[QGIS Commit] r10930 - in trunk/qgis/src/plugins/grass: .
modules-6.3 modules-6.4
svn_qgis at osgeo.org
Mon Jun 15 10:39:22 EDT 2009
Author: rugginoso
Date: 2009-06-15 10:39:22 -0400 (Mon, 15 Jun 2009)
New Revision: 10930
Added:
trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
Removed:
trunk/qgis/src/plugins/grass/config/
trunk/qgis/src/plugins/grass/CMakeLists.txt
trunk/qgis/src/plugins/grass/modules-6.3/CMakeLists.txt
trunk/qgis/src/plugins/grass/modules-6.4/CMakeLists.txt
Moved default.qgc into modules directory to make the modules tree and search GRASS version dependent
Modified: trunk/qgis/src/plugins/grass/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/CMakeLists.txt 2009-06-15 14:20:26 UTC (rev 10929)
+++ trunk/qgis/src/plugins/grass/CMakeLists.txt 2009-06-15 14:39:22 UTC (rev 10930)
@@ -1,6 +1,15 @@
-SET (GRASS_MODULES_DIR "modules-${GRASS_MAJOR_VERSION}.${GRASS_MINOR_VERSION}")
-SUBDIRS(config modules-common ${GRASS_MODULES_DIR} scripts themes)
+IF (GRASS_NUM_VERSION LESS 60300)
+ SET (GRASS_MODULES_DIR "modules-6.3")
+ELSE (GRASS_NUM_VERSION LESS 60300)
+ SET (GRASS_MODULES_DIR "modules-${GRASS_MAJOR_VERSION}.${GRASS_MINOR_VERSION}")
+ENDIF (GRASS_NUM_VERSION LESS 60300)
+IF (NOT (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/${GRASS_MODULES_DIR}" AND IS_DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/${GRASS_MODULES_DIR}"))
+ MESSAGE (SEND_ERROR "Your GRASS version is not supported.")
+ENDIF (NOT (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/${GRASS_MODULES_DIR}" AND IS_DIRECTORY "${CMAKE_CURRENT_SOURCE_DIR}/${GRASS_MODULES_DIR}"))
+SUBDIRS(modules-common ${GRASS_MODULES_DIR} scripts themes)
ADD_DEFINITIONS(-DGRASS_BASE=\\\"${GRASS_PREFIX}\\\")
ADD_DEFINITIONS(-DHAVE_OPENPTY=${HAVE_OPENPTY})
Modified: trunk/qgis/src/plugins/grass/modules-6.3/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/modules-6.3/CMakeLists.txt 2009-06-15 14:20:26 UTC (rev 10929)
+++ trunk/qgis/src/plugins/grass/modules-6.3/CMakeLists.txt 2009-06-15 14:39:22 UTC (rev 10930)
@@ -2,3 +2,6 @@
INSTALL (FILES ${MODULE_FILES}
DESTINATION ${QGIS_DATA_DIR}/grass/modules)
+FILE (GLOB CONFIG *.qgc)
+INSTALL (FILES ${CONFIG}
+ DESTINATION ${QGIS_DATA_DIR}/grass/config)
Added: trunk/qgis/src/plugins/grass/modules-6.3/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.3/default.qgc (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.3/default.qgc 2009-06-15 14:39:22 UTC (rev 10930)
@@ -0,0 +1,443 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrass SYSTEM "http://mrcc.com/qgisgrass.dtd">
+<qgisgrass name="Default">
+<modules>
+<section label="GRASS MODULES">
+ <grass name="shell"/>
+ <section label="File">
+ <section label="Import">
+ <section label="Import raster">
+ <grass name="r.in.gdal.qgis"/>
+ <grass name="r.in.gdal.qgis.loc"/>
+ <grass name="r.in.gdal"/>
+ <grass name="r.in.gdal.loc"/>
+ <grass name="r.in.ascii"/>
+ <grass name="r.in.poly"/>
+ <grass name="r.in.arc"/>
+ <grass name="r.in.gridatb"/>
+ <grass name="r.in.mat"/>
+ <grass name="i.in.spotvgt"/>
+ <grass name="r.in.srtm"/>
+ <grass name="r.in.aster"/>
+ </section>
