[QGIS Commit] r10442 - branches/vector_overlay_branch/src/core/pal
svn_qgis at osgeo.org
Mon Mar 30 06:17:04 EDT 2009
Author: mhugent
Date: 2009-03-30 06:17:04 -0400 (Mon, 30 Mar 2009)
New Revision: 10442
branches/vector_overlay_branch/src/core/pal/pointset.h
Fix compilation under windows
Modified: branches/vector_overlay_branch/src/core/pal/pointset.h
--- branches/vector_overlay_branch/src/core/pal/pointset.h 2009-03-28 21:39:58 UTC (rev 10441)
+++ branches/vector_overlay_branch/src/core/pal/pointset.h 2009-03-30 10:17:04 UTC (rev 10442)
@@ -1,241 +1,242 @@
- * libpal - Automated Placement of Labels Library
- * Copyright (C) 2008 Maxence Laurent, MIS-TIC, HEIG-VD
- * University of Applied Sciences, Western Switzerland
- * http://www.hes-so.ch
- * Contact:
- * maxence.laurent <at> heig-vd <dot> ch
- * or
- * eric.taillard <at> heig-vd <dot> ch
- * This file is part of libpal.
- * libpal is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 3 of the License, or
- * (at your option) any later version.
- * libpal is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with libpal. If not, see <http://www.gnu.org/licenses/>.
-#ifdef HAVE_CONFIG_H
-#include <config.h>
-#endif
-#ifndef _POINTSET_H
-#define _POINTSET_H
-#include <cfloat>
-#include <cmath>
-#include <stddef.h>
-#include <geos_c.h>
-#include "rtree.hpp"
-#include "linkedlist.hpp"
-namespace pal {
- class Pal;
- class Feat;
- class Feature;
- class Projection;
- class LabelPosition;
- typedef struct _cross {
- int pt;
- double d;
- double x;
- double y;
- int seg; // seg{0,1,2,3}
- int nextCorner; // pt{0,1,2,3}
- int way;
- } Crossing;
- class PointSet;
- typedef struct _cHullBox {
- double x[4];
- double y[4];
- double alpha;
- double width;
- double length;
- } CHullBox;
- inline bool ptrCrossingCompare (Crossing * a, Crossing * b) {
- return a == b;
- inline bool crossingDist (void *a, void *b) {
- return ( (Crossing*) a)->d > ( (Crossing*) b)->d;
- class PointSet {
- friend class Feature;
- friend class Pal;
- friend class Layer;
- friend class LabelPosition;
- friend class PolygonCostCalculator;
- friend class Problem;
- friend bool pruneLabelPositionCallback (LabelPosition *lp, void *ctx);
- //friend Feat *splitButterflyPolygon (Feat *f, int pt_a, int pt_b, double cx, double cy);
- friend bool obstacleCallback (PointSet *feat, void *ctx);
- friend bool extractFeatCallback (Feature*, void*);
- friend void extractXYCoord (Feat *f);
- friend LinkedList<Feat*> * splitGeom (GEOSGeometry *the_geom, const char *geom_id);
- friend void releaseAllInIndex (RTree<PointSet*, double, 2, double> *obstacles);
- friend bool releaseCallback (PointSet *pset, void *ctx);
- friend bool filteringCallback (PointSet*, void*);
- protected:
- int nbPoints;
- double *x;
- double *y; // points order is counterclockwise
- int *status; // -1 means inside the bbox, +1 means outside and 0 is either in either out
- int *cHull;
- int cHullSize;
- int type;
- //PointSet *parent;
- PointSet* holeOf;
- PointSet* parent;
- PointSet (double x, double y);
- PointSet (PointSet &ps);
-//public:
- double xmin;
- double xmax;
- double ymin;
- double ymax;
- PointSet ();
- PointSet (int nbPoints, double *x, double *y);
- ~PointSet();
- int getPath (int start, int stop, int *path_val);
- PointSet *extractPath (int path, int nbPtPath, int nbBboxPt, double bbx[4], double bby[4], Crossing *start, Crossing *stop, int startPt);
- PointSet* extractShape (int nbPtSh, int imin, int imax, int fps, int fpe, double fptx, double fpty);
- PointSet *createProblemSpecificPointSet (double bbx[4], double bby[4], bool *outside, bool *inside);
- CHullBox * compute_chull_bbox ();
- * \brief Take each line in shape_toProcess and only keep inside bbox line parts
- static void reduceLine (PointSet *line,
- LinkedList<PointSet*> *shapes_final,
- double bbx[4], double bby[4]);
- * \brief takes shapes from shapes_toProcess, compute intersection with bbox
- * and puts new shapes into shapes_final
- static void reducePolygon (PointSet* shape_toProcess,
- * split a concave shape into several convex shapes
- static void splitPolygons (LinkedList<PointSet*> *shapes_toProcess,
- double xrm, double yrm, char *uid);
- * \brief return the minimum distance bw this and the point (px,py)
- * compute the minimum distance bw the point (px,py) and this.
