[QGIS Commit] r10696 - trunk/qgis
svn_qgis at osgeo.org
Fri May 1 23:59:09 EDT 2009
Author: kyngchaos
Date: 2009-05-01 23:59:09 -0400 (Fri, 01 May 2009)
New Revision: 10696
trunk/qgis/INSTALL
update OSX build, add Xcode build
Modified: trunk/qgis/INSTALL
--- trunk/qgis/INSTALL 2009-05-02 02:23:41 UTC (rev 10695)
+++ trunk/qgis/INSTALL 2009-05-02 03:59:09 UTC (rev 10696)
@@ -38,7 +38,11 @@
4.5. Install subversion for OSX
4.6. Check out QGIS from SVN
4.7. Configure the build
+ 4.7.1. Configure the Cmake build
+ 4.7.2. Configure the Xcode Build
4.8. Building
+ 4.8.1 Building with Cmake
+ 4.8.2. Building with Xcode
5. Building on GNU/Linux
5.1. Building QGIS with Qt4.x
5.2. Prepare apt
@@ -473,15 +477,19 @@
You need a minimum of Qt4.3.0. I suggest getting the latest (at time of writing).
- ftp://ftp.trolltech.com/qt/source/qt-mac-opensource-4.3.2.dmg
+ ftp://ftp.trolltech.com/qt/source/
-If you want debug libs, Qt also provide a dmg with these:
+Mac versions are named as:
- ftp://ftp.trolltech.com/qt/source/qt-mac-opensource-4.3.2-debug-libs.dmg
+ qt-mac-opensource-x.y.z.dmg
+x, y, z being the major, minor and revision version.
+If you want debug libs, Qt also provide a dmg with these.
I am going to proceed using only release libs at this stage as the download for
the debug dmg is substantially bigger. If you plan to do any debugging though
you probably want to get the debug libs dmg. Once downloaded open the dmg and
@@ -492,7 +500,7 @@
First edit /Library/Frameworks/QtCore.framework/Headers/qconfig.h and
change
-/!\ Note this doesnt seem to be needed since version 4.2.3
+/!\ Note: this isn't needed since version 4.2.3.
QT_EDITION_Unknown to QT_EDITION_OPENSOURCE
@@ -504,7 +512,9 @@
sudo ln -sf macx-g++ default
+/!\ Note: this doesn't seem to be needed since version 4.4.
4.3. Install development frameworks for QGIS dependencies
@@ -517,35 +527,38 @@
Once downloaded, open and install the frameworks.
-William provides an additional installer package for Postgresql/PostGIS. Its
+William provides an additional installer package for Postgresql/PostGIS. It's
available here:
http://www.kyngchaos.com/wiki/software:postgres
+Also available is a GRASS application:
+ http://www.kyngchaos.com/wiki/software:grass
There are some additional dependencies that at the time of writing are not
-provided as frameworks so we will need to build these from source.
+provided as frameworks or installers so we will need to build these from source.
4.3.1. Additional Dependencies : GSL
-Retrieve the Gnu Scientific Library from
+Retrieve the current version of the Gnu Scientific Library from
- curl -O ftp://ftp.gnu.org/gnu/gsl/gsl-1.8.tar.gz
+ ftp://ftp.gnu.org/gnu/gsl/
-Then extract it and build it to a prefix of /usr/local:
+Then extract it and build it to a prefix of /usr/local. Double-click the source tarball to unpack it, then cd to the source folder and:
- tar xvfz gsl-1.8.tar.gz
- cd gsl-1.8
- ./configure --prefix=/usr/local
+ ./configure
make
sudo make install
- cd ..
@@ -558,13 +571,12 @@
http://sourceforge.net/project/showfiles.php?group_id=10127
+Double-click the source tarball to unpack, then cd to the source folder and:
- tar xvfz expat-2.0.0.tar.gz
- cd expat-2.0.0
+ ./configure
make
sudo make install
- cd ..
@@ -585,15 +597,12 @@
http://www.riverbankcomputing.com/software/sip/download
-Then extract and build it (this installs by default into the Python framework):
+Double-click the source tarball to unpack it, then cd to the source folder and (this installs by default into the Python framework):
- tar xvfz sip-<version number>.tar.gz
- cd sip-<version number>
python configure.py
make
sudo make install
- cd ..
Leopard notes
@@ -622,17 +631,14 @@
http://www.riverbankcomputing.com/software/pyqt/download
- tar xvfz PyQt-mac<version number here>
- cd PyQt-mac<version number here>
export QTDIR=/Developer/Applications/Qt
python configure.py
yes
make
sudo make install
- cd ..