+ <section label="Import vector">
+ <grass name="v.in.ogr.qgis"/>
+ <grass name="v.in.ogr"/>
+ <grass name="v.in.ogr.qgis.loc"/>
+ <grass name="v.in.ogr.loc"/>
+ <grass name="v.in.ogr.all"/>
+ <grass name="v.in.ogr.all.loc"/>
+ <grass name="v.in.dxf"/>
+ <grass name="v.in.e00"/>
+ <grass name="v.in.mapgen"/>
+ <grass name="v.in.db"/>
+ <grass name="v.in.garmin"/>
+ <grass name="v.in.gpsbabel"/>
+ </section>
+ </section>
+ <section label="Export">
+ <section label="Export raster">
+ <grass name="r.out.gdal.gtiff"/>
+ <grass name="r.out.arc"/>
+ <grass name="r.out.gridatb"/>
+ <grass name="r.out.mat"/>
+ <grass name="r.out.bin"/>
+ <grass name="r.out.png"/>
+ <grass name="r.out.ppm"/>
+ <grass name="r.out.ppm3"/>
+ <grass name="r.out.pov"/>
+ <grass name="r.out.tiff"/>
+ <grass name="r.out.vrml"/>
+ </section>
+ <section label="Export vector">
+ <grass name="v.out.ogr"/>
+ <grass name="qgis.v.out.ogr.pg"/>
+ <grass name="v.out.ogr.gml"/>
+ <grass name="v.out.ogr.mapinfo"/>
+ <grass name="v.out.ascii"/>
+ <grass name="v.out.dxf"/>
+ </section>
+ </section>
+ <section label="Map type conversion">
+ <section label="Convert a raster to vector">
+ <grass name="r.to.vect.point"/>
+ <grass name="r.to.vect.line"/>
+ <grass name="r.to.vect.area"/>
+ </section>
+ <section label="Convert a vector to raster">
+ <grass name="v.to.rast.constant"/>
+ <grass name="v.to.rast.attr"/>
+ </section>
+ </section>
+ </section>
+ <section label="Config">
+ <section label="Region">
+ <section label="Region settings">
+ <grass name="g.region.save"/>
+ <grass name="g.region.zoom"/>
+ <grass name="g.region.multiple.raster"/>
+ <grass name="g.region.multiple.vector"/>
+ </section>
+ <section label="Projection management">
+ <section label="Print projection information of the current location">
+ <grass name="g.proj.print"/>
+ </section>
+ <section label="Print projection information from a georeferenced file">
+ <grass name="g.proj.geo"/>
+ <grass name="g.proj.ascii"/>
+ <grass name="g.proj.proj"/>
+ </section>
+ <section label="Print projection information from a georeferenced file and create a new location based on it">
+ <grass name="g.proj.geo.new"/>
+ <grass name="g.proj.ascii.new"/>
+ <grass name="g.proj.proj.new"/>
+ </section>
+ </section>
+ <section label="Convert coordinates">
+ <grass name="m.cogo"/>
+ </section>
+ </section>
+ </section>
+ <section label="Raster">
+ <section label="Develop map">
+ <section label="Compress raster">
+ <grass name="r.compress"/>
+ </section>
+ <section label="Sets the boundary definitions for a raster map">
+ <grass name="r.region.region"/>
+ <grass name="r.region.raster"/>
+ <grass name="r.region.vector"/>
+ <grass name="r.region.edge"/>
+ <grass name="r.region.alignTo"/>
+ </section>
+ <section label="Manage raster cells value">
+ <grass name="r.null.val"/>
+ <grass name="r.null.to"/>
+ <grass name="r.quant"/>
+ </section>
+ <section label="Change resolution">
+ <grass name="r.resamp.stats"/>
+ <grass name="r.resamp.interp"/>
+ <grass name="r.resample"/>
+ <grass name="r.resamp.rst"/>
+ </section>
+ <section label="Raster support">
