[QGIS Commit] r10724 - branches/Version-1_0/src/app
svn_qgis at osgeo.org
Mon May 4 07:55:44 EDT 2009
Author: jef
Date: 2009-05-04 07:55:44 -0400 (Mon, 04 May 2009)
New Revision: 10724
branches/Version-1_0/src/app/qgscontinuouscolordialog.cpp
branches/Version-1_0/src/app/qgscontinuouscolordialog.h
backport r10708 to 1.0
Modified: branches/Version-1_0/src/app/qgscontinuouscolordialog.cpp
--- branches/Version-1_0/src/app/qgscontinuouscolordialog.cpp 2009-05-04 11:55:20 UTC (rev 10723)
+++ branches/Version-1_0/src/app/qgscontinuouscolordialog.cpp 2009-05-04 11:55:44 UTC (rev 10724)
@@ -41,31 +41,16 @@
QObject::connect( btnMaxValue, SIGNAL( clicked() ), this, SLOT( selectMaximumColor() ) );
//find out the numerical fields of mVectorLayer
- QgsVectorDataProvider *provider = mVectorLayer->dataProvider();
- if ( provider )
- const QgsFieldMap & fields = provider->fields();
- int fieldNumber( 0 ), comboNumber( 0 );
- QString str;
+ const QgsFieldMap & fields = mVectorLayer->pendingFields();
- for ( QgsFieldMap::const_iterator it = fields.begin(); it != fields.end(); ++it )
+ for ( QgsFieldMap::const_iterator it = fields.begin(); it != fields.end(); ++it )
+ QVariant::Type type = ( *it ).type();
+ if ( type == QVariant::Int || type == QVariant::Double )
- QVariant::Type type = ( *it ).type();
- if ( type == QVariant::Int || type == QVariant::Double )
- str = ( *it ).name();
- classificationComboBox->addItem( str );
- mFieldMap.insert( std::make_pair( comboNumber, fieldNumber ) );
- comboNumber++;
- fieldNumber++;
+ classificationComboBox->addItem( it->name(), it.key() );
- else
- qWarning( "Warning, data provider is null in QgsContinuousColorDialog::QgsContinuousColorDialog(...)" );
- return;
//restore the correct colors for minimum and maximum values
@@ -73,22 +58,8 @@
if ( renderer )
- // Awkard - here we want to search through mFieldMap for a
- // particular value, while elsewhere in this code we need to search
- // for a particular key, so one or the other loses out, which is here.
+ classificationComboBox->setCurrentIndex( classificationComboBox->findData( renderer->classificationField() ) );
- std::map<int, int>::const_iterator iter = mFieldMap.begin();
- while ( iter != mFieldMap.end() )
- if ( iter->second == renderer->classificationField() )
- break;
- iter++;
- if ( iter != mFieldMap.end() )
- classificationComboBox->setCurrentIndex( iter->first );
- else
- classificationComboBox->setCurrentIndex( -1 );
const QgsSymbol* minsymbol = renderer->minimumSymbol();
const QgsSymbol* maxsymbol = renderer->maximumSymbol();
@@ -153,17 +124,8 @@
void QgsContinuousColorDialog::apply()
- int comboIndex = classificationComboBox->currentIndex();
- if ( comboIndex == -1 ) //don't do anything, if there is no classification field
- return;
- std::map < int, int >::iterator iter = mFieldMap.find( comboIndex );
- // Should never happen...
- assert( iter != mFieldMap.end() );
+ int classfield = classificationComboBox->itemData( classificationComboBox->currentIndex() ).toInt();
- int classfield = iter->second;
//find the minimum and maximum for the classification variable
double minimum, maximum;
QgsVectorDataProvider *provider = dynamic_cast<QgsVectorDataProvider*>( mVectorLayer->dataProvider() );
Modified: branches/Version-1_0/src/app/qgscontinuouscolordialog.h
--- branches/Version-1_0/src/app/qgscontinuouscolordialog.h 2009-05-04 11:55:20 UTC (rev 10723)
+++ branches/Version-1_0/src/app/qgscontinuouscolordialog.h 2009-05-04 11:55:44 UTC (rev 10724)
@@ -44,9 +44,6 @@
protected:
QgsVectorLayer* mVectorLayer;
- /**Stores the relationship between provider field indices and field selection
- combobox indices. First is the combobox index, second is the provider field index */
- std::map<int, int> mFieldMap;
private:
/** Default constructor is private, do not use this */