Leopard notes
@@ -643,7 +649,7 @@
python configure.py -d /Library/Python/2.5/site-packages -b /usr/local/bin
-There may be a problem with undefined symbols in QtOpenGL on Leopard. Edit QtOpenGL/makefile and add -undefined dynamic_lookup to LFLAGS.
+If there is a problem with undefined symbols in QtOpenGL on Leopard, edit QtOpenGL/makefile and add -undefined dynamic_lookup to LFLAGS. Then make again.
4.3.5. Additional Dependencies : Bison
@@ -652,21 +658,18 @@
Leopard note: Leopard includes Bison 2.3, so this step can be skipped on Leopard.
The version of bison available by default on Mac OSX is too old so you need to
-get a more recent one on your system. Download if from:
+get a more recent one on your system. Download at least version 2.3 from:
- curl -O http://ftp.gnu.org/gnu/bison/bison-2.3.tar.gz
+ ftp://ftp.gnu.org/gnu/bison/
-Now build and install it to a prefix of /usr/local :
+Now build and install it to a prefix of /usr/local. Double-click the source tarball, then cd to the source folder and:
- tar xvfz bison-2.3.tar.gz
- cd bison-2.3
make
sudo make install
- cd ..
@@ -676,18 +679,18 @@
Get the latest release from here:
- http://www.cmake.org/HTML/Download.html
+ http://www.cmake.org/cmake/resources/software.html
-At the time of writing the file I grabbed was:
+Binary installers are available for OS X, but they are not recommended (2.4 versions install in /usr instead of /usr/local, and 2.6 versions are a strange application). Download the source. Double-click the source tarball, then cd to the source folder and:
- curl -O http://www.cmake.org/files/v2.4/cmake-2.4.6-Darwin-universal.dmg
+ ./bootstrap --docdir=/share/doc/CMake --mandir=/share/man
+ make
+ sudo make install
-Once downloaded open the dmg and run the installer
@@ -783,6 +786,16 @@
+There are 2 different methods to build QGIS. The traditional Cmake method,
+and the new Xcode project (starting with QGIS 1.1). The Xcode project has
+additional bundling steps, though some optional QGIS features are required due
+to limited conditional compilation. The Cmake build handles optional features,
+and some bundling steps are available with scripts in the mac directory.
CMake supports out of source build so we will create a 'build' dir for the
build process. By convention I build my software into a dir called 'apps' in
my home directory. If you have the correct permissions you may want to build
@@ -811,9 +824,9 @@
cmake -D CMAKE_INSTALL_PREFIX=${HOME}/apps/ \
- -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.3.app/Contents/MacOS/
+ -D GRASS_INCLUDE_DIR=/Applications/GRASS-6.4.app/Contents/MacOS/
include \
- -D GRASS_PREFIX=/Applications/GRASS-6.3.app/Contents/MacOS \
+ -D GRASS_PREFIX=/Applications/GRASS-6.4.app/Contents/MacOS \
-D CMAKE_BUILD_TYPE=Release \
@@ -824,16 +837,35 @@
- -D GRASS_INCLUDE_DIR=/user/local/grass-6.3.0/include \
- -D GRASS_PREFIX=/user/local/grass-6.3.0 \
+ -D GRASS_INCLUDE_DIR=/user/local/grass-6.4.0/include \
+ -D GRASS_PREFIX=/user/local/grass-6.4.0 \
+In the mac/xcode folder in the source, duplicate the 'qgis_user-template.xcconfig'
+file and name it 'qgis_user.xcconfig'. A default build will use the KyngChaos
+frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 and extra dependencies
+as described above, and compile for the build OSX version, so no extra configuration
+is necessary. If building on Leopard, you may want to use the system Python, which
+requires editing qgis_user.xcconfig.
+See the mac/xcode/readme.rtf for details, if you need to customize the build.
+The default build will also bundle the Qt frameworks, Postgres library, and
+other dependency libraries to create a self-contained package. The KyngChaos
+frameworks and GRASS application are not bundled.
4.8. Building
Now we can start the build process:
@@ -846,7 +878,16 @@
make install
+Open the xcode project file in Xcode. Select 'Release' build configuration
+and the 'Full Qgis' target, then build.
+The Qgis application will be found in the 'build/Release' folder in the xcode folder.
+Copy this to whereever you like.