+ <grass name="r.support"/>
+ <grass name="r.support.stats"/>
+ </section>
+ <section label="Reproject raster from another Location">
+ <grass name="r.proj"/>
+ </section>
+ </section>
+ <section label="Manage map colors">
+ <grass name="r.colors.table"/>
+ <grass name="r.colors.rules"/>
+ <grass name="r.colors.rast"/>
+ <grass name="r.blend"/>
+ <grass name="r.composite"/>
+ <grass name="r.his"/>
+ </section>
+ <section label="Spatial analysis">
+ <section label="Buffer">
+ <grass name="r.buffer"/>
+ </section>
+ <section label="Mask">
+ <grass name="r.mask"/>
+ </section>
+ <section label="Map algebra">
+ <grass name="r.mapcalc"/>
+ <grass name="r.mapcalculator"/>
+ </section>
+ <section label="Neighborhood analysis">
+ <grass name="r.neighbors"/>
+ <grass name="v.neighbors"/>
+ </section>
+ <section label="Overlay maps">
+ <grass name="r.cross"/>
+ <grass name="r.series"/>
+ <grass name="r.patch"/>
+ <grass name="r.statistics"/>
+ </section>
+ <section label="Terrain analysis">
+ <grass name="r.cost"/>
+ <grass name="r.drain"/>
+ <grass name="r.shaded.relief"/>
+ <grass name="r.slope.aspect.slope"/>
+ <grass name="r.slope.aspect.aspect"/>
+ <grass name="r.param.scale"/>
+ <grass name="r.texture"/>
+ <grass name="r.texture.bis"/>
+ <grass name="r.los"/>
+ </section>
+ <section label="Transform features">
+ <grass name="r.clump"/>
+ <grass name="r.grow"/>
+ <grass name="r.thin"/>
+ </section>
+ </section>
+ <section label="Spatial models">
+ <section label="Hydrologic modelling">
+ <grass name="r.watershed"/>
+ <grass name="r.carve"/>
+ <grass name="r.fill.dir"/>
+ <grass name="r.lake.xy"/>
+ <grass name="r.lake.seed"/>
+ <grass name="r.topidx"/>
+ <grass name="r.basins.fill"/>
+ <grass name="r.water.outlet"/>
+ </section>
+ </section>
+ <section label="Change category values and labels">
+ <grass name="r.reclass.area.greater"/>
+ <grass name="r.reclass.area.lesser"/>
+ <grass name="r.reclass"/>
+ <grass name="r.recode"/>
+ <grass name="r.rescale"/>
+ </section>
+ <section label="Surface management">
+ <section label="Create random points">
+ <grass name="r.random"/>
+ <grass name="r.random.cells"/>
+ </section>
+ <section label="Generate surface">
+ <grass name="v.kernel"/>
+ <grass name="r.surf.fractal"/>
+ <grass name="r.surf.gauss"/>
+ <grass name="r.surf.random"/>
+ </section>
+ <section label="Generate vector contour lines">
+ <grass name="r.contour"/>
+ <grass name="r.contour2"/>
+ </section>
+ <section label="Interpolate surface">
+ <grass name="v.surf.bspline"/>
+ <grass name="r.surf.idw"/>
+ <grass name="r.surf.idw2"/>
+ <grass name="v.surf.idw"/>
+ <grass name="v.surf.rst"/>
+ <grass name="r.fillnulls"/>
+ <grass name="r.surf.contour"/>
+ </section>
+ </section>
+ <section label="Reports and statistics">
+ <section label="Reports">
+ <grass name="r.category"/>
+ </section>
+ <section label="Statistics">
+ <grass name="r.sum"/>
+ <grass name="r.report"/>
+ <grass name="r.average"/>
+ <grass name="r.median"/>
+ <grass name="r.mode"/>
+ <grass name="r.volume"/>
+ <grass name="r.surf.area"/>
+ <grass name="r.univar"/>
+ <grass name="r.covar"/>
