10895
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/legend/qgslegendlayer.cpp
trunk/qgis/src/app/legend/qgslegendlayer.h
Change layer's icon in legend to reflext that the layer is editable.
Removed duplicate function.
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2009-06-09 12:38:11 UTC (rev 10894)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2009-06-09 22:28:08 UTC (rev 10895)
@@ -506,7 +506,7 @@
QgsLegendLayer * llayer = new QgsLegendLayer( layer->name() );//generate entry for mStateOfCheckBoxes below
QgsLegendLayerFileGroup * llfgroup = new QgsLegendLayerFileGroup( llayer, QString( "Files" ) );
QgsLegendLayerFile * llfile = new QgsLegendLayerFile( llfgroup, QgsLegendLayerFile::nameFromLayer( layer ), layer );
- llayer->setLayerTypeIcon();
+ llayer->updateIcon();
llayer->setToolTip( 0, layer->publicSource() );
//set the correct check states
@@ -547,6 +547,10 @@
setCurrentItem( llayer );
//make the QTreeWidget item up-to-date
doItemsLayout();
+ // setup connections that will update the layer icons
+ connect(layer, SIGNAL(editingStarted()), llayer, SLOT(updateIcon()));
+ connect(layer, SIGNAL(editingStopped()), llayer, SLOT(updateIcon()));
QgsLegendLayerFile* QgsLegend::currentLayerFile()
@@ -1086,7 +1090,7 @@
//set the layer type icon if this legendlayerfile is the last in the file group
if ( child.nextSibling().isNull() )
- static_cast<QgsLegendLayer*>( theLegendLayerFile->parent()->parent() )->setLayerTypeIcon();
+ static_cast<QgsLegendLayer*>( theLegendLayerFile->parent()->parent() )->updateIcon();
theLegendLayerFile->updateLegendItem();
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp 2009-06-09 12:38:11 UTC (rev 10894)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp 2009-06-09 22:28:08 UTC (rev 10895)
@@ -84,11 +84,6 @@
myFont.setBold( true ); //visually differentiate layer labels from the rest
setFont( 0, myFont );
-void QgsLegendLayer::setLayerTypeIcon()
- QIcon myIcon( getOriginalPixmap() );
- setIcon( 0, myIcon );
bool QgsLegendLayer::isLeafNode()
@@ -407,23 +402,28 @@
if ( mapLayers().size() == 1 )
//overview
+ // FIXME: overview icon is missing
if ( theFile->isInOverview() )
// Overlay the overview icon on the default icon
- QPixmap myPixmap = QgisApp::getThemePixmap( + "mIconOverview.png" );
+ QPixmap myPixmap = QgisApp::getThemePixmap( "/mIconOverview.png" );
QPainter p( &newIcon );
p.drawPixmap( 0, 0, myPixmap );
p.end();
//editable
if ( theLayer->isEditable() )
+ QPixmap myPixmap = QgisApp::getThemePixmap( "/mIconEditable.png" );
+ // use editable icon instead of the layer's type icon
+ newIcon = myPixmap;
// Overlay the editable icon on the default icon
- QPixmap myPixmap = QgisApp::getThemePixmap( + "mIconEditable.png" );
- QPainter p( &newIcon );
+ /*QPainter p( &newIcon );
- p.end();
+ p.end();*/
Modified: trunk/qgis/src/app/legend/qgslegendlayer.h
--- trunk/qgis/src/app/legend/qgslegendlayer.h 2009-06-09 12:38:11 UTC (rev 10894)
+++ trunk/qgis/src/app/legend/qgslegendlayer.h 2009-06-09 22:28:08 UTC (rev 10895)
@@ -49,9 +49,7 @@
QgsLegendLayer( QTreeWidget*, QString );
QgsLegendLayer( QString name );
~QgsLegendLayer();
- /**Sets an icon characterising the type of layer(s) it contains.
- Note: cannot be in the constructor because layers are added after creation*/
- void setLayerTypeIcon();
bool isLeafNode();
QgsLegendItem::DRAG_ACTION accept( LEGEND_ITEM_TYPE type );
QgsLegendItem::DRAG_ACTION accept( const QgsLegendItem* li ) const;
@@ -70,10 +68,6 @@
/**Updates symbology of the layer and copies symbology to other layer files in the group*/
void refreshSymbology( const QString& key, double widthScale = 1.0 );
- /**Goes through all the legendlayerfiles and adds editing/overview pixmaps to the icon. If not all layer files
- have the same editing/overview state, a tristate is applied*/
- void updateIcon();
/** called to add appropriate menu items to legend's popup menu */
void addToPopupMenu( QMenu& theMenu, QAction* toggleEditingAction );
@@ -91,6 +85,10 @@
void saveAsShapefile();
void saveSelectionAsShapefile();
+ /**Goes through all the legendlayerfiles and adds editing/overview pixmaps to the icon. If not all layer files
+ have the same editing/overview state, a tristate is applied*/
+ void updateIcon();
protected:
/** Prepare and change symbology for vector layer */
