[QGIS Commit] r10731 - trunk/qgis/src/ui
    svn_qgis at osgeo.org
    Mon May  4 14:50:40 EDT 2009
Author: wonder
Date: 2009-05-04 14:50:40 -0400 (Mon, 04 May 2009)
New Revision: 10731
Added:
   trunk/qgis/src/ui/qgsconfigureshortcutsdialog.ui
Forgotten to add configure dialog's ui file in last commit.
Added: trunk/qgis/src/ui/qgsconfigureshortcutsdialog.ui
--- trunk/qgis/src/ui/qgsconfigureshortcutsdialog.ui	                        (rev 0)
+++ trunk/qgis/src/ui/qgsconfigureshortcutsdialog.ui	2009-05-04 18:50:40 UTC (rev 10731)
@@ -0,0 +1,122 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
+ <class>QgsConfigureShortcutsDialog</class>
+ <widget class="QDialog" name="QgsConfigureShortcutsDialog">
+  <property name="geometry">
+   <rect>
+    <x>0</x>
+    <y>0</y>
+    <width>385</width>
+    <height>304</height>
+   </rect>
+  </property>
+  <property name="windowTitle">
+   <string>Configure shortcuts</string>
+  </property>
+  <layout class="QVBoxLayout" name="verticalLayout">
+   <item>
+    <widget class="QTreeWidget" name="treeActions">
+     <property name="rootIsDecorated">
+      <bool>false</bool>
+     </property>
+     <property name="columnCount">
+      <number>2</number>
+     </property>
+     <column>
+      <property name="text">
+       <string>Action</string>
+      </property>
+     </column>
+     <column>
+       <string>Shortcut</string>
+      </property>
+     </column>
+    </widget>
+   </item>
+   <item>
+    <layout class="QHBoxLayout" name="horizontalLayout">
+     <item>
+      <widget class="QPushButton" name="btnChangeShortcut">
+       <property name="focusPolicy">
+        <enum>Qt::NoFocus</enum>
+       </property>
+        <string>Change</string>
+       </property>
+       <property name="checkable">
+        <bool>true</bool>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnSetNoShortcut">
+        <string>Set none</string>
+       </property>
+      </widget>
+     </item>
+     <item>
+      <widget class="QPushButton" name="btnResetShortcut">
+        <string>Set default</string>
+       </property>
+      </widget>
+     </item>
+    </layout>
+   </item>
+   <item>
+    <widget class="QDialogButtonBox" name="buttonBox">
+     <property name="orientation">
+      <enum>Qt::Horizontal</enum>
+     </property>
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Close</set>
+     </property>
+    </widget>
+   </item>
+  </layout>
+ </widget>
+ <tabstops>
+  <tabstop>treeActions</tabstop>
+  <tabstop>btnChangeShortcut</tabstop>
+  <tabstop>btnSetNoShortcut</tabstop>
+  <tabstop>btnResetShortcut</tabstop>
+  <tabstop>buttonBox</tabstop>
+ </tabstops>
+ <resources/>
+ <connections>
+  <connection>
+   <sender>buttonBox</sender>
+   <signal>accepted()</signal>
+   <receiver>QgsConfigureShortcutsDialog</receiver>
+   <slot>accept()</slot>
+   <hints>
+    <hint type="sourcelabel">
+     <x>248</x>
+     <y>254</y>
+    </hint>
+    <hint type="destinationlabel">
+     <x>157</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+  <connection>
+   <signal>rejected()</signal>
+   <slot>reject()</slot>
+   <hints>
+     <x>316</x>
+     <y>260</y>
+    </hint>
+     <x>286</x>
+     <y>274</y>
+    </hint>
+   </hints>
+  </connection>
+ </connections>
+</ui>
