[QGIS Commit] r10310 - in branches/analysis_branch: . src/analysis/interpolation
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Mar 19 14:35:46 EDT 2009
Author: mhugent
Date: 2009-03-19 14:35:46 -0400 (Thu, 19 Mar 2009)
New Revision: 10310
   branches/analysis_branch/CMakeLists.txt
   branches/analysis_branch/src/analysis/interpolation/DualEdgeTriangulation.h
   branches/analysis_branch/src/analysis/interpolation/HalfEdge.h
   branches/analysis_branch/src/analysis/interpolation/LinTriangleInterpolator.h
   branches/analysis_branch/src/analysis/interpolation/Line3D.h
   branches/analysis_branch/src/analysis/interpolation/Node.h
   branches/analysis_branch/src/analysis/interpolation/Point3D.h
   branches/analysis_branch/src/analysis/interpolation/TriangleInterpolator.h
   branches/analysis_branch/src/analysis/interpolation/Triangulation.h
   branches/analysis_branch/src/analysis/interpolation/Vector3D.h
   branches/analysis_branch/src/analysis/interpolation/qgsgridfilewriter.h
   branches/analysis_branch/src/analysis/interpolation/qgsidwinterpolator.h
   branches/analysis_branch/src/analysis/interpolation/qgsinterpolator.h
   branches/analysis_branch/src/analysis/interpolation/qgstininterpolator.h
Added ANALYSIS export macro to interpolation classes
Modified: branches/analysis_branch/CMakeLists.txt
--- branches/analysis_branch/CMakeLists.txt	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/CMakeLists.txt	2009-03-19 18:35:46 UTC (rev 10310)
@@ -270,16 +270,19 @@
     ADD_DEFINITIONS("-DCORE_EXPORT=__declspec(dllimport)")
     ADD_DEFINITIONS("-DGUI_EXPORT=__declspec(dllimport)")
     ADD_DEFINITIONS("-DPYTHON_EXPORT=__declspec(dllimport)")
+    ADD_DEFINITIONS("-DANALYSIS_EXPORT=__declspec(dllimport)")
   ELSE (MSVC)
     ADD_DEFINITIONS("\"-DCORE_EXPORT=__declspec(dllimport)\"")
     ADD_DEFINITIONS("\"-DGUI_EXPORT=__declspec(dllimport)\"")
     ADD_DEFINITIONS("\"-DPYTHON_EXPORT=__declspec(dllimport)\"")
+    ADD_DEFINITIONS("\"-DANALYSIS_EXPORT=__declspec(dllimport)\"")
   ENDIF (MSVC)
 ELSE (WIN32)
   # other compilers don't use that MSVC construct
   ADD_DEFINITIONS(-DCORE_EXPORT=)
   ADD_DEFINITIONS(-DGUI_EXPORT=)
   ADD_DEFINITIONS(-DPYTHON_EXPORT=)
+  ADD_DEFINITIONS(-DANALYSIS_EXPORT=)
 ENDIF (WIN32)
Modified: branches/analysis_branch/src/analysis/interpolation/DualEdgeTriangulation.h
--- branches/analysis_branch/src/analysis/interpolation/DualEdgeTriangulation.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/DualEdgeTriangulation.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -37,7 +37,7 @@
 #include <set>
 /**DualEdgeTriangulation is an implementation of a triangulation class based on the dual edge data structure*/
-class DualEdgeTriangulation: public Triangulation
+class ANALYSIS_EXPORT DualEdgeTriangulation: public Triangulation
   public:
     DualEdgeTriangulation();
Modified: branches/analysis_branch/src/analysis/interpolation/HalfEdge.h
--- branches/analysis_branch/src/analysis/interpolation/HalfEdge.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/HalfEdge.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -17,7 +17,7 @@
 #ifndef HALFEDGE_H
 #define HALFEDGE_H
-class HalfEdge
+class ANALYSIS_EXPORT HalfEdge
   protected:
     /**Number of the dual HalfEdge*/
Modified: branches/analysis_branch/src/analysis/interpolation/LinTriangleInterpolator.h
--- branches/analysis_branch/src/analysis/interpolation/LinTriangleInterpolator.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/LinTriangleInterpolator.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -21,7 +21,7 @@
 #include "DualEdgeTriangulation.h"
 /**LinTriangleInterpolator is a class which interpolates linearly on a triangulation*/
-class LinTriangleInterpolator : public TriangleInterpolator
+class ANALYSIS_EXPORT LinTriangleInterpolator : public TriangleInterpolator
   public:
     /**Default constructor*/
Modified: branches/analysis_branch/src/analysis/interpolation/Line3D.h
--- branches/analysis_branch/src/analysis/interpolation/Line3D.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/Line3D.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -21,7 +21,7 @@
 #include "Node.h"
 /**This class represents a line. It is implemented as a single directed linked list of nodes (with related Point3D objects). Attention: the points inserted in a line are not deleted from Line3D*/
-class Line3D
+class ANALYSIS_EXPORT Line3D
   private:
     /**copy constructor, declared privat to not use it*/
Modified: branches/analysis_branch/src/analysis/interpolation/Node.h
--- branches/analysis_branch/src/analysis/interpolation/Node.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/Node.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -21,7 +21,7 @@
 #include <iostream>
 /**Node is a class used by Line3D. It represents a node in the single directed linked list. Associated Point3D objects are deleted when the node is deleted.*/
-class Node
+class ANALYSIS_EXPORT Node