- * Optionnaly, store the nearest point in (rx,ry)
- * @param px x coordinate of the point
- * @param py y coordinate of the points
- * @param rx pointer to x coorinates of the nearest point (can be NULL)
- * @param ry pointer to y coorinates of the nearest point (can be NULL)
- double getDist(double px, double py, double *rx, double *ry);
- //double getDistInside(double px, double py);
- void getCentroid (double &px, double &py);
- * Iterate on line by real step of dl on x,y points
- * @param nbPoint # point in line
- * @param x x coord
- * @param y y coord
- * @param d ??
- * @param ad distance from pt0 to each point (ad0 = pt0->pt0)
- * @param dl ??
- * @param px current x coord on line
- * @param py current y coord on line
- inline void getPoint (double *d, double *ad, double dl,
- double *px, double *py) {
- int i;
- double dx, dy, di;
- double distr;
- i = 0;
- if (dl >= 0) {
- while (i < nbPoints && ad[i] <= dl) i++;
- i--;
- if (i < nbPoints - 1) {
- if (dl < 0) {
- dx = x[nbPoints-1] - x[0];
- dy = y[nbPoints-1] - y[0];
- di = sqrt (dx * dx + dy * dy);
- } else {
- dx = x[i+1] - x[i];
- dy = y[i+1] - y[i];
- di = d[i];
- distr = dl - ad[i];
- *px = x[i] + dx * distr / di;
- *py = y[i] + dy * distr / di;
- } else { // just select last point...
- *px = x[i];
- *py = y[i];
-} // namespace pal
-#endif
+ * libpal - Automated Placement of Labels Library
+ * Copyright (C) 2008 Maxence Laurent, MIS-TIC, HEIG-VD
+ * University of Applied Sciences, Western Switzerland
+ * http://www.hes-so.ch
+ * Contact:
+ * maxence.laurent <at> heig-vd <dot> ch
+ * or
+ * eric.taillard <at> heig-vd <dot> ch
+ * This file is part of libpal.
+ * libpal is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 3 of the License, or
+ * (at your option) any later version.
+ * libpal is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with libpal. If not, see <http://www.gnu.org/licenses/>.
+#ifdef HAVE_CONFIG_H
+#include <config.h>
+#endif
+#ifndef _POINTSET_H
+#define _POINTSET_H
+#include <cfloat>
+#include <cmath>
+#include <stddef.h>
+#include <geos_c.h>
+#include "rtree.hpp"
+#include "linkedlist.hpp"
+namespace pal {
+ class Pal;
+ class Feat;
+ class Feature;
+ class Projection;
+ class LabelPosition;
+ typedef struct _cross {
+ int pt;
+ double d;
+ double x;
+ double y;
+ int seg; // seg{0,1,2,3}
+ int nextCorner; // pt{0,1,2,3}
+ int way;
+ } Crossing;
+ class PointSet;
+ typedef struct _cHullBox {
+ double x[4];
+ double y[4];
+ double alpha;
+ double width;
+ double length;
+ } CHullBox;
+ inline bool ptrCrossingCompare (Crossing * a, Crossing * b) {
+ return a == b;
+ inline bool crossingDist (void *a, void *b) {
+ return ( (Crossing*) a)->d > ( (Crossing*) b)->d;
+ class PointSet {
+ friend class Feature;
+ friend class Pal;
+ friend class Layer;
+ friend class LabelPosition;
+ friend class PolygonCostCalculator;
+ friend class Problem;
+ friend bool pruneLabelPositionCallback (LabelPosition *lp, void *ctx);
+ //friend Feat *splitButterflyPolygon (Feat *f, int pt_a, int pt_b, double cx, double cy);
+ friend bool obstacleCallback (PointSet *feat, void *ctx);
+ friend bool extractFeatCallback (Feature*, void*);
+ friend void extractXYCoord (Feat *f);
