[QGIS Commit] r10795 - in trunk/qgis/src: plugins/grass
plugins/grass/config plugins/grass/modules
plugins/grass/scripts providers/grass
svn_qgis at osgeo.org
Thu May 14 16:13:15 EDT 2009
Author: rblazek
Date: 2009-05-14 16:13:14 -0400 (Thu, 14 May 2009)
New Revision: 10795
Added:
trunk/qgis/src/plugins/grass/modules/qgis.db.connect-login.pg.1.png
trunk/qgis/src/plugins/grass/modules/qgis.db.connect-login.pg.qgm
trunk/qgis/src/plugins/grass/scripts/
trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt
trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
trunk/qgis/src/plugins/grass/CMakeLists.txt
trunk/qgis/src/plugins/grass/config/default.qgc
trunk/qgis/src/providers/grass/qgsgrass.cpp
fixed ticket #1173, new script which runs both db.connect and db.login (if necessary) for postgres database, connection is tested
Modified: trunk/qgis/src/plugins/grass/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/CMakeLists.txt 2009-05-14 17:03:43 UTC (rev 10794)
+++ trunk/qgis/src/plugins/grass/CMakeLists.txt 2009-05-14 20:13:14 UTC (rev 10795)
@@ -1,5 +1,5 @@
-SUBDIRS(config modules themes)
+SUBDIRS(config modules scripts themes)
ADD_DEFINITIONS(-DGRASS_BASE=\\\"${GRASS_PREFIX}\\\")
ADD_DEFINITIONS(-DHAVE_OPENPTY=${HAVE_OPENPTY})
Modified: trunk/qgis/src/plugins/grass/config/default.qgc
--- trunk/qgis/src/plugins/grass/config/default.qgc 2009-05-14 17:03:43 UTC (rev 10794)
+++ trunk/qgis/src/plugins/grass/config/default.qgc 2009-05-14 20:13:14 UTC (rev 10795)
@@ -403,6 +403,7 @@
<section label="Database management">
<grass name="db.connect"/>
<grass name="db.connect.schema"/>
+ <grass name="qgis.db.connect-login.pg"/>
<grass name="v.db.reconnect.all"/>
<grass name="db.login"/>
<grass name="db.in.ogr"/>
Added: trunk/qgis/src/plugins/grass/modules/qgis.db.connect-login.pg.1.png
(Binary files differ)
Property changes on: trunk/qgis/src/plugins/grass/modules/qgis.db.connect-login.pg.1.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/qgis/src/plugins/grass/modules/qgis.db.connect-login.pg.qgm
--- trunk/qgis/src/plugins/grass/modules/qgis.db.connect-login.pg.qgm (rev 0)
+++ trunk/qgis/src/plugins/grass/modules/qgis.db.connect-login.pg.qgm 2009-05-14 20:13:14 UTC (rev 10795)
@@ -0,0 +1,11 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
+<qgisgrassmodule label="Set PostgreSQL DB connection" module="qgis.db.connect-login.pg.py">
+ <option key="database" />
+ <option key="schema" />
+ <option key="host" />
+ <option key="port"/>
+ <option key="user"/>
+ <option key="password"/>
+</qgisgrassmodule>
Added: trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt
--- trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt (rev 0)
+++ trunk/qgis/src/plugins/grass/scripts/CMakeLists.txt 2009-05-14 20:13:14 UTC (rev 10795)
@@ -0,0 +1,5 @@
+FILE (GLOB MODULE_FILES *.py )
+INSTALL (FILES ${MODULE_FILES}
+ DESTINATION ${QGIS_DATA_DIR}/grass/scripts
+ PERMISSIONS OWNER_READ OWNER_WRITE OWNER_EXECUTE GROUP_READ GROUP_EXECUTE WORLD_READ WORLD_EXECUTE )
Added: trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
--- trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py (rev 0)
+++ trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py 2009-05-14 20:13:14 UTC (rev 10795)
@@ -0,0 +1,117 @@
+#!/usr/bin/env python
+# MODULE: qgis.db.connect-login.py
+# AUTHOR(S): Radim Blazek
+# PURPOSE: Connect to Postgresql
+# COPYRIGHT: (C) 2009 by Radim Blazek
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Make connection to PostgreSQL database and login.
+#% keywords: database
+#%End
+#%option
+#% key: host
+#% type: string
+#% label: Host
+#% description: Host name of the machine on which the server is running.
+#% required : no
+#%end
+#%option
+#% key: port
+#% type: integer
+#% label: Port
+#% description: TCP port on which the server is listening, usually 5432.
+#% required : no
+#%end
+#%option
+#% key: database
+#% type: string
+#% key_desc : name
+#% gisprompt: old_dbname,dbname,dbname
+#% label: Database
+#% description: Database name
+#% required : yes
+#%end
+#%option
+#% key: schema
+#% type: string
+#% label: Schema
+#% description: Database schema.
+#% required : no
+#%end
+#%option
+#% key: user
+#% type: string
+#% label: User
+#% description: Connect to the database as the user username instead of the default.
+#% required : no
+#%end
+#%option
+#% key: password
+#% type: string
+#% label: Password
+#% description: Password will be stored in file!
+#% required : no
+#%end
+import sys
+import os
+import string
+import grass
+def main():
+ host = options['host']
+ port = options['port']
+ database = options['database']
+ schema = options['schema']
+ user = options['user']
+ password = options['password']
+ #if not maptable:
+ # grass.fatal("There is no table connected to this map. Cannot join any column.")
+ # Test connection
+ conn = "dbname=" + database
+ if host: conn += ",host=" + host
+ if port: conn += ",port=" + host
+ # Unfortunately we cannot test untill user/password is set
+ if user or password:
+ print "Setting login (db.login) ... "
+ sys.stdout.flush()
+ if grass.run_command('db.login', driver = "pg", database = conn, user = user, password = password) != 0:
+ grass.fatal("Cannot login")
+ # Try to connect
+ print "Testing connection ..."
+ if grass.run_command('db.select', quiet = True, flags='c', driver= "pg", database=conn, sql="select version()" ) != 0:
+ print "Deleting login (db.login) ..."
+ if grass.run_command('db.login', quiet = True, driver = "pg", database = conn, user = "", password = "") != 0:
+ print "Cannot delete login."
+ grass.fatal("Cannot connect to database.")
+ if grass.run_command('db.connect', driver = "pg", database = conn, schema = schema) != 0:
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: trunk/qgis/src/plugins/grass/scripts/qgis.db.connect-login.pg.py
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp 2009-05-14 17:03:43 UTC (rev 10794)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp 2009-05-14 20:13:14 UTC (rev 10795)
@@ -181,6 +181,7 @@
#endif
QString path = "PATH=" + gisBase + "/bin";
path.append( sep + gisBase + "/scripts" );
+ path.append( sep + QgsApplication::pkgDataPath() + "/grass/scripts/" );
// On windows the GRASS libraries are in
// QgsApplication::prefixPath(), we have to add them