+ <grass name="r.regression.line"/>
+ <grass name="r.coin"/>
+ </section>
+ </section>
+ </section>
+ <section label="Vector">
+ <section label="Topology management">
+ <grass name="v.build.all"/>
+ </section>
+ <section label="Toolset for cleaning topology of vector map">
+ <grass name="v.clean.break"/>
+ <grass name="v.clean.snap"/>
+ <grass name="v.clean.rmdangles"/>
+ <grass name="v.clean.chdangles"/>
+ <grass name="v.clean.rmbridge"/>
+ <grass name="v.clean.chbridge"/>
+ <grass name="v.clean.rmdupl"/>
+ <grass name="v.clean.rmdac"/>
+ <grass name="v.clean.bpol"/>
+ <grass name="v.clean.prune"/>
+ <grass name="v.clean.rmarea"/>
+ <grass name="v.clean.rmline"/>
+ <grass name="v.clean.rmsa"/>
+ </section>
+ <section label="Change the type of geometry elements">
+ <grass name="v.type.lb"/>
+ <grass name="v.type.bl"/>
+ <grass name="v.type.pc"/>
+ <grass name="v.type.cp"/>
+ </section>
+ <section label="Manage features">
+ <grass name="v.centroids"/>
+ <grass name="v.build.polylines"/>
+ <grass name="v.segment"/>
+ <grass name="v.to.points"/>
+ <grass name="v.parallel"/>
+ <grass name="v.dissolve"/>
+ </section>
+ <section label="Convert 2D vector to 3D by sampling raster">
+ <grass name="v.drape"/>
+ </section>
+ <section label="Reproject vector from another Location">
+ <grass name="v.transform"/>
+ <grass name="v.proj"/>
+ </section>
+ <section label="Metadata support">
+ <grass name="v.support"/>
+ </section>
+ <section label="Generalization">
+ <grass name="v.generalize"/>
+ </section>
+ </section>
+ <section label="Database connection">
+ <grass name="v.db.connect"/>
+ <grass name="v.db.sconnect"/>
+ <grass name="v.db.what.connect"/>
+ </section>
+ <section label="Extract features from vector">
+ <grass name="v.extract.where"/>
+ <grass name="v.extract.list"/>
+ <grass name="v.select.overlap"/>
+ </section>
+ <grass name="v.buffer"/>
+ </section>
+ <section label="Vector geometry analysis">
+ <grass name="v.distance"/>
+ </section>
+ <section label="Network analysis">
+ <grass name="v.net.nodes"/>
+ <grass name="v.net.alloc"/>
+ <grass name="v.net.iso"/>
+ <grass name="v.net.salesman"/>
+ <grass name="v.net.steiner"/>
+ </section>
+ <section label="Overlay">
+ <grass name="v.patch"/>
+ <grass name="v.overlay.or"/>
+ <grass name="v.overlay.and"/>
+ <grass name="v.overlay.not"/>
+ <grass name="v.overlay.xor"/>
+ </section>
+ </section>
+ <section label="Change field">
+ <section label="Layers categories management">
+ <grass name="v.category.add"/>
+ <grass name="v.category.del"/>
+ <grass name="v.category.sum"/>
+ </section>
+ <section label="Reclass category values">
+ <grass name="v.reclass.file"/>
+ <grass name="v.reclass.attr"/>
+ </section>
+ </section>
+ <section label="Work with vector points">
+ <section label="Create standard vectors">
+ <grass name="v.in.region"/>
+ <grass name="v.mkgrid.region"/>
+ </section>
+ <section label="Create points">
+ <grass name="v.random"/>
+ </section>
+ <section label="Manage training dataset">
+ <grass name="v.kcv"/>
+ <grass name="v.outlier"/>
+ </section>
+ <section label="Delaunay triangulation, Voronoi diagram and convex hull">