+ friend LinkedList<Feat*> * splitGeom (GEOSGeometry *the_geom, const char *geom_id);
+ friend void releaseAllInIndex (RTree<PointSet*, double, 2, double> *obstacles);
+ friend bool releaseCallback (PointSet *pset, void *ctx);
+ friend bool filteringCallback (PointSet*, void*);
+ /*protected*/
+public:
+ int nbPoints;
+ double *x;
+ double *y; // points order is counterclockwise
+ int *status; // -1 means inside the bbox, +1 means outside and 0 is either in either out
+ int *cHull;
+ int cHullSize;
+ int type;
+ //PointSet *parent;
+ PointSet* holeOf;
+ PointSet* parent;
+ PointSet (double x, double y);
+ PointSet (PointSet &ps);
+//public:
+ double xmin;
+ double xmax;
+ double ymin;
+ double ymax;
+ PointSet ();
+ PointSet (int nbPoints, double *x, double *y);
+ ~PointSet();
+ int getPath (int start, int stop, int *path_val);
+ PointSet *extractPath (int path, int nbPtPath, int nbBboxPt, double bbx[4], double bby[4], Crossing *start, Crossing *stop, int startPt);
+ PointSet* extractShape (int nbPtSh, int imin, int imax, int fps, int fpe, double fptx, double fpty);
+ PointSet *createProblemSpecificPointSet (double bbx[4], double bby[4], bool *outside, bool *inside);
+ CHullBox * compute_chull_bbox ();
+ * \brief Take each line in shape_toProcess and only keep inside bbox line parts
+ static void reduceLine (PointSet *line,
+ LinkedList<PointSet*> *shapes_final,
+ double bbx[4], double bby[4]);
+ * \brief takes shapes from shapes_toProcess, compute intersection with bbox
+ * and puts new shapes into shapes_final
+ static void reducePolygon (PointSet* shape_toProcess,
+ * split a concave shape into several convex shapes
+ static void splitPolygons (LinkedList<PointSet*> *shapes_toProcess,
+ double xrm, double yrm, char *uid);
+ * \brief return the minimum distance bw this and the point (px,py)
+ * compute the minimum distance bw the point (px,py) and this.
+ * Optionnaly, store the nearest point in (rx,ry)
+ * @param px x coordinate of the point
+ * @param py y coordinate of the points
+ * @param rx pointer to x coorinates of the nearest point (can be NULL)
+ * @param ry pointer to y coorinates of the nearest point (can be NULL)
+ double getDist(double px, double py, double *rx, double *ry);
+ //double getDistInside(double px, double py);
+ void getCentroid (double &px, double &py);
+ * Iterate on line by real step of dl on x,y points
+ * @param nbPoint # point in line
+ * @param x x coord
+ * @param y y coord
+ * @param d ??
+ * @param ad distance from pt0 to each point (ad0 = pt0->pt0)
+ * @param dl ??
+ * @param px current x coord on line
+ * @param py current y coord on line
+ inline void getPoint (double *d, double *ad, double dl,
+ double *px, double *py) {
+ int i;
+ double dx, dy, di;
+ double distr;
+ i = 0;
+ if (dl >= 0) {
+ while (i < nbPoints && ad[i] <= dl) i++;
+ i--;
+ if (i < nbPoints - 1) {
+ if (dl < 0) {
+ dx = x[nbPoints-1] - x[0];
+ dy = y[nbPoints-1] - y[0];
+ di = sqrt (dx * dx + dy * dy);
+ } else {
+ dx = x[i+1] - x[i];
+ dy = y[i+1] - y[i];
+ di = d[i];
+ distr = dl - ad[i];
+ *px = x[i] + dx * distr / di;
+ *py = y[i] + dy * distr / di;
+ } else { // just select last point...
+ *px = x[i];
+ *py = y[i];
+} // namespace pal
+#endif
