[QGIS Commit] r10742 - in trunk/qgis: python/gui src/gui
svn_qgis at osgeo.org
Tue May 5 17:52:46 EDT 2009
Author: jef
Date: 2009-05-05 17:52:46 -0400 (Tue, 05 May 2009)
New Revision: 10742
trunk/qgis/python/gui/qgisinterface.sip
trunk/qgis/src/gui/qgisinterface.h
fix python binding compile error
Modified: trunk/qgis/python/gui/qgisinterface.sip
--- trunk/qgis/python/gui/qgisinterface.sip 2009-05-05 18:46:21 UTC (rev 10741)
+++ trunk/qgis/python/gui/qgisinterface.sip 2009-05-05 21:52:46 UTC (rev 10742)
@@ -89,8 +89,8 @@
/** Add a dock widget to the main window */
virtual void addDockWidget ( Qt::DockWidgetArea area, QDockWidget * dockwidget )=0;
- /** Remove specified dock widget from main window (doesn't delete it). Added in QGIS 1.1. */
- virtual void removeDockWidget ( QDockWidget * dockwidget )=0;
+ /** Remove specified dock widget from main window (doesn't delete it). Added in QGIS 1.1. */
+ virtual void removeDockWidget ( QDockWidget * dockwidget )=0;
/** refresh legend of a layer */
virtual void refreshLegend( QgsMapLayer * layer )=0;
@@ -102,6 +102,16 @@
* windows which are hidden rather than deleted when closed. */
virtual void removeWindow( QAction *action ) = 0;
+ /** Register action to the shortcuts manager so its shortcut can be changed in GUI
+ \note added in 1.2
+ virtual bool registerMainWindowAction( QAction* action, QString defaultShortcut ) = 0;
+ /** Unregister a previously registered action. (e.g. when plugin is going to be unloaded)
+ virtual bool unregisterMainWindowAction( QAction* action ) = 0;
/** Accessors for inserting items into menus and toolbars.
* An item can be inserted before any existing action.
Modified: trunk/qgis/src/gui/qgisinterface.h
--- trunk/qgis/src/gui/qgisinterface.h 2009-05-05 18:46:21 UTC (rev 10741)
+++ trunk/qgis/src/gui/qgisinterface.h 2009-05-05 21:52:46 UTC (rev 10742)
@@ -135,10 +135,14 @@
- /** Register action to the shortcuts manager so its shortcut can be changed in GUI */
- /** Unregister a previously registered action. (e.g. when plugin is going to be unloaded */
// TODO: is this deprecated in favour of QgsContextHelp?