+ <grass name="v.hull"/>
+ <grass name="v.delaunay.line"/>
+ <grass name="v.delaunay.area"/>
+ <grass name="v.voronoi.line"/>
+ <grass name="v.voronoi.area"/>
+ </section>
+ </section>
+ <section label="Vector update by other maps">
+ <grass name="v.rast.stats"/>
+ <grass name="v.what.vect"/>
+ <grass name="v.what.rast"/>
+ <grass name="v.sample"/>
+ </section>
+ <section label="Report and statistics">
+ <grass name="v.to.db"/>
+ <grass name="v.report"/>
+ <grass name="v.univar"/>
+ <grass name="v.normal"/>
+ </section>
+ </section>
+ <section label="Imagery">
+ <section label="Develop images and group">
+ <grass name="i.image.mosaic"/>
+ </section>
+ <section label="Manage image colors">
+ <grass name="i.rgb.his"/>
+ <grass name="i.his.rgb"/>
+ <grass name="i.landsat.rgb"/>
+ <grass name="i.fusion.brovey"/>
+ </section>
+ <section label="Filter image">
+ <grass name="i.zc"/>
+ <grass name="r.mfilter"/>
+ </section>
+ <section label="Tassled cap vegetation index">
+ <grass name="i.tasscap4"/>
+ <grass name="i.tasscap5"/>
+ <grass name="i.tasscap7"/>
+ </section>
+ <section label="Transform image">
+ <grass name="i.fft"/>
+ <grass name="i.ifft"/>
+ </section>
+ <grass name="r.describe"/>
+ <grass name="r.bitpattern"/>
+ <grass name="r.kappa"/>
+ <grass name="i.oif"/>
+ </section>
+ </section>
+ <section label="Database">
+ <section label="Database management">
+ <grass name="db.connect"/>
+ <grass name="db.connect.schema"/>
+ <grass name="qgis.db.connect-login.pg"/>
+ <grass name="v.db.reconnect.all"/>
+ <grass name="db.login"/>
+ <grass name="db.in.ogr"/>
+ </section>
+ <section label="Tables management">
+ <grass name="v.db.addtable"/>
+ <grass name="v.db.droptable"/>
+ </section>
+ <section label="Columns management">
+ <grass name="v.db.addcol"/>
+ <grass name="v.db.update_const"/>
+ <grass name="v.db.update_query"/>
+ <grass name="v.db.update_op"/>
+ <grass name="v.db.update_op_query"/>
+ <grass name="v.db.dropcol"/>
+ <grass name="v.db.renamecol"/>
+ <grass name="db.execute"/>
+ <grass name="db.select"/>
+ <grass name="v.db.select"/>
+ <grass name="v.db.select.where"/>
+ </section>
+ <section label="Others">
+ <grass name="v.db.join"/>
+ <grass name="v.db.univar"/>
+ </section>
+ </section>
+ <section label="3d Visualization">
+ <grass name="nviz"/>
+ </section>
+ <section label="Help">
+ <grass name="g.manual"/>
+ </section>
+</section>
+</modules>
+</qgisgrass>
Modified: trunk/qgis/src/plugins/grass/modules-6.4/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/modules-6.4/CMakeLists.txt 2009-06-15 14:20:26 UTC (rev 10929)
+++ trunk/qgis/src/plugins/grass/modules-6.4/CMakeLists.txt 2009-06-15 14:39:22 UTC (rev 10930)
@@ -2,3 +2,6 @@
Added: trunk/qgis/src/plugins/grass/modules-6.4/default.qgc
--- trunk/qgis/src/plugins/grass/modules-6.4/default.qgc (rev 0)
+++ trunk/qgis/src/plugins/grass/modules-6.4/default.qgc 2009-06-15 14:39:22 UTC (rev 10930)
@@ -0,0 +1,445 @@
+<modules>
+ <grass name="r.external"/>
+ <grass name="r.external.qgis"/>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+ </section>
+</section>
+</modules>
+</qgisgrass>