   protected:
     /**Pointer to the Point3D object associated with the node*/
Modified: branches/analysis_branch/src/analysis/interpolation/Point3D.h
--- branches/analysis_branch/src/analysis/interpolation/Point3D.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/Point3D.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -21,7 +21,7 @@
 #include <iostream>
 /**Point3D is a class to represent a three dimensional point*/
-class Point3D
+class ANALYSIS_EXPORT Point3D
   protected:
     /**X-coordinate*/
Modified: branches/analysis_branch/src/analysis/interpolation/TriangleInterpolator.h
--- branches/analysis_branch/src/analysis/interpolation/TriangleInterpolator.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/TriangleInterpolator.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -21,7 +21,7 @@
 #include <Vector3D.h>
 /**This is an interface for interpolator classes for triangulations*/
-class TriangleInterpolator
+class ANALYSIS_EXPORT TriangleInterpolator
   public:
     virtual ~TriangleInterpolator() {}
Modified: branches/analysis_branch/src/analysis/interpolation/Triangulation.h
--- branches/analysis_branch/src/analysis/interpolation/Triangulation.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/Triangulation.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -25,7 +25,7 @@
 #include <TriangleInterpolator.h>
 /**Interface for Triangulation classes*/
-class Triangulation
+class ANALYSIS_EXPORT Triangulation
   public:
     /**Enumeration describing the behaviour, if two forced lines cross. SnappingType_VERTICE means, that the second inserted forced line is snapped to the closest vertice of the first inserted forced line. DELETE_FIRST means, that the status of the first inserted forced line is reset to that of a normal edge (so that the second inserted forced line remain and the first not*/
Modified: branches/analysis_branch/src/analysis/interpolation/Vector3D.h
--- branches/analysis_branch/src/analysis/interpolation/Vector3D.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/Vector3D.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -19,7 +19,7 @@
 #include <cmath>
-class Vector3D
+class ANALYSIS_EXPORT Vector3D
       Class Vector3D represents a 3D-Vector, capable to store x-,y- and z-coordinates in double values. In fact, the class is the same as Point3D. The name 'vector' makes it easier to understand the programms.
Modified: branches/analysis_branch/src/analysis/interpolation/qgsgridfilewriter.h
--- branches/analysis_branch/src/analysis/interpolation/qgsgridfilewriter.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/qgsgridfilewriter.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -26,7 +26,7 @@
 /**A class that does interpolation to a grid and writes the results to an ascii grid*/
 //todo: extend such that writing to other file types is possible
-class QgsGridFileWriter
+class ANALYSIS_EXPORT QgsGridFileWriter
   public:
     QgsGridFileWriter( QgsInterpolator* i, QString outputPath, QgsRectangle extent, int nCols, int nRows );
Modified: branches/analysis_branch/src/analysis/interpolation/qgsidwinterpolator.h
--- branches/analysis_branch/src/analysis/interpolation/qgsidwinterpolator.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/qgsidwinterpolator.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -20,7 +20,7 @@
 #include "qgsinterpolator.h"
-class QgsIDWInterpolator: public QgsInterpolator
+class ANALYSIS_EXPORT QgsIDWInterpolator: public QgsInterpolator
   public:
     QgsIDWInterpolator( const QList<QgsVectorLayer*>& vlayers );
Modified: branches/analysis_branch/src/analysis/interpolation/qgsinterpolator.h
--- branches/analysis_branch/src/analysis/interpolation/qgsinterpolator.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/qgsinterpolator.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -23,7 +23,7 @@
 class QgsVectorLayer;
 class QgsGeometry;
-struct vertexData
+struct ANALYSIS_EXPORT vertexData
   double x;
   double y;
@@ -33,7 +33,7 @@
 /**Interface class for interpolations. Interpolators take
 the vertices of a vector layer as base data. The z-Value
 can be an attribute or the z-coordinates in case of 25D types*/
-class QgsInterpolator
+class ANALYSIS_EXPORT QgsInterpolator
   public:
     /**Describes the type of input data*/
Modified: branches/analysis_branch/src/analysis/interpolation/qgstininterpolator.h
--- branches/analysis_branch/src/analysis/interpolation/qgstininterpolator.h	2009-03-19 18:24:38 UTC (rev 10309)
+++ branches/analysis_branch/src/analysis/interpolation/qgstininterpolator.h	2009-03-19 18:35:46 UTC (rev 10310)
@@ -24,7 +24,7 @@
 class TriangleInterpolator;
 /**Interpolation in a triangular irregular network*/
-class QgsTINInterpolator: public QgsInterpolator
+class ANALYSIS_EXPORT QgsTINInterpolator: public QgsInterpolator
   public:
     QgsTINInterpolator( const QList<QgsVectorLayer*>& inputData );
More information about the QGIS-commit mailing list
